Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Ice and water dispensers not working
Both dispensers stopped working within 2mos of each other.
I have a sice by side by side model # GC5SHGXLS00 . Repair man says I need to replace whole door--is their any other way?
  • Anonymous Mar 19, 2009
    the ice maker makes ice, but the dispenser does not work the product is a whirlpool gold GD5SHAXKT02
  • 3 Answers
I don't think that you need to replace the hole door unless something is physically wrong with it. Could be a lot of things one is the limit switch (number 14)->
http://www.us1internet.com/GC5SHGXLS00_66388.htm
if for some reason the limit switch is not working properly then the paddle never send the signal to the valve to dispense. The same thing is for the auger motor (the one that dispense Ice).
If you see your dispenser under the paddles and activate the paddles you can see when the paddle touches the limit switch. You should hear a click. Also could be the switch pack (#18 in the drawing) that is short circuited. But this is most complicated to resolve, not impossible, but you need the schematics of the switch pack to check continuity, if you don't know a electrical technician can do the job. Also he can check the harness to check for continuity. The harness inside the door send the signal to the board to actuate the valve or to move the auger motor that send the ice.
Maybe the repair man tought that you need to remove the door because for example... LG foam the harness inside the door but Whirlpool use a conduit in the foaming process and when the door is already foamed they put the harness inside the conduit that is why you don't need to remove the door.
Also could be the valve... your ice maker is making ice?
Posted on Feb 20, 2009
Water dispenser is not working. Ice dispenser is working
If your model is the PSS25MGMWW and the water dispenser is not workingthe problem is most likely the=> WR57X10026 Water Inlet Valve Most times the ice dispenser and water to the ice maker will continue to work properly while the half of the water control valve will fail and stop water to the dispenser or ice maker. Follow the instructions in the video and I will be here if you have questions, Thanks Sea Breeze
Sep 12, 2013 | GE Profile Arctica 25.4 Cubic Feet...
Water is leaking from our water dispenser. A large amount. An 8 oz cup fills up within an hour. It is coming from the water dispenser on the outside of the fridge. The ice maker is working fine but the...
Your water valve on the back of the refrigerator is plugged up, there are two sides to it, one side is for ice maker the other is for chilled water dispenser.You may be able to clean it out, if not then you will have to buy a new valve.Hope this helped.
May 29, 2011 | Kenmore Refrigerators
Ice maker works but water dispenser stopped working
There sould be a set of water control valves on rear of refrigerator and where the water comes into refrigerator dispenser and ice maker. When one goes bad you replace both. You can test the windings in each coil or test for voltage while someone presses dispense water.I will ty to locate one set with your model number. Sea Breeze
Mar 20, 2010 | Refrigerators
I have a whirlpool side by side refridgerator about a year or more ago the water dispenser stopped working and now the ice cube dispenser also stopped working it is no longer making ice into the container....
Your water line into the refrigerator is probably plugged up. First, check at the cut-off valve where the house water connects to the refrigerator water line. Mineral deposits often form in these small valves and can block the water flow.
The other possibility is a blocked water line within the refrigerator. Plastic weedeater line works very well to clean out these lines.
Oct 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Apr 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
167 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
