Question about Anvil 246 Watts MIX7110 Stand Mixer
Anvil Mixer 7110 is losing torque. this is a five speed mixer with electronic controller....great mixer but is now losing torque to the mixer shaft....any help? Where can I get a repair manual or parts.
  • 9 Answers
SOURCE: mixer speed settings
It could be the phase control, or it could be that the governor assembly or associated spring is missing or malfunctioning.
Posted on Mar 25, 2008
SOURCE: Blakeslee (Kenwood) A717 mixer speed control
I had the same problem. Had to strip the machine down to get to the motor. On the top is a moving plate with various capacitors etc mounted. On the front side there was a Capacitor (At least I think it was) with the wire broken.
I resoldered it and the machine now works fine.
I hope this helps
Posted on Jul 05, 2008
SOURCE: Kitchenaid K5A mixer 10 speed only runs on fast, no slow speed
Pull the back off and there will be two screws at the top of the Speed Control Plate and a 3rd screw at the bottom. Tighten the top two screws down. bakerboy49203@yahoo.com. Let me know if it works.
Posted on Mar 21, 2009
ricardok45
  • 135 Answers
SOURCE: I suspect my D300T Hobart Mixer has a broken shaft
Hi. Go to hobartservice.com, register for free. This will allow you access to the parts files for your D300T mixer. Download them. When you begin your disassembly, take a photo of every piece that you remove, lay these pieces on a piece of cardboard or something suitable in the order that they were removed. This will help you greatly with your project. Good luck! ricardok45
Posted on May 21, 2009
  • 81 Answers
SOURCE: I need a trasmission parts for an Anvil 20qt dough
Stove Parts Supply in Ft. Worth Texas
Posted on Jul 29, 2009
Kitchenaid mixer works intermentily
How old is the mixer? If older, check for possible short in cord either at plug end or at mixer body. Best to disassemble and test cord with VOM meter. Often cord and break internally and show open circuit only when cord bent a an angle.
Next< i would look at the speed mixing switch, the mechanical part, not the electronic board, for defect such as dirty contacts.
If above do not work, then check motor brushes. And, only then I would suspect electronic controller.
Please psot Mixer model and serial number rfor further assistance
j
Nov 29, 2013 | Food Mixers
Tip
Great place 4 parts
If u need parts, mixer,slicer parts for Hobart, Anvil, Berkel and more u may want to give (www.onesharpstore.com) a try. Great pepole to deal with
Harry Oooooooooo
on Mar 10, 2009 | Hobart A200 Stand Mixer
HOW TO TEST A PHASE CONTROL BOARD ON KITCHENAID MIXER
I am sorry to say but only with a new one, about 30 bucks and five minutes of work, but if your mixer has any speeds working except only high (only high means it is the phase control board) then it is more likely the speed control board is bad rather than the phase board. Can you send is more info on what happened when the mixer started or stopped working. We can be of more help with more info
Oct 18, 2012 | KitchenAid K45SS Classic Stand Mixer
Anvil 9130 mixer grease
where do I find motor for this mixer
Feb 24, 2010 | Anvil 373 Watts MIX9120 Stand Mixer
How do you remove the top of a Anvil 20 qt mixer
To the best of my knowledge that is a reduction drive / direct motor connection mixer. No belts just bearings and gears. It has been far too long and I honestly can not tell you how to remove the cover. I do remember that were screws under the chassis of the motor / gear section. Real bad case of long time no do... here. You might have to remove the drive head to access the top cover screws. Wish I could have been more of a help. Just in this case it is one of those it needs to be in front of me things.
Jan 13, 2010 | Food Mixers
The mixer is a 300 watt model, it was used for too heavy of a load and stripped the plastic gear. I replaced the gear and reassembled the mixer but now it won't run at low speeds. It sounds fine at the...
Hi GERALD. You don’t provide your model number so I can only provide a ‘generic’ solution to your problem.
More than likely when you inadvertently stripped the plastic (worm) gear the speed control assembly was also damaged electronically. That’s why you get the higher speeds but not the lower speeds.
I’ll assume you already have your mixer’s Parts List manual on-hand. If you're lacking one, you can download it from the KA website http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number and select a file under Parts List (and then check to see it this matches your mixer model).
Turn to pages titled "Motor And Control Parts", which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. You’ll want to focus on "Control Plate Assembly."
First inspect around the control plate assembly to ensure all the wire connections are OK. It's possible a connection has come loose during the reassembly from your first repair. Unfortunately the whole controller assembly is fabricated on a little PC board which was not meant to be 'home fixed', and my 'expertise' ends there. A local small appliance repair shop should be able to determine if the controller assembly is functioning properly or not, or you can just order replacement parts without the testing.
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. You should be search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer that are good to have in your ‘toolbox’.
I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Dec 18, 2009 | KitchenAid 32685 Mixer
Hobart HL600 Legacy mixer will run on stir speed only.
check to see if magnet on bowl guard is still in place, it is on the right side.
Nov 14, 2008 | Hobart HL600 Legacy Stand Mixer
MIX7130
ship it back to anvil , buy a hobart ,best mixers in the world
May 19, 2008 | Anvil MIX7130 Stand Mixer
Our mixer will not come on
When your guard is closed the safety switch opens.You need to remove the guard and make sure the safety switch is not full of flour.
Oct 29, 2007 | Anvil MIX7130 Stand Mixer
Anvil 246 Watts MIX7110 Stand Mixer Logo
124 people viewed this question
Top Anvil Food Mixers Experts
Oscar Netto
Oscar Netto
Are you an Anvil Food Mixer Expert? Answer questions, earn points and help others
