Question about Philips Magnavox DVD/VCR Dual Player
When the DVD is inserted, an error appears
We hooked this up to our TV and everything works (the VCR) except the DVD player. We tried using several different DVDs but when we insert the disk, a blue screen appears with disk error. There is no trouble shooting in the manual for this issue. HELP US!
  • milkmaid137 Apr 11, 2009
    I have the same problem; no DVD will play and it machine claims there is a disk error. I have used a cleaning disk, but the DVD player still will not read any disk, and an error message appears.
  • 899 Answers
Have you tried or have you been using a laser lens cleaning disc ?
if not then the glass lens will need to be manually cleaned with a q-tip and lens cleaning solution
Posted on Feb 19, 2009
Memorex MVUC821 TV/DVD. Everything works except the TV.
Just bought the Memorex MVUC821 & the DVD Player will not open using the remote or front panel button!!!
Mar 23, 2010 | Memorex MVUC821 Player
How can I set the channel BACK to CH 3 from CH 4
1) Set your TV to channel 3.
2) Insert a pre-recorded tape into this unit.
3) Press the OUTPUT button on the DVD/VCR so that the VCR OUTPUT light is lit.
• If noise appears on the TV screen, press the VCR/TV button on the remote control.
4) Press the PLAY button once.
5) After a few seconds, press the PLAY button on the DVD/VCR for 3 seconds.
• The RF output channel will change to channel 3 from channel 4 and you will see a playback picture.
• When a picture does not appear on the TV screen, repeat step [4].
6) Press the STOP button to stop playback.
Nov 17, 2007 | Emerson EWD2004
How can I hook up a nintendo wii through my
Hi, There should be an av button.
do you not have spare connections on your tv?
This is your best way, unless you want to record what you are playing.
Which model do you have?
I will try and help
Regards - Anthony
Feb 08, 2010 | Philips Magnavox DVD/VCR Dual Player
Connecting a toshiba sd-v392 to an old analog tv
Make sure your menu settings are correct audio outputs may have a setting for digital or analog sound output check that these are set up to analog or stereo output .Also try hooking the sound up direct to a stereo system or amp to be sure you have output! Also you may not be able to get your sound thru the convertor box!! Because the convertor is a reciever of digital signals not a line amp. for audio !! Hope this helps11 AAAAAAAAAAAAAE!!!! Swampratt200 ! Out!!
Jul 21, 2009 | Toshiba SD-V392 DVD Player/VCR
Tv/digital converter box & vcr-dvd hook-up
Hi Karen, I think you are having connection issues. Can you provide specific details of the connections? Thanks, Mike
Nov 02, 2008 | Philips Magnavox DVD/VCR Dual Player
Rca dvd/vcr dual recorder, wont play dvd
My VCR/DVD Model # DRC6200N is not working. I can hear the DVD but no picture, do you have any suggestion what is wrong?
Jul 17, 2008 | RCA DRC8295N DVD Recorder/VCR
Hook up
Purchased a rf modulator and hooked in to the tuner out to modulator and from modulator to tv that made everything work
Apr 12, 2008 | Philips Magnavox DVD/VCR Dual Player
Interface error! Trun off the power
Okay...sounds like you have a lot of signal splitting as well as devices that may also weaken your signal. With digital cable, you won't see snow or what would be a dead give-away to a weak signal. Only analog signals do that. Digital signals give you crisp clear picture or they drop out.
Try taking the cable directly from the wall to the DVD-Recorder. If you are able to watch channels and manipulate the device, then you can start from there as the source is good and the recorder is good.
Try to place the DVD-Recorder after the first splitter and see if you still receive stable signal. You'll probably need to leave the unit in this part of your A/V chain.
It really sounds like you need a signal amplifier for all the splitting you've done, or to re-work your A/V stack into something more manageable. It is entirely possible that the built-in tuner of the new DVD-Recorder is not as sensitive as the old unit.
Oct 28, 2007 | Memorex MVDR2102
Emerson VCR and new TV don't hook up
hey i sort of hav the same problem except, i cant access the "channel" with my sons game stuff on it
if i click menue then it just givs me "Picture" "Channel Set" "Language" "V-Chip Set-Up" "Captions" and if i click channel set i get "CH{TY}" "CH{CATV}" "CH{DTV/TV}" and v-chip asks me for an access code. and i got this tv from a friend and he lost the remote. i only hav an iO Digital Cable remote. help me plz
Oct 28, 2007 | Emerson EWD7003 DVD Player
My DVD player wont read a disc
There are several things you can do to try and solve your problem: Make sure that the DVDs you try to play are encoded for the right region. Make sure that the transportation lock (usually a plastic screw on the bottom of the unit), is not engaged. Turn off player with disc inserted, unplug temporarily from wall outlet, plug back in and turn back on.
Mar 20, 2006 | Panasonic DVD-S31S DVD Player
Philips Magnavox DVD/VCR Dual Player Logo
116 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
