Question about Dell Latitude D600 Notebook
Dell latitude D600 CPU issue
I have a 1.89ghz intel pentium M 750 cpu chip in my laptop, and it will not read more than 1.40 top speed. I ran the intel ID utility and expected is 1.89ghz but it only registers 1.40ghz. The expected system bus was 533 but reported was only 400mhz. I have the latest bios for the mother board so it is not that. It is not the CPU because I pulled it out and put it in another laptop of mine and BANG it reads at 1.89ghz. Can anybody give me an idea of why the latitude is not reading the full speed? Oh and FYI, I had a 1.8ghz pentium M in the lap top before hand and it also ran at only 1.4ghz.
  • keivnflannag Feb 19, 2009
    Ooopsie lol sry, I put down 1.89ghz and it is actually 1.86ghz, so sorry bout that. lol
  • keivnflannag Feb 21, 2009
    Speed step is installed and running, it keeps the cpu peaked out at 1.39ghz but the cpu is rated at 1.86ghz. I will try the Fn key at start up and see what happens.
  • 202 Answers
Is Speedstep installed? This is a utility that adjust the clocking of the CPU. If it is not installed, you can download it from the Dell support site. After you install it, run it and set it to max performance when plugged in to AC power. The stepdown for battery use will slow the CPU to aboout half, but extend the battery life.
Also try running diagnostics to see if there is an error. Hold the Fn key down when you start the laptop. It will test the system and alert you to any errors.
Good luck and let me know how it turns out.
Posted on Feb 20, 2009
WHAT IS MAX CPU SUPORT OF P4M800-M7A ( above 2.6GH )
Select the "Start Menu."
Click to select "Control Panel." This will open a new window with several clickable options.
Choose "System and Maintenance," typically located near the top left-hand corner of the Control Panel
Click to select "System" from the new list of options
Look for the CPU's stock speed as indicated under the "Processor" heading. This is a ballpark, relatively close estimate of your computer's CPU speed, as provided by the manufacturer.
Checking the Stock CPU Speed in Windows XP
Click the "Start Menu.
Right-click on "My Computer."
Select "Properties." By default the Properties window will usually be set to the "General" tab, but if the window is set to a different tab you'll need to click on the "General" tab located near the top of the window.
Check the CPU rating as listed underneath the "Computer" heading.
Determining Real-Time CPU Speed
Go to CPU Speed Professional's website (see Resources) and download "CPU Speed Professional."
While other free CPU clocks exist, many are beta programs with glitches and unwanted bugs. CPU Speed Professional is well-known and reputable, receiving the "Vista 5 Star Software Award" according to its website.
Install the recently downloaded
" http://download.cnet.com/cpu-speed-professional/3000-2086_4-10833139.html "
file by double-clicking on it and following on-screen prompts to complete the automated install procedure.
Open CPU Speed Professional.
Click "Test Your Speed" on the main program interface.
A real-time, active measurement of your CPU speed will appear numerically, and CPU Speed Professional will also display your CPU speed on a stylish meter for easy visual comprehension.
hope this helps
Oct 10, 2012 | Biostar P4M800-M7A Motherboard
Hi,I have a Dell Latitude D600 which the temp are always at 85.5C(mobmeter,ig8kfan). The fan was running high all the time n the speed is just 600mhz instead of 1400mhz whatever i do.(Prime95,Dell Xp...
don't worry most laptops nowadays run hot. your CPU will shut itself down long before damage occurs. try elevating your laptop to promote air circulation or place it on a cooling mat.
Be careful if you set it on your lap, some people have had minor burns from laptops setting on their laps for prolonged periods.
Jan 04, 2011 | Dell Latitude D600 (D6005C) PC Notebook
Latitude D600 PC Notebook: Installed new RAM 1G on Dell Lat600,Now CPU is run...
It is not the memory causing the issue. You either have a clogged fan and heat sink or a bad fan. This will solve most heat issues with the laptop.http://www.diefer.de/i8kfan/faq.html
Install this software and put the fan on manual high. That should help a lot if the fan is still working.
May 18, 2010 | Dell Latitude D600 Notebook
Cpu not running at stated speed Dell d600 Latitude
Power saving methods include dynamically variable clock frequency and core voltage, allowing the Pentium M to throttle clock speed in order to conserve energy, using the SpeedStep 3 technology. for the battery ....http://www.daileyint.com/hmdpc/battery.htm
Mar 11, 2010 | Dell Latitude D600 Notebook
Dell Latitude 1.6 GHz/512/40GB-processor speed seems to be stuck at 221 mhz regardless of what app I am running. Is there a way to adjust the speed of the processor? Or is the processor bad?
The processor is throttled by a process called speed step. This slows the CPU to save power. The same process is used when the processor overheats, and the system throttles to manage the heat production.
So the heatsink and cooling fan should be replaced as the first step in trying to resolve the process.
Jan 11, 2010 | Dell Latitude D600: Pentium M 1.6GHz,...
I have Dell Latitude D600 orginal with BIOS A16 and Intel(R) Pentium(R) M processor 1500MHz,Banias,Socket 479 mPGA,my question is --- can I replace with :Intel Pentium M 760,Intel(R) Pentium(R) M processor...
For information for your D600 model use this link to the Dell WEB site.
http://support.dell.com/support/edocs/systems/latd600/en/index.htm
The service manual listed these CPUs.
The recommended processors for the D600 are :-
Processors
7U338
1.3 GHz CPU
7R414
1.4 GHz CPU
6R637
1.5 GHz CPU
4R867
1.6 GHz CPU
4W884
1.7 GHz CPU
Jul 24, 2009 | Dell Latitude D600 Notebook
Power for battery on DELL laptop Latitude D610 as posted FixYa
In the BIOS, does it show the battery and it's current state? As weird as it sounds, I've fixed an issue like this on a D600 by updating the BIOS to the most current level. Weird, but true.
Dec 22, 2008 | Dell Latitude D610 Laptop Computer -...
Processor upgrade
Hi ryonsdad,
I checked out the Latitude D610 laptop, and you'll be glad to know that you have the following processor upgrade options:
1.) Pentium M 780 Processor - 2.26 GHz, 2MB, 780, Pentium-M Dothan, 533FSB (fastest upgrade)
2.) Pentium M 770 Processor - 2.13 GHz, 2MB, 770, Pentium-M Dothan, 533FSB
3.) Pentium M 760 Processor - 2.0 GHz, 2MB, 760, Pentium-M Dothan, 533FSB
4.) Pentium M 750 Processor - 1.86 GHz, 2MB, 750, Pentium-M Dothan, 533FSB
5.) Pentium M 740 Processor - 1.73 GHz, 2MB, 740, Pentium-M Dothan, 533FSB (slowest upgrade)
You can buy these processors from Dell Spareparts or otherwise from a 3rd party store.
Hope this helps!
Peace! :)
Oct 20, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
365 people viewed this question
Alun Cox
