Question about Samsung SCX 4521F All-In-One Laser Printer
I bought a Samsung SCX-4826FN and it cannot be used to send faxes because I have DSL internet. Is it true that it works only on analog lines?
    Genius:
  • 2,120 Answers
That's true. ALL fax systems are ANALOG devices.
Posted on Feb 20, 2009
8860 wont send or recieve fax on cable modem
Fax machines usually only work over regular phone lines, not through digital cable or DSL systems. If your phone is a VOIP phone, it is a digital system and your fax will not work. It needs to be plugged into the Plain Old Telephone System (POTS) which is an analog system.
May 05, 2012 | Xerox Office Equipment & Supplies
Can i use a samsung scx-4216f to send a fax through dsl internet connection but no land line?
Depends on how much trouble you want.
The software should be able to use an internet fax service, but it might be limited to a service provided by Samsung.
You can always use a scanner to scan the page that you are trying to fax, and then print it as a fax port which is setup for an internet fax service.
Jun 13, 2010 | Samsung Office Equipment & Supplies
We have a SCX 4826FN and we can not receive faxes currently...we can send them but not receive the line just rings and no fax comes thru
its may be the problem related to Toner Exhaust, Internel Memory is full ........... so try to check after clear the memory from Tech Mode
Menu#1934 select clear memory from the list.
after that this preset pls. change the cartrige unit or Purchase the Catridge Refill Soltuion.
Feb 24, 2010 | Samsung SCX-4828FN All-In-One Laser...
I cant seem to send a fax on my dsl line I have a hp640
DSL is DIGITAL. All fax machines are ANALOG. It won't work reliably.
Jan 07, 2010 | HP 640 Inkjet Fax Machine
Ever since i brought my HP 1040 fax machine i can
it may possible that you have a DSL conn. for internet & phone line.
In DSL conn. we need a DSL filter to be fitted in ur DSL line,so that you can get a analog line for fax/voice calls.
And if you have a VOIP conn. then plz contact HP technical support.
Nov 20, 2009 | HP 1040 Plain Paper Inkjet Fax
Having trouble connecting samsung clx-3175fn multi function printer to home phone and dsl to enable me to send and receive faxes
Make sure you attach a dsl filter to the Samsung. Should look like this: Samsung/filter/phone line. Should be installed like this: filter to Samsung bottom phone jack, phone line to filter. Attach the home phone to the upper extension jack from the Samsung.
Nov 27, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Invalid number
Fax machines do not work well or at all on digital lines. They are designed for analog lines, like the standard phone company line. You may have to install a dedicated fax line from your tel. company.
Jun 11, 2008 | Samsung SCX-4216F All-In-One Laser Printer
When try to fax, the papers go through the scan but it would not send .the model is all-in-one scx-4216f
Check the phone line to the printer. Make sure you are connected to the line and not the auxillary phone. If you have DSL internet, be sure you have a filter on the fax. If you get a specific message, let me know.
Jun 11, 2008 | Samsung Office Equipment & Supplies
Lexmark X73
Sending a fax by DSL requires one of two methods: 1. You obtain a DSL line filter suitable for connecting a standard voice telephone to the DSL line, then connect an analog fax modem to the line through the line filter. 2. You hire an Internet E-faxing service. See · http://www.slipstick.com/addins/services/fax.htm#internetfax · http://www.slipstick.com/addins/services/fax.htm · http://www.savetz.com/fax Tim
Jan 30, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Samsung SCX 4521F All-In-One Laser Printer Logo
135 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
