Question about HP LaserJet 2840 All-In-One Printer
Out going faxes some go through and some don't.
Some give me a busy sig. and others go OK I tried calling the same number from a phone at the same time it was ring busy and I get through.
this tells me that the machine is not connecting. It is a line with DSL on it.
I recently added filters they supplied but it made no difference.
    Genius:
  • 2,120 Answers
Filters will not cure your problem. ALL fax machines are ANALOG devices and will not work on DIGITAL phone lines.
Posted on Feb 20, 2009
All my faxes say busy
It is not uncommon for this to happen. What I did with my Pixma was go on the assumption that the fax executable file had become corrupted. So I uninstalled it, then reinstalled, and all went smoothly until the next time, when the same solution worked again. Since the other possibility is hardware which means money, try my solution.
Oct 15, 2014 | Canon Pixma MX410 All-In-One Printer
Problem with the F/T setting.
leave these phones unused for one day and then use it and see.
leaving them unused will make everything get settled.
Jul 29, 2008 | Office Equipment & Supplies
Can fax to a toll free number but not to a local number
The easiest way to experiment with this problem is to plug in a phone in place of the fax.Take the list of numbers and try dialing them with the phone.Many local carriers now require for you do dial a "1" before the exchange,even if you are in the same area code.(I live in the D.C. area,and we have to dial "1" first).I believe adding a 1 to your local fax numbers will correct this issue.If not,try dialing another number at your location.If you can call one of your other numbers OK,but cannot dial to a local number even when dialing 1-area code-exchange-last four digits,this may be an issue with your long distance carrier.(Anytime you dial one before the other ten digits,it goes through along distance carrier,even on local calls).
Jun 12, 2012 | Brother IntelliFAX 1840C Plain Paper...
Canon ImageRunner 1025if won't fax to #s, only email
Try to connect simple phone to fax line and try to dial a number of fax that you are calling from machine.If the line is ok then do the next:
press MENU and # ( service mode) with cursors go to clear, ok, clear all and ok.Turn off and on.
If that doesnt help call service.
Be carefull: the tel. line to fax machine must be connected in L slot, not in small picture of telephone.
Jun 15, 2010 | Canon Imagerunner 1025IF Grayscale Copier
We cannot receive faxes. Gives a busy signal.
Unplug the phone line from the machine. Wait a few minutes then try calling your fax number from a phone while leaving the phone line disconnected from the machine. If it rings fine from the phone, then re-install the phone line to the fax machine. Try making the call again. If you now get a busy signal then the modem in your fax machine has gone bad and is holding the line open. Make sure when installing the phone line you are placing the cord into the "line" port on the machine and not the phone port.
Good Luck and thank you for using Fixya.
Mar 18, 2010 | HP LaserJet 3050 All-In-One Printer
When I dial a fax number I get a busy signal even though I know that the number is not busy because I have dialed it on my outside line and it works. This has happened repeatedly. I have unplugged...
Since you mentioned that you have an outside line, do you have to use a code to dial out normally? Try plugging in a phone to the line for your fax machine, and attempt to dial the number for the other fax machine using the phone. You should reach the fax and hear a high pitched sequence of tones. This is the other fax machine trying to establish a connection. If you still get a busy signal, try calling the owner and letting them know that their fax machine is not accepting incoming calls.
Feb 22, 2010 | Brother IntelliFAX 770 Plain Paper Thermal...
Companies trying to fax to our office tell us that our fax number is "BUSY" but the faxes we receive "failed" and nothing is printed.
Take a cell-phone, and dial the telephone-number that you are giving to your customers. Does it ring? Does the FAX "pick-up" the call?
Or, do you get a "busy" signal?
Nov 13, 2009 | HP Officejet 5610 All-In-One InkJet...
What do I buy to use 2line phone and separate fax?
You can buy a 2 line phone, but to use the fax/dsl line for voice, you will also need a line sharing device.
"The stick" is a good brand....
All it does is recognize if an incoming call is a fax or a voice call. If fax it would go to a fax port on the stick. If voice, it comes out the voice port which you can call on.
The same rules apply to this line....if something is using it, the next call will get busy......But now you could have the phone company "Hunt" your line 1 to line 2 (fax/dsl) if line 1 is busy.......hence...2 incoming lines....
Apr 14, 2009 | RCA 25201RE1 Corded Phone
Setting up fax to send or recieve..just ringing, showing busy no response
Hi! I not computer smart nor am I an expert, but try this. I just got my machine.
put the phone jack into the wall to your printer. Put the paper on top to feeder the paper will come out at the very top
next, dial the number using area code, then press either ok or start
Good Luck, I do hope that works.
If it doesn't call dell supporters, they will walk you through it.
mamalong2000@yahoo.com
Mar 05, 2008 | Brother MFC 240C All-In-One InkJet Printer
Can't receive faxes
Something is causing the fax machine to "trip" to busy. There is some type of short occuring either in the fax machine or the physical phone line itself. Unplug the fax, plug in a regular single line telephone. Call the fax number from another telephone. If the phone rings and you can talk to the other party, the problem is in your fax machine. If the call still is busy, the problem is in your wiring, either in your office or the phone company network.
Feb 01, 2008 | Canon FAXPHONE L80 Laser
HP LaserJet 2840 All-In-One Printer Logo
44 people viewed this question
Ben Johnson
