Question about Logitech Cordless Optical Mouse for Notebook 931151-0403
Logitech cordless mouse won't work right. Hard to stop in one
Place when it finally starts. I have to press the button several times before it will even point on what I want it to. Then It is moving all over the place and I put new batteries in it for the second time so it is not the batteries. Please help as this thing is driving me up the wall. It takes forever and I have to keep pressing the left and right side to get it to land on what I need. Do I just need to return it and get a new one? Will my old mouse that uses a cord work with my cordless keyboard in the meantime? Thanks.
  • tnjackie Feb 19, 2009
    I used the connect button and the button under the green light however the light just keeps blinking. Is it supposed to remain on all the time without blinking? Mine does not do that. I am using Duracell Coppertop batteries, would that matter? Thanks.
    TnJackie@aol.com
    I have connected the mouse with the buttons. The green light just keeps blinking. Is it supposed to remain solidly on all the time? Thanks.
    TnJackie@aol.com
  • 202 Answers
Have you connected the mouse and keyboard to the receiver? There is a button on the bottom of each marked "connect". Press and hold the button down and watch the light on the receiver. The blinking will change when the device is recognized. It should operate smoothly after that.
Let me know how it works out.
Posted on Feb 19, 2009
  • Barry Parks Feb 19, 2009
    Your corded mouse should work fine with the wireless keyboard. Just be aware that if it is a PS2 mouse, round plug, it will only be detected when the computer first starts. So shut down the system, connect the mouse and restart the computer. You don't need to shutdown if the corded mouse is USB.
    Duracell batteries should be fine. I haven't seen any issues with any name brand batteries.
    Something else to try would be to start from square one again. Hook up both old mouse and keyboard. take all of the batteries out of the wireless devices and let them set for a few minutes. While they are 'resting', check the area for anything that might be causing electrical interference. Also check to be sure that the area between the receiver and the mouse and keyboard is not obstructed.
    When everything is well rested, install the batteries again, and connect the receiver to the computer. You may see the 'new hardware found' message. If you do, let it complete loading and then try the connect button. Check the documentation that came with the mouse and keyboard to see if they explain the blinking. Some blink constantly while others are steady or some only blink when the mouse is in motion.
    Please keep me posted on how you are doing!
Logitech cordless keyboard not working properly - keys stick or are delayed
Did you spill something on it or is food lodged in unit if so take apart clean.
Fresh batteries would be good start.
Feb 18, 2010 | Logitech Cordless Desktop MX3200 Laser...
My right click mouse button stops working periodically any suggestions how to stop this from happening
Sage, The mouse may be fine. What may have happened is that the lever that you press as right click has a micro switch below it. This micro gets pressed and you get a right click. As time passes the gap between the lever and the switch increases and you have to click harder and then comes a time when this contact can not be made under normal circumstances. So place your finger in a different position so that the lever is pressed differently. You may still get a few thousand clicks before even this stops working.
Basically, the bottom line is that the mouse is getting old and needs replacement.
Dec 06, 2009 | Logitech Cordless Desktop MX 5500...
Logitech mouse stopped working. Put in new
First thing is to check that you re-established the connection between the mouse and its receiver correctly. Press the button on the sender/stand and quickly press the small button under the mouse for at least 15 secs.
It could also be that the mouse just died - I have this happen to me!
Nov 06, 2009 | Audio Players & Recorders
Mouse stopped working. Changed batteries... still does not work.
There is a connect button on both mouse and receiver have you tried pressing those? It may be receiver first or mouse first but there's only 2 ways.
Aug 31, 2009 | Logitech Cordless Mouse
My mouse just stopped working. I have a cordless
I would start by pressing the Connect button on the bottom of the mouse, then the Connect button on the bottom of the mouse receiver connected to your computer.
If that doesn't work, try replacing the batteries, then going through the Connect method mentioned above.
Aug 25, 2009 | Logitech Cordless Mouse
Cordless mouse and keyboard wont work together
Hi, after experimenting a little i have fixed my problem and I think I might be able to help you.
First, try press the connect button on the receiver.. Hold it for 20 sec (might not be necessary).
Then, press the connect button on the mouse and hold it for 20 sec (is necessary)
Next, wait 20 sec (is necessary) then press the connect button on the receiver but do not hold
Finally, press and hold the keyboard button for 20 sec.
Sep 28, 2008 | Logitech Cordless Mouse
Logitech wireless mouse and keyboard
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Sep 23, 2008 | Logitech Cordless Mouse
Hotkey problems
I had the same problem but finally found a solution hidden in the depths of Logitech. It's quoted below. I had to do it a couple of times before it worked, and it seems that you need to reconnect the mouse at the same time. I didn't the first time and then the keyboard refused to work. (Finger trouble?) :-(
Cheers,
Magani
The following is from :-
http://logitech-en-ap.custhelp.com/cgi-bin/logitech_en_ap.cfg/php/enduser/std_adp.php?p_faqid=28&p_created=1083786523&p_sid=hwmEUpij&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTkwLDE5MCZwX3Byb2RzPTg0NCZwX2NhdHM9JnBfcHY9MS44NDQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1teCBkdW8gaXRvdWNo&p_li=&p_topview=1
This article applies to the following products:
Cordless Access Duo
Cordless Acess Duo Optical
Cordless access keyboard
Cordless Elite Duo
Cordless MX Duo
Cordless Navigator Duo
You may be able to reset the keyboard and resolve the problem by clearing the keyboard capacitors. To do this, remove the batteries from the keyboard and type continuously on as many keys as possible for one to two minutes. This action should simulate touch-typing; you should not press and hold only some keys down.
After you clear the capacitors, replace the batteries and synchronize the keyboard using the following procedure:
  1. Make sure the batteries are in correctly. A diagram on the device itself or in the Getting Started Guide should tell you the correct polarity for the batteries.
  2. Press the connect button on the receiver.
  3. Press the connect button on the bottom or right hand edge of the keyboard.
    NOTE: If you are using a Cordless Desktop System, you must do this procedure for both the mouse and the keyboard.
The "Connect" button on the mouse is quite small and usually requires a pencil tip or other small object to push it. Remember, ALL Logitech cordless devices will have a synchronization button. If you have the "Cordless Mouse" with Model Number (M/N) M-RN67, the button will be located in a small hole on the lower portion of the back of the mouse. You will need a paper clip to access the button.
Jul 03, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Logitech downloads for V220 logitech mouse
You can get it HERE. Choose the correct operating system to download your driver.
Jun 21, 2008 | Logitech Cordless Mouse
Logitech cordless mouse and keyboard installation
You probably already done this but try pressing the receiver button and while it is flashing turn the board over and press the small reset/connect button on the bottom of the board and also the reset/connect button on the bottom of the mouse. It should work okay after that. here is hoping that helps. Bud
Dec 20, 2007 | Logitech Cordless Desktop MX3200 Laser...
Logitech Cordless Optical Mouse for Notebook 931151-0403 Logo
199 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
