Question about Microsoft Xbox 360 Console
New Xbox 360 disk drive doesn't play games
I bought a new disk drive and it want play games it just say put this disk in a 360 console and chinese writing comes up
    Guru:
  • 832 Answers
Hi there! thanks for using fixya.com!
Please check this website for microsoft support:
http://support.microsoft.com/kb/906662
http://talk.xboxsolution.com/showthread.php?t=6248
and you could do Go to Xbox.com and sign in using your gamertag.
Just check out those websites. I hope I helped you somehow.
Pls don't forget to rate me with my solutions. thanks! cheers!
Posted on Feb 19, 2009
    Sergeant:
  • 250 Answers
Well my friend thats because each xbox 360 drive is unique for each console so it only works on the original console, to solve this you have to flash the firmware from the old drive and put it the new one, there are many sites explaining it just google it.
as for more detailed and prescribed help just click this link below and read the instructions to solve your problem
http://x-box-360-info.blogspot.com/search/label/problem
    Scholar:
  • 64 Answers
It will need to be flashed before it can play. go to http://www.biline.ca/360_mod.htm
There is a lot involved in doing this. Good luck
  • shawnsz
    shawnsz Feb 19, 2009
    What drive do you have according to the site i posted? I have extensive knowledge in the Xbox 360. So if you need any more help just ask
    and again good luck
    Sergeant:
  • 326 Answers
Upgrade the software/firmware with latest drivers as then it will start supporting and working properly.
Tried to play new game, says not enough memory space. I deleted everything and still wont play, help!
You may have an old series console version of the Xbox 360 that only has either 256MB or 512MB of internal memory. You may also have a new series console version of the Xbox 360 that only has 4GB or data storage. For multi-disk games that install one or more disks, you need, at minimum, a 20GB hard drive installed in your console. You will need to invest in a hard drive for your Xbox 360.
Mar 22, 2014 | Microsoft Xbox 360 Console
I bought a new xbox 360 driver circuit board and installed it myself, now the game don't work on it. it says i need to install the disk into an xbox 360 system, then a bunch of chinese writing help
XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console........
Click here to download repair guide
Dec 24, 2010 | Microsoft Xbox 360 Console
Hi, I had a problem with my xbox, it wouldn't play games. I bought a new drive, I have a benq. I fitted the old mother board into the new drive but it would still not play. I then fitted the new mother...
Your Xbox 360 lens are most likely dirty. And your 360 probably has something like dust stopping it from scanning your games. I suggest blowing into your DVD drive carefully and gently. If it still doesn't work I recommend sending your Xbox 360 back to Microsoft for a new one if your under warranty. If you don't have a warranty you could clean you lens by your self. But opening your 360 to clean the lens could make it worse so do it at your own risk.
Apr 15, 2010 | Microsoft Xbox 360 Console
Xbox 360 Pro : To Play This Disk Error
Unfortunately , a new xbox360 game cant be played in a normal xbox (not xbox 360)
The problem is that the new xbox is way different on the inside than the original xbox is. Because it is way more powerful, you can put an old xbox game into a 360, and it will work fine (most of the time), but if you try the reverse there is no way to make it work.
May 13, 2009 | Microsoft Xbox 360 Pro System Console
To play this disk put it in an X-Box 360 console??? Nice message after I replaced the disk drive. I bought a new driver made for the 360 and it still only shows disks for DVD ??
The dvd drive and the motherboard have a key that must match each other. The xbox 360 dvd drives are not plug-and-play. You must first extract the key from the original drive and spoof firmware to make the new drive match the key on the motherboard. There is an easy way though.... just take the pcb board out of the old drive and stick it into the new one, then everything should work fine withough messing with the firmware. If you need more help, just ask on our xbox 360 dvd drive repair forum
Mar 05, 2009 | Microsoft Xbox 360 Console
New XBox 360 putting scratch in games
the problem is the disc drive.
you have to open it up and put some stick foam " like a sticky strip of foam, insulator : on top of the drive .
the problem is that the disc touches the laser assembly while turning cheating a ring on the disc.
i can fix your games as well as the disc drive if you feel like is to complicated.
Jan 02, 2009 | Microsoft Xbox 360 Console
Xbox 360
if its just 4 that 1 game then ur disk wont play no longer. mine did the same thing. i flipped my console to the side while a game wuz in and now i get the same message along with a lot of chinese on the page. but if its wit all ur games then its ur cd drive.
Mar 28, 2008 | Microsoft Xbox 360 Console
well my friend thats because each xbox 360 drive is unique for each console so it only works on the original console, to solve this you have to flash the firmware from the old drive and put it the new one, there are many sites explaining it just google it.
Sep 17, 2007 | Microsoft Xbox 360 Console
New Xbox 360 Drive.. Need help flashing
You will need to backup the firmware from you original drive and flash it to your new drive as the old drive is tied to the motherboard with a 16 byte key
Microsoft Xbox 360 Console Logo
41 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
