Question about GE Profile PSS26NGS Side by Side Refrigerator
Automatic ice maker will not dipense ice cubes.
I have cleaned out the ice and the dipenser will not work. It simply buzzes as if it is stuck and not turn. I can turn it by hand.
  • rwstech Mar 19, 2009
    sometimes ice will come out but always is crushed ice not cubes, does not matter what the setting is at panel. also when depressed it seems as though fridge loses strengh.
This may be a circuit board problem for which there might be a recall from GE. I had the same problem and found information about it on the web site below.
Posted on May 30, 2009
Ice maker not working. appears no water coming in. water dipenser is working fine in frige.
Pour tap water into the ice tray if empty of cubes. Let freeze and if cubes drop then the dual water control on back of the refrigerator is most likely the problem. Click Here=> Rear of JFC2087HRP you will see part 10 in photo, that is your dual water control valve OEM Part=> 67005154
It can be bad only on ice maker side. Let me know about the ice test so we can determine which part is the problem. If you have more questions please let me know, Thanks Sea Breeze
1ec4065.jpgSea Breeze
Oct 13, 2010 | Jenn-Air JFC2087HRP Side by Side...
Ice maker will not produce ice, no water flowing to dipenser.
Sounds like the water filter is plugged up...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
Jul 11, 2010 | Whirlpool Refrigerators
Ice maker will not dipense ice
Hello, Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If these wire is in the raised position, the ice maker is turn off.On some unit you simply lowered the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in proper position, check the freezer temperature, it should be between 0-8 degrees Fahrenheit.If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seal and thermostat, repair/replace as necessary.
Jun 21, 2010 | Frigidaire FRS3R5EMB Side by Side...
Ice maker doesnt produce ice
ice maker or water valve
Mar 30, 2009 | Hotpoint HSM25GFRSA
Ice cube button is lite but the only dipenses crushed ice
We have had this problem on occasion. The lever up in the ice dispencer gets jammed with frost and ice. If you remove the ice bucket/auger and let it thaw or just rinse it with water and dry it. Give it a try. -Matt
Mar 13, 2009 | Frigidaire FRS26R4A Side by Side...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Water/ice dipenser
Sorry, these become dirty after a period of time. Try spraying up with soap and water, clean as best you can, let dry. And then spray with a canned lubricant. Silicone type, (as opposed to WD-40 type) may work best. But OK to try either.
Feb 07, 2008 | Maytag MZD2766GES Side by Side...
ICE MAKER and Water Dispenser
very likely a partially clogged filter, but not sure why no light.
Jun 13, 2007 | Amana ARS2661B Side by Side Refrigerator
GE Profile PSS26NGS Side by Side Refrigerator Logo
407 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
