Question about Pioneer AVIC-80DVD Car DVD Player
Pioneer AVH P6500DVD/AVIC 80DVD Installed.Pink Purple Green Wire?
I have the Pioneer AVH P6500DVD/AVIC 80DVD installed but the Nav is not working. I dont have the manual. What does the Pink, Puple and Green wires do coming out of the actual Nav unit do? They might be the parking brake, one the reverse lights, one the speed sensor, one might even be ABS or something. Please help.
Also the black plastic cage seems to be stuck down where the cd/dvd's go in.. How do I fix this and why does this happen? it wont take any discs in. Thanks
    Scholar:
  • 64 Answers
Can you take the black cage off or maybe you can take a screw driver and bend it back up
Hope this helps
install manual
owners manual
Posted on Feb 19, 2009
Wat wire do i hook up to b able to view my movies on my pioneer avh p6500dvd
the green wire is the e brake cable if you ground this wire you can bypass the need for the e brake keep in mind that because of the type of deck you have you will need to install a switch and you will have to switch ths on and off everytime you turn into or awayfrom acc
Aug 24, 2010 | Pioneer AVH-P6500DVD Car DVD Player
Pioneer AVH P6500DVD Tuner Failed
sounds like the antena plug on the back of the unit came out pull out an check
Jul 15, 2010 | Pioneer AVH-P6500DVD Car DVD Player
Pink wire whats it for, it on a pioneer avic-d2
The brake sensor wire (Lt Green) can be simulated with a toggle switch to ground.
Pink (CAR SPEED SIGNAL INPUT)
The mobile navigation system is connected here to detect the distance
the vehicle travels. Always connect the vehicle’s speed detection
circuit or the ND-PG1 speed pulse generator, sold separately. Failure
to make this connection will increase errors in the location display.
Orange/white
To lighting switch terminal
Light green
Used to detect the ON/OFF status of the parking brake. This lead
must be connected to the power supply side of the parking brake
switch. If this connection is made incorrectly or omitted, certain
functions of your navigation system will be unusable.
Violet/white
(REVERSEGEAR SIGNAL INPUT)
This is connected so that the navigation system can
detect whether the vehicle is moving forwards or
backwards. Connect the violet/white lead to the
lead whose voltage changes when the shift lever is
put in reverse. Unless connected, the sensor may
not detect your vehicle traveling forward/backward
properly, and thus the position of your vehicle
detected by the sensor may be misaligned from the
actual position.
Note: When you use the ND-PG1 speed pulse
generator (sold separately), please make sure
to connect this lead.
When you use a rear view camera, please make
sure to connect this lead. Otherwise you cannot
switch to rear view camera picture.
Further detail can be found here:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/130/130AVICD2.PDF
Feb 23, 2010 | Pioneer AVIC-D2 DVD Nav/6.5"...
Problem wirings for Pioneer AVH-P6500DVD Car DVD Player
very easy fix. you can pay thirty bucks on ebay and buy the bypass kit or make it yourself. but the light green wire on the harness has to be hooked up to ground. just hook the light green wire to the chassie of the car and you will be able to see dvds all the time. If you want to buy the kit its not really needed I have a toggle switch on mine just for turning it on and off when I am driving. simple as putting a wire from your chassie of the car(Ground) and then the other from the unit(light green wire) to a switch. hooking it up from Supply to Acc on the switch.
Mar 17, 2009 | Pioneer AVH-P6500DVD Car DVD Player
Car/audio AVH-P6500DVD pioneer
I also need to know where i can get an installation manual.
And don't believe that there is not one anywere on the net.
Mshanev
Apr 04, 2008 | Pioneer AVH-P6500DVD Car DVD Player
Installation
are you experienced in installing car stereos at all? these decks are not the easiest to install. Best bet would be to try to find an installation manual....there would be way too much instruction to put on here.
If you have any specific questions feel free to ask.
Mar 29, 2008 | Pioneer AVH-P6500DVD Car DVD Player
How do you connect a pioneer d2 navigation system to a 2006 ford expedition entertainment system
You need to identify the four wires that carry the DVD audio in the factory plug, and re-wire them to RCA plugs that can be used with the Auxiliary input RCA jacks on your Pioneer unit. The four wires should be: Left (+) light green Left (-) white Right (+) red Right (-) black The easiest way is to purchase some inexpensive RCA cables (or better yet, speaker wire with RCA ends). Cut the cables and wire the center pin conductor wires to the (+) audio wires in the stock plugs, and connect the outer shield conductors to the (-) wires. Then connect the RCA plugs to your head unit's auxiliary input jacks.
Aug 08, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
Pioneer AVIC-80DVD Car DVD Player Logo
892 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
