Question about Technics SC-DV290 System
Hi fi totaly lost bass
Sound not entertaining at all lost complet bass
Have you cheaked the low frequency cables are ok running from the unit to the speakers if not try that
Posted on Feb 28, 2009
I have a bose 321 system and I was wondering if there is a way to turn the bass up and down without the remote. I lost it
321 Home Entertainment System - Bose Product Support
worldwide.bose.com/productsupport/.../321.../page.htm...
Bose CorporationDiscover product support for your 321 home entertainment system. ... Learn how to setup and place your system components. more » ... You can adjust bass and treble levels to suit your listening preferences and your ... Discover how to use buttons on your remote and media center control panel to ... Get Adobe Reader.
[PDF]3•2•1 Home Entertainment System - Bose
worldwide.bose.com/axa/assets/pdf/.../og_321.pdf
Bose CorporationJan 29, 2002 - within the system enclosure that may be of sufficient magnitude to constitute a risk of electric .... Turning off the internal speakers in your TV .
Jan 18, 2016 | Bose 321 Series Iii Dvd Home Entertainment...
When playing LP the sound is bass heavy, but when playing a cd, the sound is perfect.... any suggestions?
The record deck is played through a separate pre-amp to all other functions, so it therefore could be a fault in that pre-amp, but I doubt it. You can fit a wide verity of cartridges in record decks that will each give a different response to the sound. But first check that the cartridge connections are correct. Try swapping them around, it might change what you get. But it could simply be that you have a cartridge that produces a lot of bass. Changing the cartridge to a high quality recommended type - by say some hi-fi buffs website or magazine, might solve the problem.
Apr 14, 2015 | Pioneer PL990 Turntable
Sony audio docking system ipod PCB spare part
Do you know hqew.net? Know the pcb.hqew.net is the best PCB small batch customization supplier in China?
http://pcb.hqew.net/?s=544849
or
http://www.aliexpress.com/store/233890
Is custom PCB link
Jun 30, 2013 | Sony 100 watts Hi-Fi Audio Stereo Sound...
I have Denon AVR-2310...but lost operating manual ! In audio set up, more specifically speaker configuration, a choice is given between " FTE", and "FTE +main". What is the...
The manual... http://www.retrevo.com/support/Denon-AVR-2310CI-Receivers-manual/id/23452bh638/t/2/
I'm pretty sure you mean "LFE + Main".
You need to identify the speakers to the receiver as Large or Small regarding their bass-handling capacity more than their actual size.
"LFE" removes the possibly overloading bass in a given speaker channel containing 'small' speakers and sends it to the subwoofer.
"LFE + Main" is sort of explained on page 29 "Bass Setting". The intent of LFE+Main is to task your subwoofer with the bass that ALSO exists on all other speaker channels regardless of their ability to handle it all by themselves. As you can imagine, this might make the subwoofer respond to sonic events that are actually supposed to be directional from, say, the rear channel(s). In that case the event might seem to come from wherever the sub is located instead of the intended direction; or at the very least it might seem to come from both places which is probably not what the sound engineers intended when they recorded the piece.
Having full-range speakers 360-degrees around PLUS a subwoofer, I don't subscribe to the 'bass-is-non-directional' school of thought. If you've ever felt the concussion from and subconsciously glanced toward one of the speakers after, say, a huge explosion, the system is working.
Sep 03, 2011 | Denon Audio Players & Recorders
How would I attach my hi-fi Goodmans Speakers to a LSD TV
Your best bet to improve the bass is to attach the audio output of your HDTV to a stereo unit and amplify the audio with the amplifier. Attaching the speakers to the HDTV will not improve the sound much. Sorry.
Jan 11, 2010 | LG 42LC2D 42 in. LCD HDTV
Not getting high depth of bass sony MHC-RV777d
I wouldn't expect huge bass from those little speakers. Somewhere on there, there's an equiliser, where you 'll probably be able to turn the bass up and down. See if that works. If not, new speakers may help.
Jan 08, 2010 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
How to incrise the bass of sony MHC-RV777d
Is it possible that the speakers are out of phase, where one speaker is moving out, the other is moving in, resulting in zero bass?
Other than checking wires, making sure + on amp is linked to + on speaker, try changing the eq settings, or sit them next to a wall - walls help bass a lot.
Bass speaker moving in out more then normal
If you can't hear the difference maybe the bass frequency which is moving the speakers is below your hearing range.
I think you may have a "loudness" button on that amp -- if you do, turn off the loudness -- this is a bass booster.
But, in general, bass speakers are designed to move in & out a lot. They have to move a lot of air to produce the bass sound.
May 09, 2009 | B&W ASW1000 Speaker
GETTING BETTER SOUND QUALITY
An equaliser is, put simply, a more complex tone control, giving you the ability to cut or boost more specific frequencies than a tone knob, or bass & treble controls.
It comes in handy for tweaking the sound from your hi-fi to just the way you like it. But beware, as it can make your hi-fi produce sounds that are so bass or treble heavy, that you can damage your speakers if you're not careful.
Adding another compnent into the chain (like a graphic EQ) can add a little background noise but this Technics EQ is a pretty quiet one & you probably won't notice the noise apart from when there's no music playing & you've got the amp turned up high.
Jan 10, 2008 | Technics SH-GE70 Home Equalizer
Soundcard
This Sound Blaster X-Fi Vista Installation CD is intended to support X-Fi products bought before a Vista installation CD was available in the box.
It supports the following models:
  • SB X-Fi Xtreme Music (SB0460)
  • SB X-Fi Xtreme Gamer (SB0730/SB073A)
  • SB X-Fi Xtreme Gamer - Fatal1ty Professional Series (SB046A)
  • SB X-Fi Fatal1ty FPS (SB0466/SB0256)
  • SB X-Fi Platinum (SB0460/SB0251)
  • SB X-Fi Platinum Fatal1ty Champion Series (SB046A/SB0256)
  • SB X-Fi Elite Pro (SB0550/SB0510, SB055A/SB0510) This CD does not support the Sound Blaster X-Fi Xtreme Audio range (SB0790/SB0792).
This Sound Blaster X-Fi Vista Installation CD includes a full suite of drivers and applications:
  • X-Fi Mode Consoles (Gaming/Entertainment/Audio Creation)
  • Creative Mode Switcher
  • Creative Audio Console
  • THX Console
  • Creative MediaSource 5
  • Creative Smart Recorder 2
  • Creative WaveStudio
  • SoundFont Bank Manager
  • Creative 3DMIDI Player
  • Creative Diagnostics
  • Creative Entertainment Center
For more information on how to obtain a copy of Sound Blaster X-Fi Vista Installation CD, please refer to our regional sites at www.europe.creative.com or us.creative.com.
Windows XP applications do not work with Windows Vista. When launched, it will display a message "The audio device supported by this application is not detected. The application will exit" even though your Sound Blaster card is working properly.
If you have installed any Windows XP applications for your Sound Blaster X-Fi card, it is recommended that you uninstall these (Windows XP) applications before installing the Sound Blaster X-Fi Vista Installation CD. To uninstall, go to Control Panel, and select Programs and Features, and then choose the applications that you need to uninstall.
Nov 18, 2007 | Biostar P4TPT - Motherboard
Technics SC-DV290 System Logo
102 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
