Question about Canon Rebel XT / EOS 350D Digital Camera
My lens will not come off my Digital Rebel...
I have the original Digital Rebel and have several lenses that I use. The original 18-55 mm lens is not working so I purchased a 50 mm lens for every day use. I have taken it off and on several months now without any issues but now when I try to take it off to change the lens, it will turn just slightly when I push in the release button and then stops. It will not release nor turn any further. Help! ETA: The camera itself is almost six years old and never had any problems with it.
  • Canon Master
  • 5,412 Answers
Take it to a service centre, let them deal with it, and fix the problem that has caused this.
Posted on May 29, 2017
SOURCE: AF and shutter release failure
There was a lot of discussion of this when the Mk II was new. Many people "fixed" it doing just the things you did. Also, some reported that mounting the lens on another camera "fixed" it. IIRC, in the end it ended up being a lens issue. IS module. Canon can repair.
Posted on Aug 16, 2007
  • 34 Answers
SOURCE: Nikon D80 black spot center of photos
There is dust on the imaging sensor, and it will need to be cleaned off. A local repair shop can take care of this, or search photography forums for proper technique. Note, improper cleaning can damage the sensor, so use caution.
Posted on Sep 26, 2007
SOURCE: Camera won't shoot with lens on Auto Focus
Talked to canon support, they suggested to send lense in for review/repair. They said it could be the motor, I think it was a gear problem based on the noises and jerkiness of the focusing action while in manual focus (manual focus gave out as well). Cost TBD - "would definately be more than $50. I shopped around and elected to buy a new lense rather than try to hassle with the repair, shipping, insurance, and the wait, etc. Besides, I have a deadline that I need the lense for, so repair at Canon really became a non-option. I think the cost would've been pretty much the same in the end as the new lense, since this wasn't one of the costlier of lenses to begin with.
Posted on Mar 20, 2008
SOURCE: Nikon D40x AF-S Nikkor 18-55 mm 1:3.5-5.6 GII ED Lense Trouble
I've found the same thing with my D40x and the 18-55mm AF-S lens. I took a really close look at it and found that the mount on the lens is badly worn on all three of the bayonet tangs and one is cracked at the base. What happens in my case is that the lens has movement when mounted on the camera - just enough to stop the contacts from mating properly. Hence, no photos. Am taking it to Nikon to get it fixed. I suggest if this is your problem, that you take it to the repair man.
Posted on Dec 10, 2008
Gurudristi
  • 98 Answers
SOURCE: Canon EOS Digital Rebel 300D will not take pictures
Have you tried to take picture by switching off the autofocus to manual focus in a prperly lit environment?
If it takes a picture, then it has something to do with your auto focus system of your camera. In such a case: try taking out the battery, the memory card etc and switch off the camera and keep it for like that for about 5 minutes. And then insert only the fully charged battery and try again.
If it still gives you a problem and keep trying to focus You will need to take it to the nearest Canon Service centre.
Posted on Mar 08, 2009
My canon ds6041 displays err 99 when i try to capture light aur object in sun light.What should i do i'm using 70-21-mm lense
Usually this is cased by shutter failure or failure of the aperture unit in the lens. Try another lens and see if you get the same error message - that will tell you if the problem is in the camera body or lens
Apr 05, 2013 | Canon Digital Rebel / EOS-300D Digital...
Are older Sigma Quantaray lenses that I used with a 35 mm SLR Canon Rebel 2000EOS compatible with new DSLR Canon bodies?
Yes. Bear in mind that many Canon digital SLRs have a sensor smaller than a frame of 35mm film. This results in the image being cropped, narrowing the field of view and making the lens behave as if it was of a longer focal length.
Sep 02, 2011 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Error 99 with a Canon 300D (original rebel) and Tamron XR Di II 18 to 200 mm lens. Occurs when lens is zoomed out. Does not happen with other lenses (Canon 18-55 kit, Canon 75-300). Cleaning contacts on...
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thank you for using Fixya!
Apr 17, 2011 | Tamron AF 28-200mm f/3.8-5.6 LD Aspherical...
I just purchased a Canon EOS Rebel K2 35 MM film camera body. What lenses are compatible with this camera?
The Rebel K2 has the Canon EF mount. It is compatible with any EF lenses except the EF-S series. It will also work with third-party lenses that are compatible with the Canon EF series.
You can see the entire current line of Canon lenses (including the EF-S series) at
http://www.usa.canon.com/cusa/consumer/products/cameras/ef_lens_lineup
Jan 25, 2011 | Canon EOS Rebel K2 with 28-90 lens 35mm...
1000d error code 1
user manual say its a communication problem between the camera and lens. The suggested solution is to clean the contacts.
Jan 18, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
I have a Canon EOS Digital Rebel XT with the original 18-55mm lense and a Quantarey 70-300mm lense. Have had all pieces for 3 years now and everything worked great until last night. Camera focuses and...
This means that the communication with the Quantarey lens is not the right one.
You can try in cleaning the lens contacts and the camera contacts with a pencil eraser or a white erase (flip down the camera so no particles get inside the mirror box).
If still you are having problems, then that means the Quantarey lens is defective, and either needs to be service to be repaired, or you will need to get another zoom lens.
Best regards,
Jul 02, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Quantary 100-300mm telephoto lense
I have been researching this problem and found there's nothing you can do. Appararently, the quantaray, being an older lens, wasn't made to work with this latest era of cameras. Though it might work perfectly with your older camera, its technology is outdated as it relates to digital cameras and can't mesh with the latest and greatest. By the way, most of my questions were answered on the Digital Camera Resource page (www.dcresource.com)
Jul 25, 2007 | Quantaray 100-300mm F4.5-6.7 Zoom lens for...
80-200 mm lens not responding
whos make is the lens - some sigma/tamron etc lens will need to be rechipped and do not work on later EOS cameras also whats the aperture - there is a maximum that the AF will work with and again some 3rd party lenses have a problem
Apr 27, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
193 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
