Question about Samsung 710V 17" LCD Monitor
Samsung 710v test good
I tried holding in the menu button at the same time as the + and - buttons, message read 'test good' still cant get monitor to work.
  • 1 more comment
  • Yang Xue Apr 20, 2009
    I have the exact same problem and I can open the case. Looks easy enough and the VGA board is smaller than I expected. What is the next command?
  • dopimile Apr 29, 2009
    Another one in a line...
    Waiting for further instructions.
  • Nerijus Mazuolis May 11, 2010
    its the microchips NT68F63L problem on vga board. you need to open
    monitor to solve the problem. there are more than 3 ways how to repair.
    Can you open the monitor ??
    if you want there is manual how to repair samsung monitors with this
    problem you can find on ebay: Repair manual Samsung monitor 710n, 913v,
    510n and more, Item number: 220389041052.
    it shows step by step reparation process.
For anyone having this problem i suggest to get a manual from asnerejas. His notes helped me out totally.
Its not something you would spot looking at its inside...
Posted on Apr 30, 2009
Samsung 710v problem. It started out as "Not optimum mode" for which i applied the 50/47 ohm fix present around the web. It worked for around a year.
Not optimum mode refers to the resolution. If you set it to 2048x1024 and your monitor won't support that, it will give you this message. Remove the resistor. In Windows Control Panel go to display. Adjust your resolution to your preference in the table. Do NOT exceed the table. You may have fried your monitor with the resistor. Good luck.
Nov 04, 2014 | Computers & Internet
How do I unlock the OSD lockout on a Samsung B2430H monitor. I've unplugged the power and computer connection cable. Tried holding the menu and auto keys nothing seems to work. There is just the...
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear.
Sep 09, 2013 | Samsung SyncMaster 753S 17" CRT Monitor
My samsung P2050 monitors menu has been lockd, now i cant set up my monitor setings. Please tell me how to unlock it
On: If you press and hold the MENU button down for 5 seconds, the OSD Adjustment Lock
function is activated.
Off: If you press and hold the MENU button down for 5 seconds again, the OSD Adjustment
Lock function is disabled.
That should FixYa.
Mar 12, 2011 | Samsung P2050 Monitor
My syncmaster 710n is not working. I get the box where it ses what resolution si the right one, but the syncmaster 710v works normaly. Does that means my 710n can`t be repared anymore? Thanks
Not completely sure what you're saying. Here's what I got out of your problem:
You have a Syncmaster 710n that displays a box saying the best resolution is _____ x _____, but your Syncmaster 710v doesn't show that message.
The main question I have to ask you is whether or not you see the screen or display behind the message on the Syncmaster 710n.
In either case, I doubt that this is a hardware problem. I also highly doubt that your monitor cannot be repaired. Try the following:
1) If you see the display/screen is showing behind the message box, this is almost definitely a setting issue. You need to press the menu button on your monitor and look for an option that says something like "display resolution message" or "ideal resolution message", or something else like that. Then you need to change the setting for that option, for example if "Yes" is selected, then you need to change it to "No" or if "Enable" is selected you need to change it to "Disable".
If you have the manual for the monitor, it should make it easier to know what setting to change. If not then go here:
and download the Manual that you need.
2) If nothing is being displayed behind the message, try to change the display settings of your computer. While using a different monitor, try the following: If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution to something compatible with your monitor (like the one it suggests you to change it to). If in Vista/7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Good luck. Let us know how it goes.
Feb 16, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
I cant unlock osd of my samsung monitor , sync master 551v
Please try again to turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu. regards
May 27, 2009 | Samsung SyncMaster 151 N 15" LCD Monitor
Where is the source button on the samsung 710v
the 710V samsung monitor has only vga analog input. so there is no source button
Feb 19, 2009 | Samsung 710V 17" LCD Monitor
It may be that the LCD monitor will not display all screen resolutions so you may need to change your resolution to match the desired resolution and refresh rate of the LCD. In your case the computer should be outputting:
1280x1024 pixels
60 Hz
You can change these settings by right clicking on the desktop and clicking properties and they're under the settings tab.
Mar 25, 2008 | Samsung 710V 17" LCD Monitor
Auto adjastment locked
Samsung implements protection into their monitors, which allows to block all settings except brightness and contrast. This "Locked" mode turns on by pressing and holding 'Menu' button for 5 seconds, and turns off by pressing and holding 'Enter' button for 5 sec.
Mar 02, 2008 | Samsung SyncMaster 193V 19" Flat Panel LCD...
Samsung 710v 17'' lcd problem
The problem is main board inside monitor which is needed to be changed with new one. So I suggest you to take monitor in nearest samsung's service center.
Best regards
Dec 14, 2007 | Samsung 710V 17" LCD Monitor
Samsung 710V 17" LCD Monitor Logo
1,429 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
