if there is no spark when u crank it it means there is a problem with your starter coil u fix that everything will be alright. There is no need to change your battery.
You have a motor error. Remove any load from dryer and check if drum turns freely by hand. Check L1 power supply voltage, motorwindings, and motor thermal protector (if motor thermal protector has tripped,it may take up to 30 minutes to reset). If error persist, replace the motor with this new one.
You can start by making sure that the photocopy is working, this is to ensure that the scanner is working. Next, try to isolate the issue if this is only happening to only one fax number? If all of these have negative results, I suggest for a hardware reset. Follow the steps for reset found here, How to Reset the HP LaserJet Pro M1536dnf Multifunction Printer. Goodluck :)
If you just changed or disconnected the battery....
You can't reset it yourself. It takes a scanner at your Local Dealership to do it. People do it, (new battery) everyday unaware that doing so can and usually does, arm the theft system and either kills the radio or the whole car. To me it's just another built-in defect that requires dealer assistance. It's a buzz kill I know, and it probably won't be long until car owners won't even have access to the engine compartment. They will need your VIN, and then they call HQ to get the code for your radio / Vehicle.
