Question about Brother DCP-8065DN Black and White Copier
Keeps saying no paper in tray although paper is in tray
Although the paper tray has paper in it, screen keeps saying no paper.
We have taken paper out and put in fresh new paper, but it still does not
work. Copier will work if paper is manually fed, but not if we try to
use the paper tray.
  • dwood340 Feb 27, 2009
    Thanks, I sort of thought that because we can only put in a
    few pieces of paper in the paper tray at a time!
  • Anonymous Mar 12, 2014
    I have taken off the back panel and can see nothing that can be stopping it from working unless there is a sensor that is blocked somehow
  • 37 Answers
I encounter that problem before, after I checked the sensors, feed unit and mechanism nothing is wrong or broken but still NO PAPER indicates on the display .I only noticed with the machine is the cassette tray or the paper tray, when you try to pullout the cassette tray and look at its left side, there is missing parts on it. There is a spring and actuator on it that will engage on the feed unit drive. Try to find the same machine and look at the cassette tray to see the missing parts on it. You can buy a new cassette because the parts that is missing maybe not available.
Posted on Feb 27, 2009
Mfc 7860dw will not print from paper tray
Check the paper level in tray 1 and keep the paper within the levels indicated by the arrows on the side. I had this same problem, and although the paper tray accommodates the extra paper, the printer obviously does not like it and defaults to the manual feed.
Mar 08, 2012 | Office Equipment & Supplies
HP LJ 2420 wont pickup paper from tray 2
Replace try2 paper pick up roller..
Dec 01, 2011 | HP LaserJet 2420 Printer
Paper alarm; printer keeps printing same job
remove all supply and then plug then attach data cable, uninstall printer driver and install again
Jun 18, 2009 | Canon MF8180C Color Laser MFC Printer
Paper jam
check paper jam error you need do:
1) between paper input tray and cartridge check any pieces paper
2) between cartridge and fuser area do same thing
3) check fuser and pressure roller(near fuser) any pieces of paper there
4) after fuser to output tray
all above step checking for avoid any pieces paper obstruct any sensor through all paper road, so that cause jam error
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 25, 2009 | Brother MFC 8500 All-In-One Laser Printer
When asking to print keeps saying load MP feeder cardstock A4 although computer set up to print from tray 1?
depends on the printer, normal home use printer have only 1 tray.
office printer usually have multiple trys. and usually the default for that is tray 2. tray 1 is manual feed.
May 14, 2009 | Office Equipment & Supplies
Error message keeps appearing "paper jam in tray 2" although there is definitely no paper jam.
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it.
May 02, 2009 | HP LaserJet 2300dn Printer
Sharp FO 6700 Plain Paper Laser Fax
No there is no configuration page. The red blinking light means you have no paper under your blue tray or the paper empty sensor is broke. To identify the noise open the lid then close it, if you hear the noise while the fax is warming up then most likely you have a bad gear that meshes with the fuser drive gear, although it could also be the toner or drum. If it's not the toner or drum I stongly recommend a service technician , he should be able to provide an exit tray.
Oct 05, 2008 | Sharp FO 6700 Plain Paper Laser Fax
Paper Coming from wrong tray for incoming faxes
press setup on printer select preferences and select default tray as 2 and try making copy and also check while receiving fax and also follow this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01096354&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Oct 01, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
Brother DCP-8065DN Black and White Copier Logo
443 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
