Question about Kenmore 65924 Electric Dryer
Dryer will not heat
I have replaced the heating element and all three termoststes and the dryer still will not heat. The first time I replaced the heating element it worked for about three weeks then it stoped heating again. Then I replaced the heating element again still would not heat and then I replaced all the termostates. The dryer still will not heat.
  • Paulo May 11, 2010
    Did you check the fuse panel or reset the breaker? (reset the breaker even if it looks like it's not tripped)
  • 188 Answers
Check to make sure you have 240V at the outlet. If you do, check the continuity of the element and thermostats. If still no heat, it could be the temperature setting switch, the timer or the motor.
Posted on Feb 21, 2009
My whirlpool dryer 3394996 is about 10 years old or more and it wont heat up everything else seems to b normal
This is either a heating element (most likely and easy to replace) or it is one of your heat sensors. Should be three of them. Still very easy to replace and I would do all three at the same time rather than just the bad one. You can tell if it is the element by looking for a break in the wire on the element or pull it off and hook it direct to current to see if it heats(glows).
Nov 10, 2015 | Whirlpool Dryers
Dryer won't heat
Odds are the Heating element is out. Only repair is to replace it.
Oct 29, 2012 | Maytag Dryers
Drying times have lengthened over the last few months, and now require three cycles. The dryer is heating, but obviously not sufficiently. Is it a thermostat? Heating element? Maybe both? Something else?
If your dryer is a basic one it will just have an on/off switch and an element. If so, sounds like the electric element in the dryer is broken down internally and is not operating correctly. It sounds like you will have to have the element replaced. If you're dryer has a thermostat that could also be the problem.
Feb 14, 2011 | Kitchen Ranges
Dryer is not heating properly have run loads two to three times. Can I just replace heating element?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 09, 2011 | Kenmore Elite HE4 Electric Dryer
Quit heating
Hello there and thank you for choosing fixya
ok there are a few reasons why this happnes i will post them below for you
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Jan 22, 2011 | Dryers
My kenmore Electri Dryer is humming while drying.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.hope this help you out sincerely D.Jones
Jun 08, 2010 | Kenmore 64672 Electric Dryer
Does not heat- three of the temp sensors read 0 ohms, one is at 7.4 K ohms. Can it be the cause
Hello there
Here is a list of item for you to check Hope this is very helpful for you
Best regards Richard
My dryer will not heat up. Investigate these five areas if your dryer is not heating up:
Proper Voltage
dryer_heating-element.jpg Heating Element
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
Dec 15, 2009 | Whirlpool LTE6234D Top Load Stacked...
Dryer won't heat up! It tumbles fine, but no heat! My Maytag dryer is only two or three years old!
This problem is normally caused by a faulty thermostat and or heating element. Test and replace if needed
Sep 23, 2009 | Maytag Dryers
Kenmore dryer makes no heat
replace the heating element. Or the control panel has weakening capacitor not sending correct current flow to the heating element
Jul 09, 2009 | Dryers
Trying to find heating element on dryer
You have to pull the three screws that secure the top to the back. Then you have to slide the top off and remove the front panel. The heating element is on the bottom right side of the machine. Once you have it off, replace the thermostats and it usually works fine. I keep having to replace mine, as my outside "bird" filter gets clogged and the thing loves to trip.
Dec 11, 2007 | Dryers
Kenmore 65924 Electric Dryer Logo
1,536 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
