Question about Samsung Cell Phones
How to erase ''recently dialed numbers''
How do you get the cursor to move to YES to erase...it stays on NO
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 158 Answers
What is your phone model sir/mam? pls try the opposite key, if the no appears on the left, then click the right botton or vice versa
Posted on Feb 19, 2009
Need to reset speed dial numbers but cannot get the cursor to appear.
Dear
Storing One Touch Dial Numbers 1Press Menu, 2, 3, 1. 2Press the One Touch key where you want to store the number. 3Enter a number (up to 20 digits), and then press Set. 4Enter a name (or leave it blank), and then press Set. 5Press Stop/Exit. Storing Speed Dial Numbers 1Press Menu, 2, 3, 2. 2Enter a three-digit (a two-digit for FAX-4100e) Speed Dial number, and then press Set. 3Enter a number (up to 20 digits), and then press Set. 4Enter a name (or leave it blank), and then press Set. 5Press Stop/Exit.
Thanks.
Feb 03, 2015 | Brother IntelliFax-4100e Fax
I need to unlock my zte wireless tracfone after to many pattern attemps but forgot my google account and password
Hey Jesse. I think all u can do now is perform a reset ill tell u how.
Power off the phone.
Press and hold "Vol+", "Menu", and "Power" key until the phone goes to recovery mode.
.Use "Vol+" and "Vol-" to move the cursor up and down.
Move cursor to "wipe data/factory reset", press "Back" key to select it.
Now move cursor down to "Yes - delete all user data" and press "Back" to select it.
. The data will be erased.
The cursor will be on "reboot system now" at the end, so just press "Back" key to reboot the phone normally
But hey all ur data on phone will be erased completely. Try n take off ur SD before doing the reset. If u have 1...:)
Apr 09, 2013 | ZTE Cell Phones
Zte warp phone stuck on android logo
1.Power off the phone.
2.Press and hold "Vol+", "Menu", and "Power" key until the phone goes to recovery mode.
3.Use "Vol+" and "Vol-" to move the cursor up and down.
4.Move cursor to "wipe data/factory reset", press "Back" key to select it.
5.Now move cursor down to "Yes - delete all user data" and press "Back" to select it.
6.The data will be erased.
7.The cursor will be on "reboot system now" at the end, so just press "Back" key to reboot the phone normally.
WARNING: All user data will be completely cleared; the phone will be in a factory reset status.
Jan 23, 2013 | ZTE Warp
How to reset my z990 avil at&t tuch screen phone
You have 2 options to reset the device. One is through the Menu and the other is through the buttons on the device. Press the Menu Key > Settings > Privacy > Factory data reset > Reset phone > Erase everything.
Hard Reset-Power off the phone.
Jan 12, 2013 | ZTE Z990 Avail At&t Black Android Touch...
My zte merit net10 phone keeps rebooting
If your phone rebbots by itself try perfoming the following task1.Power off the phone.
Dec 12, 2012 | ZTE Cell Phones
I need to set up a number on speed dial and delete one.. i have a brother intellifax 4750e
1 Press Menu, 2, 3, 2.
2 Enter a three-digit Speed Dial number, and then press Set.
3 Enter a number (up to 20 digits), and then press Set.
4 Enter a name (or leave it blank), and then press Set.
5 Press Stop/Exit.
Changing One Touch and Speed Dial Numbers
If you try to store a One Touch or Speed Dial number in a location where a
number is already stored, the LCD shows the current name stored at that
location, then prompts you to either
1 Press 1 to change the number, or press 2 to exit without changing it.
2 Enter a new number and then press Set.
If you want to erase the number, press Clear when the cursor is to the left of the
digits.
If you want to change a digit, use left arrow or right arrow to position the cursor under the digit
you want to change, then type over it.
3 Follow the directions beginning at Step 4 for Storing One Touch Numbers or
Storing Speed Dial Numbers.
Feb 28, 2011 | Office Equipment & Supplies
How do I delete speed dial numbers on the Intellifax 2820?
Changing One Touch (For FAX Models Only) and Speed Dial Numbers
If you try to store a One Touch (FAX models only) or Speed Dial number in a
location where a number is already stored, the LCD shows the current name stored there, and then prompts you to either:
1 Press 1 to change the stored number-OR- press 2 to exit without making a change.
2 Enter a new number, and then press Menu/Set.
• If you want to erase the whole number, press Stop/Exit when the cursor
is to the left of the digits. The letters above and to the right of the cursor will be deleted.
• If you want to change a digit, use or to position the cursor under the digit you want to change, and then type over it.
3 Follow the directions beginning at Step 4 in Storing One Touch Numbers
(For FAX Models Only) and Storing Speed Dial Numbers.
Dec 03, 2010 | Brother IntelliFax-2820 Laser Fax
Change name display on Toshiba DKT2020-SD
Press "intercom" button, then #621. Use * to move the cursor all the way to the left. Use the # sign to change from numbers to Alpha. For example: You want "N", but the "M" comes up. Press the "0" to toggle to additional letters on same number key. For a SPACE, use the number 1 and toggle to get a space.
Nov 04, 2009 | Toshiba DKT-2020 Corded Phone
Erasing recent history from "dialed number" display
go to the call register and try erasing them there.
Feb 19, 2009 | Samsung SGH-D900 Cellular Phone
Need help changing the speed dial ID numbers
In order to change #01 to #21 its best just to program the number into #21 slot and then clear the memory for #1.
Start by trying to store a number at a location already used Press Menu/Set, 2 (Fax), 3 (Set Quick-Dial), 2 (Speed-Dial).
Use the dial pad to select the three-digit location (001 – 200) in which you want to erase the number and press Menu/Set.
The screen displays the name or number currently stored there, then prompts you to either 1. CHANGE or 2. EXIT.
Press the Stop/Exit key when the cursor is to the left of the digits. Everything above and to the right of the cursor is deleted.
Hit he menu/set key.
This should save the speed dial number as a blank.
Apr 29, 2008 | Brother IntelliFax-2820 Laser Fax
Cell Phones Logo
26 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
