Question about Maytag Atlantis MDE7400AY Electric Dryer
Dryer runs but no heat. gas dryer (maytag) - Maytag Atlantis MDE7400AY Electric Dryer
  • 1 more comment
  • matthew_a952 Feb 28, 2009
    The dryer was working fine but made a lot of noise now its still running and i have no heat at all.
  • never_br0ken May 05, 2009
    yes it is the ignitor but how do i get to te old one??
  • never_br0ken May 06, 2009
    i thiught it was the ignitor but now i think it might be thermostat, it runs but dont get hot???
    Problem Solver:
  • 10 Answers
Check the ignitor. depending on the model can be from $25- $90.00 This is what heats up when you start the dryer. like a pilot light on a water heater, only it doesn't stay on all the time.
Posted on Feb 19, 2009
My Maytag Gas Dryer runs and starts to heat, but cools off. It takes a long time to dry. Model #MDG2600BWW What could be wrong?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101./,,./
Jul 22, 2011 | Maytag MDG2600BWW Gas Dryer
My Maytag gas dryer is running but not heating. The "manual" says to check circut or fuse. Is there a fuse in the dryer and if so where would I find it? Any other thoughts on why this is not...
heatman101//''/
Feb 13, 2011 | Maytag PYE4500AY Gas Dryer
My Maytag Neptune dryer model mdg5500aww has no heat when running . ignitor never gets red. there's gas to the unit and 110 volts. there really not much lint in there. is the problem the flame sensor?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 15, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag DE7600 runs but will not heat
heatman101
Nov 21, 2010 | Maytag Dryers
I have a Maytag PYG4500AWQ that does run but does not heat up? How can this be fixed?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 07, 2010 | Maytag PYG4500A Gas Dryer
Maytag neptune dryer will run, no heat I think the heating element is out, how do I replace it. Model MD5500
heatman101
Sep 12, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer model #MDG308Dawn heat not coming out of dryer dryer motor running but clothes are not drying can't feel the heat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 08, 2010 | Maytag Dryers
Maytag MDE6657BYW RUNS BUT NO HEAT
heatman101
Aug 14, 2010 | Maytag Dryers
Maytag Gas Dryer doesn't heat up
The igniter is the part that ignites the gas in the Maytag gas dryer. Long time a go the dryers use to have a pilots. The pilots where on all the time, even when the dryer was not been use.
This wasted a lot of gas and a new design was needed. That is when the igniter or glow bar as is also known, came to be. A bad igniter could be the reason for your Maytag gas dryer not heating.
The radiant sensor is a small black box that attaches to the combustion funnel. The job of the radiant sensor is to allow the igniter to glow until it is real hot, then it shuts the igniter off and opens the gas valve to start the heating process. A bad radiant sensor could the the reason for your Maytag gas dryer not heating.
The gas valve has two coils or solenoids. These coils job is to open the gas chambers inside of the gas valve.
When one of the coils goes bad, the symptom is that the igniter glows, but the gas valve won't open to let the gas flow through the gas chamber to be ignited.
A bad set of coils could be the reason for your Maytag gas dryer not heating.
The hi-limit thermostat is located on top of the combustion funnel, and its job is to open the circuit to the gas valve if the airflow to the dryer is restricted for any reason.
The cycling thermostat is use to control the temperature inside of the dryer. It is factory preset at 155 degree, in other words it will open the circuit to the gas valve when the temperature reaches 155 degrees.
This thermostat is opening and closing all the time the dryer running. A bad cycling thermostat could be the reason for your Maytag gas dryer not heating.
The timer is the part that direct the electricity to the other parts in the dryer. This part works very hard and the contacts wear out and some times they burn out. If the timer contacts won't close, the dryer will not heat.
The motor switch is another safety device that only closes the heating circuit when the motor is running. When the motor is not running the circuit of the gas valve is open and the dryer will not heat. A bad motor switch could be the cause for your Maytag gas dryer not heating.
As you could see, there are a lot of parts inside of the dryer that have to be in good working condition for the dryer to produce heat.
May 27, 2009 | Maytag Dryers
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
one thing u can do remove vent tub,
turn on dryer run for about two min
open door touch inside door if hot
u have a vent problem
May 12, 2009 | Maytag PYG2300A Gas Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
169 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
