Question about Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic Lumix DMC-FX9PP Digital Camera Display not working
I have lost the back lit display on my camera. This has been intermittent for the last year or so, so when the display would go dark, I would turn the unit off & on & that would sometimes work. Mostly I would give the screen (or side) a bit of a "tap" and voila! on it would come. I can, depending on ambient light and the right angle, see the image and menu options faintly on the screen. I can still take pictures, although not well as you could imagine. I may need to find out about service repair options for this problem. I'd hate to throw away this $300+ camera and don't want to spend too much for repair. Thanks, Alan B. Southbury, Connecticut
It seems that the only repair option unless I try to take it apart myself was to send it off to Panasonic for a flat rate of $161.50. So I went to "Plan B" ..... I went on eBay, found the exact same camera last night that had an auction that was ending in a few hours. I bid on it & & won it for $61. So I get memory cards, extra charger, battery & cables & move on. If, down the road, I can find a Panasonic recall similar to Canon's then I'll bring the old one back to life.
Name Address City State Zip Phone .
PANASONIC CAMERA AND DIGITAL S 1590 TOUHY AVENUE ELK GROVE VILLAGE IL 60007 (800) 211-7262
Panasonic has centralized its repair experts for quality control and efficiency. If you need operating assistance, please call 1-800-211-PANA. If you are sure your product is in need of repair, please ship it to us at the address above.
If your camera model begins with PV ----- If the unit is over the 90 day warranty period but within the 1 year parts warranty period, the flat rate repair charge is $161.50 (Return Shipping Included). If unit was purchased over 1 year ago, the flat rate repair charge is $261.50 (Return Shipping Included). Please include a check or a credit card number to eliminate any delays in processing your repair.
If your camera model begins with DMC ----- If unit was purchased over 1 year ago, the flat rate repair charge is $161.50 (Return Shipping Included). Please include a check or a credit card number to eliminate any delays in processing your repair.
Failures resulting from misuse, moisture damage, impact damage or other physical damage do not qualify for flat rate repair. In these cases, a separate repair estimate will be prepared for your approval.
Posted on Feb 20, 2009
Panasonic Lumix DMC-FZ28
It is broken and you will have to content yourself using the display screen.
Sep 01, 2017 | Panasonic Lumix DMC-FZ50K Digital Camera
I have a Panasonic Lumix DMC-FX9PP and the monitor suddenly went completely dark and has stayed that way. What caused this and how can I reverse/fix it?
The display being black can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the display is not seen, then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the camera aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Thank You for using fixya
Aug 22, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic lumix dmc tz7 has message no valid picture to display. Can someone please help? This is not a new memory card , it has been in use for a few weeks.
Have you got the switch on the rear of the camera set to camera and not playback? My camera displays this message if I have no images on my memory card and try to play them back.
Nov 29, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
DMC TZ3 all buttons blocked
Jan, I have the same problem on the same camera. Did you get yours fixed?
May 21, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
I have an urgent issue of needing to display date Lumix DMC-FZ50
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-FZ50K for pdf version of manual. The K or S means the color of camera you have...black or silver. My wife has that camera, there is no way to display the date/time on the pictures themselves, you will have to look at the properties of the image. All images now contain certain data that is hard for the novice to change and might be able to be used in certain courts...good luck, hope it's not too late.
May 18, 2009 | Panasonic Lumix DMC-FZ50K Digital Camera
Need to replace the lcd in lumix(panasonic) dmc-fx3
ebay seller rongyuanxie about 55.oo or do an ebay search with these key words... FX3 LCD DISPLAY SCREEN
hope this helps...
Oct 31, 2008 | Panasonic Lumix DMC-FX2 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
528 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
