Question about Lexmark N4050e 802.11g Wireless Print Srv(USB)
How do you set up network scanning with lexmark N4050e ?
Have installed wireless Print server as per instructions and then
attached printer (lexmark X543) to print server with USB cable and installed drivers for printer as per instructions.
Printing from PC to the wireless Print Server/attached printer works fine. No problems.
BUT can't scan from printer.
Problem is I can't see IP address of printer on the network - just that of the Print Server. So I can't set up a scan profile from the web admin page of the Printer as I can't access that page.
I have fixed the IP address of printer to a number valid in my local wireless LAN using the admin menus on the printer.
Any ideas ???
Thanks.
  • 619 Answers
SOURCE: Lexmark 4300 series
Open control panel to activate your printer in default /check also device manager if your priter are connected w/ device.
Posted on Jan 07, 2008
SOURCE: Print server thinks printer is offline
Disconnect from the net and turn off your firewall while trying to install.
Posted on Jul 31, 2008
PABLOCSA
  • 1124 Answers
SOURCE: I have a Lexmark 5490
Check your windows firewall or your antivirus.
Disconnect that for a while and delete all pending documents (queue).
Send a new doc to print and see what happen.
Usually those program are blocking the communication between printer and computer.
If this is your case, set a rule on your antivirus program.
Have a great day!
Pablo :-)
Posted on Oct 18, 2008
  • 11 Answers
SOURCE: lexmark N2050 wireless adapter for X3500-4500 series printer
i cant tell you too much because i dnt know too much about your situation but try completely resseting everything and try sending something again
if its allwireless c if you can pick up the wireless points if you cant there's your problem
Posted on Jan 01, 2009
bluegreenash
  • 661 Answers
SOURCE: Cannot print from laptop to printer using wireless print server
This is probably the Software Firewall on your laptop
you should probably tell your firewall software that you have an internal network (Laptop-desktop-printer) you should add the IP range of the wireless network as a trusted network.
Posted on May 25, 2009
I recently purchased a Lenovo All in One wireless computer. I've plugged in the USB cable as per instructions but my X4650 printer will still not print.
Have you installed the printer drivers? Is the printer power turned on before plugging the USB cable into the computer? You could have a bad cable. Try a different cable.
Dec 13, 2014 | Lexmark X4690 Wireless InkJet Printer
Can I wirelessly network my hp pec 1350 with a belkin wireless g all in one print server
The Belkin Wireless G All-In-One Print Server lets you easily add an all-in-one printer to your wireless or wired network. It features 802.11g technology that makes sending print jobs faster than ever, and includes a memory buffer that handles your graphic jobs effortlessly. The Print Server is so easy to install that you'll be printing in minutes. Simply connect your Print Server to your Belkin Wireless Router and run the Belkin Easy Installation CD. Next, attach your USB printer to the Print Server and load yourprinter drivers onto your computer. You are now free to print, scan, fax and readcard media* wirelessly from around the home or office. The Print Server also works flawlessly with wired networks through its integrated Ethernet port. Compatible with most USB, network-ready printers, the Wireless G All-In-One Print Server from Belkin delivers even your most data-intensive print jobs with maximum speed and reliability.
*If your all-in-one device has a card-reader slot.
Instructions:http://www.belkin.com/pyramid/documents/external/F1UP0002_EN_QIG.pdf
Nov 21, 2012 | HP Psc 1350 All In One Printer Scanner...
Installing printer. Trying to install drivers for Lexmark X2500 printer. It's asking for an IP address
According to the specs, this printer connects to the computer using an USB cable.
The only reason it could be asking for an IP address if it is connected to a network card or attached to a print server.
OR the wrong print driver is installed.
You can download the Lexmark printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
May 18, 2012 | Lexmark Office Equipment & Supplies
How do i set up my wireless canon printer to my laptop? I keep getting messages saying can't find the printer.
Difficulty: Moderately Easy
Instructions
Things You'll Need: · Wireless print server
· USB printer
· Ethernet cable
· Computer
1. Step 1
Obtain a wireless print server that is compatible with both your wireless network and your printer. While the printer’s documentation may not explicitly say that it is compatible with a print sever, many are compatible, and this can be verified by checking the website of the print server’s manufacturer. If you have a multifunction printer, only the print function will work with most wireless print servers, though a few have recently added support for scanning and the printer’s other functions.
Step 2 Read all of the documentation that came with the wireless print server. The manual will detail the specifics of the installation routine.
Step 3 Connect the printer to the wireless print server via the USB cable. Connect the print server’s Ac adapter and turn the unit on.
Step 4 Connect an Ethernet cable between the wireless print server and your computer. This will be used for the initial setup only.
Step 5 Insert the CD supplied with the print server into your CD-Rom drive. Start the software if it does not start automatically. The application will walk you through the installation process, which includes setting the unit’s IP address, setting an access password, configuring it to connect to the wireless network, installing the drivers that allow the print server to use the printer and installing the print drivers on your computers.
Step 6 Choose how your print server will be addressed. Most units are set up to use dynamic addressing by default, which means that your wireless router will assign an IP address to it. This allows the server to be easily installed on the network, but it also means that the IP address of the printer may change over time. The other option is to assign a static IP address to your print server. This option is more reliable, because the print server will always use the same IP address, making it easier for the computers to find the printer and easier to access the print server’s online configuration application. If your router has the IP address of 192.168.0.1, for instance, set the print server to something like 192.168.0.2 or 192.168.0.3, as long as another device does not use that address.
Step 7
Set a password to be used to access the unit’s online configuration application.
Step 8 Configure the print server to access your wireless network. Give it the same SSID network name as your router and set it to use the same wireless channel. If encryption is used on the router, enable encryption on the print server, and enter the encryption key or password.
Step 9 Follow the instructions given by the print server’s software for installing printer drivers on the unit.
Step 10
Disconnect the Ethernet cable and allow the unit to connect via the wireless network.
Step 11 Install the printing drivers on each computer that will use the printer.
Step 12 Access the print server’s online configuration application to verify all settings by entering the IP address of the unit into a web browser, using the “http://192.168.0.2” format. Enter the administrator name and password.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 21, 2010 | Canon PIXMA MP600 all-In-One InkJet...
I am using my install disc and got as far as USB connection, which I did and now my continue window is grayed out. Trying to add my Lexmark 5600-6600 to my wireless network.
You're trying to do what?
Are you using a router that is also a print server?
Are you using a USB print server?
Printers don't hook up to routers unless it's a network connection with an ethernet cable.
Print servers hook up to printers with a USB cable, but are attached to the network with an ethernet cable in most cases.
Dec 22, 2009 | Computers & Internet
I have a wire less network set up and want to use my lexmark x1270 so i can print wireless but cable is USB and do i need to get a cable to put into my router or??
You can't set it up wirelessly, persay. but you can use a special bluetooth adapter in the "pic bridge" slot on the front. I have seen them on e-bay from £5($8) to £12($17) or so.
Oct 24, 2009 | Lexmark X1270 All-In-One InkJet Printer
Computer can's see Print Server in Add Printer Wizard The WGPS606 installation -- part 1 -- seemed to go fine. It sees our wireless network, we assigned it an IP address, it sees the printer connected to...
Make sure the printer has been connected locally first and that the print drivers have been installed. This should then allow you to add the printer via the set up.
Regards gaz
Sep 28, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
WHAT KIND OF WIRES DO WE NEED TO HOKUP A LEXMARK X3350 ALL IN ONE PRINTER.
Standard Ports USB Compatible with USB 2.0 Specification (Type B)
Optional Network Ports Lexmark N4000e Fast Ethernet (Print Only)
Lexmark N4050e 802.11g Wireless Print Server (Print Only)
According to:
http://www.lexmark.com/lexmark/product/home/277/0,6970,204816596_653399443_473191701_en,00.html?tabId=1
Sep 10, 2009 | Lexmark X3350 All-In-One InkJet Printer
Hp printer wont print through print server
Share printer option needs to be turned on
Realize that the scan option only funtions on local connection
Aug 11, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Lexmark N4050e 802.11g Wireless Print Srv(USB) Logo
252 people viewed this question
Top Lexmark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Robert Monigold
Robert Monigold
micky dee
Are you a Lexmark Computer and Internet Expert? Answer questions, earn points and help others
