Question about Dewalt 18 Volt Compact Drill Kit
How are the jaws replaced in a keyless chuck?
  • 2,176 Answers
They are not, you need to buy a new chuck. The tolerance is so close on the collar that you can't repair it. On some of the older keyed chucks you could but the jaws cost about as much as a new one.
Posted on Feb 19, 2009
How to remove keyless chuck
open the chuck jaws right up
down the center of the chuck you will see either a philips screw head or a hex head for allen key
hold the shaft at the base of the chuck to stop it from turning and undo the screw in the chuck in a right hand direction ( it is a left hand thread) when you have that out , still holding the shaft turn the chuck in the left hand direction ( normal thread ) and screw the chuck off
to assist in undoing the chuck do it up so that the jaws come out a bit
place something between the 3 jaws to act as a lever or use an allen key in the chuck done it tight and use that as a lever to undo the chuck
the secret is the lh thread screw in side the chuck which stops it from undoing when the drill is in reverse
Nov 17, 2015 | Bosch 18V Brute Tough Drill with Blue Core...
How to remove the keyless chuck on a rigid r86008
You will have to replace the whole chuck.
Dec 09, 2012 | Drills
Ryobi 18v drill keyless chuck stuck
Try holding the bit in a vice and gently tap the chuck off of the bit and see it it releases the pressure on the jaws.
Jun 20, 2012 | Ryobi 18v Cordless Drill - P206 18 Volt V
Mybrand new RZ20 keyless chuck will not close around a bit.
If a large enough drill bit is inserted too far so it bottoms in the chuck, the jaws run into the bottomed shank and will not close beyond a certain point due to the interference. If you hold the drill bit out about 1/2 inch from the bottom, the jaws should close on the bit. I assume you have tested the chuck without a bit to verify they can close.
Feb 15, 2012 | Drills
The keyless chuck on my "PSB 5000 RE" electric drill has jamed up and cannot be used. Can it be replaced or is the whole electric drill a throw-away?
chucks are screwed to the drill by a left hand theaded screw. try to get the jaws open enough to access screw then replace with new keyed jacobs chuck. they are brill.
Aug 12, 2010 | Bosch Garden
My AEG 630 watt drill SBE630RX. The keyless chuck is seized and will not release drill bit. This is used on a regular basis if this is any help. Many thanks. Trev
The cover on the chuck must be removed by using a punch, tapping around the drill side. this will pop off the cover exposing the jaw's. then use a channel lock and or bench vice on wheel that surround's jaw's. if the chuck is no good it may have a left hand screw in the bore that must be removed to take chuck off.
Apr 20, 2010 | Drills
Keyless chuck grip is stripped inside and the chuck is stuck in a tightened position. Can I get a replacement chuck grip and how do I get the chuck assembly off the drill, if that's necessary ?
second question first. No you cant just buy the grip, you have to buy a replacement chuck, shop around for best price, second you have to get the jaws opened up to remove, couple different ways, but first go to Dewaltservicenet.com and type in your model number for a parts explosion. Next if the grip is damaged can you put a pair of pliers on it and turn the collar to loosen it? the jaws have to be retracted to remove the chuck screw (LH threads), what you need to do now is put the drill in the drill only position and the tool in low range. Find a bent handle allen wrench and lock in the jaws, put the chuck on a bench or block of wood and wrench at about a 30 degree angle to strike it counter clockwise, you might have to hit a couple time but this will work. Let me know if I can help further.
Sep 07, 2009 | Dewalt Drills
New keyless chuck for panasonic drill ey690
Can'y find anything with the model number furnished, but generally to replace a chuck on a cordless you first have to remove the chuck screw LH threads and then shift the tool to the LOW position and the clutch to the drill only. Find a bent handle allen wrench about the same size as the chuck capacity and lock the smaller end in the jaws. Put the chuck on a work bench or block of wood with the handle at about a 30 degree angle so that you will be striking the wrench in the counter clockwise position, you might have to hit it a couple time but it will come off
Aug 10, 2009 | Panasonic Drills
Drill chuck swap
1. Turn the screw clockwise to take it out.
2. Then you needs 3/8 allen key & insert the short side of the allen key & tighten the chuck.
3. hold the drill at the edge of the table & wack the allen key
counter clockwise & do it again as needed.
4. dewalt keyless chuck will fit but you might add a washer to insure the chuck is not rubbing the clutch collar.
5. putting it back together the other way.
Jun 01, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Keyless chuck problem
I had the locking screw come loose in the center and bottom of the chuck it has a left hand thread and is a torx head . It had backed out and prevented the chuck from closing.
Mar 14, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt 18 Volt Compact Drill Kit Logo
162 people viewed this question
Top Dewalt Drills Experts
Tyler Craig
Tyler Craig
Level 1 Expert
Soulvisitor
Soulvisitor
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
