Question about Kenmore Dryers
Fuse blowing on timed cycle dryer blows fuse replaced fuse put on permanent press cycle dryer runs good tryed timed cycle again and blew fuse after 20 minutes. should timer be replaced
  • lindapatters Feb 22, 2009
    vent is clear
    Thank you
  • lpattersn May 11, 2010
    which fuse is blowing? i.e., household fuse, thermal fuse in dryer, etc.
  • Kenmore Master
  • 3,361 Answers
Your exhaust vent is blocked.
Timed dry is High heat.
Permanent press is a medium heat and intermittent.
The dryer does not get as hot as often in Permanent press mode. Therefore the fuse does not reach critacal and blow.
Remove the vent at the rear of the dryer and run a timed load.
If it dries correctly, repair your vent blockage.
If not, repost and I will lead you to the next step.
Posted on Feb 20, 2009
Lg dryer is overheating blowing the thermal fuse
you have an airflow problem. Check the vent hose all the way out and the outdoor vent hood.
a simple verification can be performed by disconnecting the vent hose from the dryer and see if this solves the problem.
Mar 03, 2014 | LG DLE5977 Electric Dryer
The thermal fuse keeps blowing
If you pull it out of closet and replace fuse and it works even after turning off again etc for several times--something is happening when it gets put back---did you disconnect venting connection when you pulled it out?
Dec 17, 2012 | Estate EED4400WQ Dryer
Sears 417.80042990 keeps blowing thermal fuse
Did you clean out the lint filter at the front, heat is the enemy. Clean out all lint from front, if you are handy, get around back and remove all lint and dust by blowing compressed air.
Sep 21, 2012 | Frigidaire FEQ332E Electric Dryer
My Kenmore HE5 dryer will not run without blowing an internal fuse. The repairman replaced the fuse, and it blew again. The dryer heats up but will not turn it's heating element off until the fuse blows....
Has any one checked the exhaust vent,other than a bad thermostat the number one cause for the thermal fuse to open is a clogged or restricted exhaust vent flow, the entire vent system needs to be checked ( not just the hose from the unit to the wall) for proper air flow. Turn the unit on TIMED ,AIR DRY (NO HEAT) and go outside to the exhaust vent and check the air flow,if there is any question as to weather the air flow is sufishent get someone out to clean the exhaust vent ,it always a good idea to clean out every few years regardless to help prevent build up of lint witch could cause a fire......Hope this Helps Good Luck
Dec 14, 2010 | Kenmore HE5 Electric Dryer
The dryer is blowing the one time fuse
I would also replace the cycle thermostat mounted by the thermal fuse, I believe the part number will be 3387134 but be sure to look it up by model number. If this is not cycling the dryer at the proper temps it will cause the fuse to blow. The other thing that would blow the fuse would be a venting restriction. Check your airflow outside and make sure its got good airflow. If not be sure to clean or replace your venting before running the dryer again. Hope this helps -MJ-
Jan 28, 2010 | Kenmore Dryers
Engine management fuse keeps blowing
My car stopped running without any warning, its a 2005 ford focus, 2.0 and the 20 amp fuse for the engine management keeps blowing, it's number 9 in the panel and I have replaced it twice, both times it blew again, any tips? Also the odometer reads ------ and that's it.
Jan 09, 2010 | 2001 Ford Focus
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Blows fuse for heat after about 30 minutes
yes , occassionally though it will run for full cycle ....but not very often
Sep 06, 2008 | Kenmore 73952 Gas Dryer
Dryer Thermal Fuse
air flow could be the issue or if your heater itself is grounded against the cabinet i think your unit is getting to hot check all your vent lines if you have good air flow check the heater try taking the vent totally off for a few cycles and see if the fuse blows agian
Mar 15, 2008 | Kenmore 64902 Electric Dryer
Hotpoint NVL333EY Electric dryer blows thermal fuse
I had the same thing happen, I replaced the thermal cutoff and made sure no lint build up. It lasted a week then blew again. I then replaced it again and got to thinking why it would blow. I then took apart the exaust inside the dryer running fron the drum to the motor and right before the motor was a build up of lint ane particals that was almost like compressed sawdust which was blocking half of the line. I cleaned this out and it seemed to work much better.
Jan 04, 2008 | Hotpoint NVL333EY Electric Dryer
Dryers Logo
123 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
