Question about Kenmore 24032\24036 Top Load Washer
70 Series will fill, but nothing else
The machine will fill with water but then completely stops. Won't go throught the cycle, no draining or rinsing, no spinning. I've tested the outlet and it works fine so it's not the electric. What could possibly need to be repaired? Any ideas on the cost including labor?
  • richhaupt Feb 20, 2009
    It's not the lid switch. It works fine, it clicks when closing and I've also tried doing it by hand and that doesn't do it either. Any other ideas?
  • 188 Answers
Check the lid strike and lid switch . If the switch is not engaged with the lid closed, the machine thinks the lid is open and won't agitate or spin.
You can check by slowly lowering the lid and listening for a clicking sound from the switch. Alternatively, use a pen to press the lid switch down and see if the machine starts.
A new lid switch, if required, is not too expensive but including labor it might be over $100. I suggest replacing it yourself if you can.
Posted on Feb 19, 2009
  • Paulo Feb 21, 2009
    Could be a defective motor or loose wiring. Is the motor working at all?
  • 3 Answers
Hey I'm fixing the same problem right now, it's probably the coupler between the motor and transmission in the bottom of the machine. It seems to be about a $13 part. go to and search.
Posted on Feb 23, 2009
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Kenmore series 70 fills with water on rise cycle but stops halfway throught then starts agian and finishes is this normal
If this has always stopped during the rinse cycle, most likely it's the "cool down" part of the rinse cycle.
See the following Sears site for manuals. Enter your model number and you should be able to download the proper manual for your washer.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Washing machine keeps draining during rinse
You may be experiencing a condition known as "siphoning". This is caused by the drain hose not being high enough off the floor, or not having a proper air gap at the standpipe in order to drain properly. This creates a suction and the washer will constantly drain as it tries to fill. The following link explains:
In the majority of the cases, this problem is attributed to improper installation, rather than an actual problem with the washer. If you have any questions, please post back and let me know. I hope this helps you.
Apr 08, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing machine isn't spinning to drain water
suggest that the drive belt is worn and slipping under exess load solution replace belt regards billnkaym
Apr 02, 2009 | Whirlpool LSQ8543J
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 24032\24036 Top Load Washer Logo
Sal De
 Brian Main
Brian Main
