Samsung dvd player S224 pictures on screen are in red tones only
    Scholar:
  • 85 Answers
How is video on the dvd player hooked up? via s-video, component cables ( r,g,b), or the yellow cable? if it is the yellow cable then i beleive to be something wrong with the unit but just make sure you are plugging into the yellow input on tv. if it is the other types make sure you dont have the rgb cables mixed up. it is very easy to mix up the 3 wires. if it is the s-video cable try a different one if you can and make sure all pins are intact when you remove them. i hope this helps and good luck
Posted on Feb 19, 2009
  • Chuck Feb 22, 2009
    ok i am looking into the menu online alittle more i hope to change your mind on the thanks for trying box up to atleast helpful. lol. The only thing i see in the settings was turning AAC off, and then DTS might work and set to bitstream on the hdmi settings for audio
How do install samsung dvd player dvd s224 with a bauhn tv
Plug the HDMI cable that came with the DVD player into an HDMI port on your TV.
Feb 21, 2015 | Samsung DVD-S224 DVD Player
The VHS tapes will not playback on the Samsung TV (flat screen)..the Samsung TV is a Syncmaster 2333 HD...the Samsung dvd/vhs unit is a DVD-V9800 The DVD discs will play just fine. How should I be...
On these combo units, the VCR will not play using component cables but the dvd's will play just fine.
What you need to do is run a pair of composite (Yellow, red and white) cables and use that for VCR and component (Green, blue, red, white and red) for the dvd player.
Make sure you switch the tv to the corresponding input.
Dec 30, 2009 | Samsung DVD-V9800 DVD Player/VCR
When I switch to the DVD player on my Samsung Big screen TV, the pictures turns green. Tom
If the DVD player is hooked up with a Component Input connection on the TV. A red, blue, and green wire for video, one of them is backwards and needs to be switched and plugged in correctly.
Dec 24, 2009 | Samsung DLP HL-P5663W 56" TV
No picture from dvd player on tv
Try to push the cords faster in, that might be ther problem (the red yellow and white) you can try turning them or putting the converter itself faster in or change if you can. (from 1 slot to another)
Oct 23, 2009 | Samsung Televison & Video
Need codes for tv and dvd player/recorder.
This wasn't my problem! As I have explained before, I put the question on about a urc22B-12B control and FixYa somehow classed it as a Jensen.
Sep 03, 2009 | Jensen JR500 Remote Control
I hear sound but no picture!!!!!!
If your using dubbing wires to connect to tv then check or replace the video input wire
Aug 28, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
I have a samsung2333hd and want to connect a dvd player using the connections marked pr(red) pb(blue) y (green) when i connect them all i get a redish pink screen then when i connect two of them i get...
OK no problem here. I can help. First reconnect the DVD Player to the tv using the Compoment cables. Match Green to Green,Red to Red and Blue to Blue.. If this is done correctly then you will have normal looking picture. If the picture looks like it is missing the RED color then switch both Red cables. The pix should look normal. Then connect the RED and White audio cables to the audio inputs . Now the Pinkish color is a result of the DVD Player not being set to the "Progressive" setting in the DVD Player Menu. It will help to connect a set of COMPOSITE cables from the DVD Player to the TV's Composite Input. Those are the Yellow,Red and White inputs on both the tv and the DVD Player. This will allow you to see the DVD player menu in case you cannot see the menu while in the Component input. The Pinkish picture should go to a Normal picture.
Jul 04, 2009 | Samsung Televison & Video
Connect Philips DVD to Sansung TV
the red and black are the same as the red and white, these are the audio left and right channels. the yellow plug is the video plug. the next thing you have to check is wheather your tv has video 1 and 2 channels
May 09, 2009 | Samsung Televison & Video
Samsung DVD-SH853M HDD/DVD Recorder/Digital Receiver
Make sure you are not using DVD+R dics - the player won't play these. It is OK with DVD-R.
Jan 21, 2008 | Samsung DVD-HD950 DVD Player
Door will not open
While Unit is ON
press and Hold STOP on front panel, press power on the remote - Toggles
Dealer Lock ON/OFF (This is used to prevent customers removing a sample CD
from a display model
Jan 07, 2007 | Samsung DVD-S224 DVD Player
Televison & Video Logo
159 people viewed this question
Top Televison & Video Experts
