Question about Eicon (ISO-400) (ISO400) Power Supply
I have a iso switching power supply Model # ISO -400 300w. I cannot get it to run. I had moved around the switch between 115v and the 230v and it did start up for a second. Is there anything that I could do to fix this myself?
  • Anonymous May 07, 2009
    i have exactly same problem, i deassembled it, the fuse was burned
  • zillah May 26, 2009
    Could you please advise who is the manufacture for those PSU ?
Hayward super II wiring
move so both terminals are used sometimes they don't line up put on 220 then move to other position
Jul 24, 2012 | Hayward Super Pump 1 1/2 - Hp for In...
My computer will not come on , it is plugged the screem is in power save , it sound like it's dead, I have no solution can you help
Check the power supply first to make sure it hasn't gone bad. Note: I had a case where somebody changed the input voltage from 115V to 230V. It did not work on a 120 Volt outlet until I discovered the red slide switch on the back of the power supply was in the wrong position. Maybe somebody thought it was an on/off switch. It isn't often that people get off so easily, but it's worth a look.
(The voltage setting switch is next to the power cord socket, is generally recessed slightly so it's hard to mess with it. Usually it's colored red, but is sometimes black, and is always marked 115V in the correct position for U. S. operation. If it reads 230V that is the problem, unless you are outside North America and using 230 Volt power. In that situation setting it to 115V may cause major damage.)
Nov 04, 2010 | Computers & Internet
The pump comes factory set for 230v. Power to the motor is 115v so I switched the jumper as indicated. The jumper is set on 2 posts with an arrow pointing to 230v. I moved it to 1 post and the arrow now...
Jun 29, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
Power problem .... tried 3 different power supply cords...the green light on the rear blinking meaning???? pushed switch on front ...held response only moved from 1 office to another....always...
was it dropped..?? the indicator light should b solid not flashing.. If you held the power switch in for several min an nothing Try plugging the cord directly into the wall. Do not use power strips as they may have failed.Toggle the voltage regulator switch from 115V to 230V then back again. If you are in North America, this switch must be on 115V. you may have a loose connection in the machine Lastly, you may need to go inside the case and confirm the thin wires running from the front power and reset switches are connected to the motherboard., to check be sure u are grounded an check all connections inside the computer... If the LED is still flashing, the power supply is probably bad.
Apr 28, 2010 | HP Pavilion a350n PC Desktop
Ok i neeed help!!!!!!!! on my power supply there is a switch which you can move to 115 volts to 230 volts. everytime i switch it to 230 volts the computer wont turn on? why is this happening? when i put it...
This is the power supply for your PC, depend on your local country power supply, some country like North US may use 110 V in their daily use electrical stuff and some country like Euro, UK use 240 V.
Your PC power supply is design to suit this 2 type of power input so can be sold everywhere. What u need to do is to make sure your local country power supply voltage and then just switch the input correctly, i think u have done it.
YBC (/\)
Oct 20, 2009 | Computers & Internet
My computer when in 115v it turns on and then immediately off
Switch the power button on the rear of the supply back to 115V.
Have someone remove the supply and replace with the same.
Sometime, just disconnecting the supply connections at the motherboard and re-connecting them, resets the supply.
I would go that rout first and go from their.
Sep 25, 2009 | Computers & Internet
NPS-460AP, How to change to 230VAC
On the back should be a switch that reads 115v. There is a little notch that you can slide the switch and you can change it to 230v. Then at that point the power suppy will be setup to be ran for 230v.
Aug 30, 2009 | Dell - NPS-460BB-B (NPS460BBB) Power...
Compaq presario sr1115cl wont power up
Remove the power supply after everything is unplugged and take it to your nearest electronics store. They should have a tester there. This is probably the problem.
Jul 01, 2008 | HP Compaq Presario SR1420nx...
Sony VAIO VGC-RB50 No Power
Most likely you have a problem with your power supply. First off make sure your Input voltage selector switch is properly set. This switch should be located next to the power cord. In most cases it is red in color, and will have "115V" and "230V" printed on the switch. I have seen red switches and black switches, but mostly red. I you live in the US, you should see "115V", Europe is "230V". Before flipping the switch, unplug power cord.
Since the light is blinking, you are getting power to the power supply. The power supply might be bad, and you need a new one.
Nov 07, 2007 | Sony VAIO VGC-RB50 PC Desktop
Eicon (ISO-400) (ISO400) Power Supply Logo
1,826 people viewed this question
Top Eicon Computers & Internet Experts
David Payne
David Payne
Are you an Eicon Computer and Internet Expert? Answer questions, earn points and help others
