Question about E-Machines eMachines Desktop PC
I have a desktop E Machine. When i push in the
I have a desktop E Machine. When i push in the circular button nothing happens. seems like the system is drawing energy however because when i plug it in from the back the lights dim for a brief momment. I tried using its own power source thinking maybe it was underpowered due to the lights dimming but no luck.
  • 35 Answers
This sounds like a power supply went bad. Did you either have a power surge or did someone shut down the computer by pulling out the plug?
Posted on Feb 19, 2009
The kitchen timer button does not work on my Kenmore circular wave microwave.
If it has membrane switches, you might have a bad switch. Or, you could have a bad connection between the touch panel and the circuit board. Or the circuit board itself could have a problem.
Jul 25, 2016 | Kenmore Microwave Ovens
Nothing happens when push start button. power cord etc good ??? is this a power unit failure?
make sure the outlet is recieving power
unplug the tower from the outlet & then replug it in & see what happens
make sure all cords are plugged in correctly in the back of the tower
then if nothing happens after you push the start button, power supply & cord could be bad
the same thing happened to my daughter's pc & had to replace power supply & shorted out the motherboard
Nov 18, 2010 | HP Compaq Presario SR2050NX PC Desktop
The washer has power but when you push the start button nothing happens. The machine filled then was paused and it will not drain or restart. Any help out there?
The start button actuates a small switch on the control board. Pressing the start button hard enough can cause damage to the microswitch, and/or loosen its connection to the PC board. If you rock the start button with your finger (ie circular rubbing motion), that sometimes works. Better still, open her up, find the microswitch directly under the start button actuator, a plastic plunger that makes contact with the microswitch, and press the microswitch button directly. Try jiggling the microswitch itself while pressing in the button. If it comes on, then it's a bad solder joint.
Nov 07, 2010 | GE Profile WPRE6100G Top Load Washer
Panel lights are on. push on button nothing happens
I have experienced the same thing a number of times. To solve, open the door, then turn the knob, and push the start button on and off, and push the delayed start button (3, 6, 12 hour). Then close the door, and retry. This routine seems to reset the system.
Apr 22, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
When the power button is pushed on, the power button just does a quick flash and nothing happens. nothing starts on the computer.
have you added any new equipment to the system?
Have you have bad weather?
Do you have a suppresser on the AC input
How old might this unit be?
Feb 17, 2010 | HP Compaq Presario SR2050NX PC Desktop
I just moved into a flat with the WMA641 w Beko Washing Machine. I loaded it and turned it on : settings : Delicates 30 degrees. Pushed the on button and nothing happens. after few seconds the on light...
turn the machine off at the wall , leave off for 30 secs , switch back on
give the door an extra shove as this may not be fully closed
the on/off button will be a push in type , the start button is usually much smaller
Oct 23, 2009 | Washing Machines
I tried pushing tab and delet still nothing
it usually happened when a key is permanently pushed and stuck. so please check all the keys and release the key which is pushed or stuck.
Apr 04, 2009 | Compaq Digital PC 3100 PC Desktop
Computer seems totally dead
If the power cord is firmly plugged in - both ends, remove the battery. Does it turn on now? If so, replace battery.
gurutim
Mar 21, 2009 | Dell Dimension E510 PC Desktop
CD drive door won't open.
there is a very small hole near the push button of your drive, put a pin into it and press it along with the push button
Nov 08, 2008 | HP Pavilion Slimline S3123W Desktop PC -...
Power switch does not turn computer on
If the switch has a (O) and (I) on it ,the (I) should be pushed in.
Jan 10, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
41 people viewed this question
Top E-Machines Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
