Question about Garden
Can i ajust chain oil flow rate, to lubricate bar, on husqvarna 340
  • josh1111 Mar 02, 2009
    no i got the same saw and cant figure that out either
    Sniper:
  • 87 Answers
No. It is an automatic oiler.
Posted on Apr 10, 2009
Need to know what kind of oil is used in 2.0 cid gas chainsaw?
Chain oil for the chain
STIHL Bar and Chain Oil - Chainsaw Accessories ' STIHL USA
www.stihlusa.com/products/oils--lubricants-and.../oils...lubricants/chainoi... Rating: 4.5 - ‎6 reviews Don't let friction cut down your chainsaw's performance. STIHL bar and chain oil is specially formulated to adhere to your chainsaw's bar and chain, providing ...
2 stroke oil for the engine
XP® Professional Peformance 2 Cycle Engine Oil 50:1 ...
www.husqvarna.com > ... > Accessories > Lubricants & Fuels XP® Professional Peformance 2 Cycle Engine Oil 50:1. Our best ... 610 00 01-31, 6.4 oz. bottle for 2 1/2 gal. mix (50:1 Mix), $ 3.29. 610 00 01-32 ... Chainsaws.
Oils and lubricants STIHL
Feb 08, 2016 | Garden
How to stop flow of oil on to chain?
Interesting.
Chain lubrication
is critical to the life of the bar and chain.
I'd be suspicious that you may not be using heavy viscosity chain lubrication oil.
Light weight oil will flow much faster.
Dec 03, 2015 | Garden
How do i adjust the chain oil flow rate
to test if your oiler is functional remove bar and chain and start unit. if it drips oil with bar and chain off then clean the oil hole in the bar. if plugged it will prevent oil from reaching bar for lubrication of chain
Sep 16, 2014 | Garden
How to adjust chain oil
chain oil is not ajustable. the pump is most likely faulty or the oil ports blocked.
Apr 09, 2014 | Husqvarna 450 e-series 18" Chain Saw
MY HUSQVARTA 340 STARTS BUT THEN DIES AND THE OIL TO THE CHAIN DOES NOT DISTRIBUTE TO THE CHAIN IT ENDS UP AT THE END OF THE BAR
Remove the fuel hose from inide the fuel tank and replace the fuel filter, remove the top cover and clean the air filter, now try again, the chain oil is delivered to the top of the bar and is taken around the bar by the drive links, make sure you are useing a non fling chain oil, remove the guide bar and clean out the delivery hole, now try again.
Apr 10, 2011 | Husqvarna Garden
The saw is a 385xp. We have changed bars and chains numerous times. When sawing the bar gets hot enough to fry an egg and the chain stretches out. Onlynable to saw a minute or teo at the time. bar gets...
Overheating the chain/bar is usually caused by insufficient oil getting to the chain, but can be caused by the chain being too tight to begin with (you should be able to turn the chain by hand), grit in the chain groove, or a poorly sharpened chain. The saw has an oil volume adjustment screw on the lower part of the case near the chain return area. Turning it CCW should increase oil flow. Oil volume can be judged by running the saw tip at speed near some cardboard for a moment--it should throw off a thin line of oil. Chain sharpening condition can be judged by the sawdust residue coming from the cut--if a powder-like material, the teeth are not sharp or are improperly filed. You should not have to bear down excessively on the saw to make it cut quickly. Hope some of this helps!
Jan 09, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How much chain bar oil should my husqvarna 340 use?
A rough equivalent is one oil tank for one fuel tank. Check the chain oiling by running the bar tip near some cardboard at speed for a few moments--it should throw off a thin line of oil. Hope this helps!
Jul 19, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 272 xp, setting for setting screw for oiler
To check for proper oiling, run the saw at speed with the tip of the bar near a piece of cardboard--it should throw off a thin line of oil after several moments of running. Adjust the oil adjust screw CCW for more oil. The screw is usually in the lower front or underneath the engine. Remove the bar and chain first before adjusting anything and check the oil passages located in the drive end of the bar for plugging--especially the two small passages that go from the large oil holes out to the chain groove on both sides. Start the engine without the bar and chain--look at the oil port where the bar mounts next to the engine. It should ooze out oil with the engine running fast. If nothing at all, the pump, oil lines, and oil filter in the tank should be checked. When everything seems to be working, then adjust oil flow for best operation. Hope this helps!
Apr 17, 2010 | Husqvarna Chain Saw 20" Bar
Garden Logo
362 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
