Looking for battery cover or box for large hasbro butterscotch pony # 7647106
Ok you can buy spare parts. The UK details are here.
FAQ Manuals and Spare Parts
USA Hasbro Online Customer Service Hasbro
SOURCE: I need a battery compartment for butterscotch fur
i need the same part so if u no any where plz email me [email protected] plz am in need off the battery conpartment x
SOURCE: computer novice--hasbro battery
Once you backout the retaining screw, put your fingers in the gap between the battery compartment and the switch. Push the battery compartment to the rear of the pony then you can remove it.
SOURCE: Looking to repair the tail on Butterscotch pony
Had the same problem and the fix is easy. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of CLEAR plastic tubing with 3/16" inner diameter and 5/16" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the holes. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. You will probably need to twist the tube gently while applying firm pressure on it to make it slide over the stub. The end of the tube with the holes should be about even with the outside top of the white plastic hole and the tube holes should be level, looking at it from side to side. This makes the alignment of the screw hole to the tail correct. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully twist and remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right if you cut it too short! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
