Question about Sony PCV-RZ40C PC Desktop
PCVRZ40C won't recognize the recovery DVD's
Can boot from the recovery DVD up to the point it says Press any key to boot from DVD, then it just goes blank.
  • Frank  Fernandez
    Frank Fernandez May 11, 2010
    How long did you wait after the screen went blank?
  • 43 Answers
The reason when you boot from DVD, then it just goes blank is because it is unbootable or corrupt
you might want to try a diffrent recovery dvd disc
Posted on Feb 23, 2009
I have a eMachine t5246. My hard drive went bad, very bad, couldn't get it to even get wiped out so. my eMachine disc won't start up. It is the operating disc but every time it says install and...
If the hard drive failed you will first need to replace it with a working hard drive. One that is done, power on the computer with the recovery disc is the drive and enter setup. It should say something like press F9 or F10 for Setup. Look through the menus for "Boot Order", make sure your CD/DVD drive is above hard drive. Save the changes and reboot, you should get a message "Press any key to boot to disc" or something similar, do so, and follow the prompts to re-install windows.
Jul 07, 2013 | Computers & Internet
Computer won't boot stuck in Error RecoveryScreen won't go any further
You should be able to do a clean install of Windows. Just insert the installation disc and press any key when indicated. Optical drive needs to be the first boot option. Go into BIOS and change it is not.
As for disc, you have to use the same Windows version as indicated on the MS Product Key sticker, because of the serial number.
May 24, 2013 | Toshiba NB205-N210 Netbook
Unmountable boot disk error on blue screen
first, recover your files. You will need to use some data recovery program like asoftech data recovery. you can download it from
http://www.softpedia.com/get/System/Back-Up-and-Recovery/Asoftech-Data-Recovery.shtml
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Sep 07, 2011 | Gateway Computers & Internet
System error
I'd recommend that you use some data recovery program
Sep 06, 2011 | Computers & Internet
Solutions for "HP Pavilion dv5
File: \BOOT\BCD Status: 0xc000000F Info: An error occurred while attempting to read the boot configuration data. First try going into Windows safe mode with command line utility enabled. (F8 on bootup). In command console typechkdsk /f /r and enter Y for yes at the prompt. Wait for it to finish, it may take a while and then test the issue. If the problem persists, please continue with the following instructions. Rebuild BCD 1. Put the Windows Vista installation disc in the disc drive, and then start the computer. 2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears. 3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next. 4. Click Repair your computer. 5. (Click the operating system that you want to repair), and then click Next. 6. In the System Recovery Options dialog box, click Command Prompt. 7. Type BOOTREC /FIXMBR, and then press ENTER. 8. Type BOOTREC /FIXBOOT, and then press ENTER. 9. Type BOOTREC /REBUILDBCD, and then press ENTER. Use the Windows Recovery Environment (WinRE) to run System Restore 1. Insert the Windows Vista installation disc into the disc drive, and then start the computer. 2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears. 3. Select a language, a time and currency, and a keyboard or input method, and then click Next. 4. Click Repair your computer. 5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next 6. At the System Recovery Options Dialog Box, click on System Restore. 7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point. 8. Click Finish to restore the system. Startup Repair from the Windows Recovery Environment (WinRE) 1. Insert the Windows Vista installation disc into the disc drive, and then start the computer. 2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears. 3. Select a language, a time and currency, and a keyboard or input method, and then click Next. 4. Click Repair your computer. 5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next. 6. At the System Recovery Options Dialog Box, click on Repair your computer. 7. (Click the operating system that you want to repair), and then click Next. 8. In the System Recovery Options dialog box, click Startup Repair
finaly if you do not have the cd you can use a copy too.
Kronoguy
Jul 04, 2011 | Computers & Internet
Toshiba satellite L300 will not boot up. error code 0xc00000e9
What you can do is attempt to repair the system using System Restore or startup repair. I would suggest trying startup repair first.
Method 1: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Insert the Windows Vista or Windows 7 installation disc into the disc drive, and then start the computer.
Method 2: Startup Repair from the Windows Recovery Environment (WinRE)
8. In the System Recovery Options dialog box, click Startup Repair.
Hope this helps
Ray
Mar 07, 2011 | Computers & Internet
What to do if bootmanager fails?
hi frenofurs05,
Thank you for the post.
I suggest trying the following methods to troubleshoot the issue:
Method 1: Startup Repair from the Windows Recovery Environment (WinRE)
7. Click the operating system that you want to repair, and then click Next.
Method 2: Rebuild BCD
5. Click the operating system that you want to repair, and then click Next.
7. Type Bootrec /RebuildBcd , and then press ENTER.
Method 3: Use the Windows Recovery Environment (WinRE) to run System Restore ============================================
Note:I just pasted this answer from other person cause its very long when i will wrote it and i think the better one than my explanation.
regards,
mastergani
Jan 03, 2011 | Toshiba Satellite L500 Series Notebook
My acer aspire am5100 desktop needs a recovery to wipe the hard drive. I have the discs, but when they are placed in the drive, the system doesn't recognize them and starts up normally. It basically...
With the first recovery disc in in the drive, and starting from a powered off machine, press the power button and then press quickly and repeatedly on the F12 key. The boot menu should appear. When it does, make sure that CD/DVD/Optical whatever drive is highlighted. If it's not, use the up and down arrow keys on your keyboard to highlight it. When it's highlighted, hit the enter key.
The second you see a white message on a black screen that says...."Press any key to boot from CD" hit a key and begin to follow all the prompts.
You should be ok after that.
Regards,
Selk
Nov 19, 2010 | Acer Aspire M5100 AM5100-U5313A AMD...
HOW TO USE EMACHINES RECOVERY DISCS
Turn your computer on.
When you see "Press <BLAH> to enter BIOS SETUP mode", press the <BLAH> key.
Change the "boot-order" to select your CD/DVD drive as the "first" boot device.
Put the first recovery-disk into your CD/DVD drive.
Save-and-exit from BIOS SETUP.
Your computer will "boot" from the media in the CD/DVD drive, and thus will start the "recovery" process.
Apr 10, 2010 | E-Machines eMachines Monitor E15T4
Black screen on laptop, will not boot in safe or normal. no back up disk, tried f11 sys recov did not work
2. Press a key when the message indicating "Press any key to boot from CD or DVD …". appears.
May 15, 2009 | Compaq Armada E500 Notebook
Sony PCV-RZ40C PC Desktop Logo
61 people viewed this question
Top Sony Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
