Question about Sanyo DVW-6100 DVD Player/VCR
I have an old sanyo vwm 710 vcr. I have a new hdtv. I can play tapes on the tv if I change the input on the tv. I have selected line 1 on the vcr, but cannot get any channels to come on to record. The antenna is plugged into the back of the tv, the yellow, red, white cord goes from the tv to the output spots on the vcr. The vcr is on channel 4 (on the back. Do I need to change something on the remote or hook up another cable?
  • 4 Answers
Have you tried pressing the INPUT button on the remote; try pressing it up to 3 different times because I believe it sequences 2 or 3 times. With mine, hooked up to my RCA TV, 1st push puts it in Line1 on a blank blue screen, 2nd push shows Line 2 on a blank blue screen, and 3rd push brings it back to my TV with my satellite picture showing.
Sincerely, Rick
Posted on Feb 26, 2009
Not really a solution....RCA customer services (from India, I think), says that there is no way with that VCR because both the front and back (red, yellow,white) ports are input, and the only other jack on the tv is the one for the antenna. Since the digital converter is inside the tv, a splitter would do no good.
I would still have to get either a new VCR with the digital converter in it or get another converter box. An atmosphere of bait and switch is covering this hdtv scheme....
Posted on Feb 20, 2009
Where can i get a manual for a sanyo vwm-710 vcr?
Go to support on the Sanyo website. Enter your model number and download an owners manual.
murf427
Aug 04, 2012 | Sanyo VWM-700 VCR
Video heads of Sanyo VWM-800 4 head vcr need cleaning.
Take the top off and spray the main head with Servisol Video 40. (image below) Also the tracking and audio heads.
Wait for it to dry before putting a tape in. In the future use only this it is much better and cheaper than cleaning tapes.
Mar 10, 2010 | Sanyo VWM-800 VHS VCR
New sanyo hdtv and old vcr...can't get menu to appear on screen
there is an input or input select button that gives you cable,hdmi and video composite,to run the vcr. hook up cable and put the tv on channel3 to make sure that works first,then play with the rca cables. keep in mind a tape has to be playing,the new tv have a signal sense circuit,if there is just "snow" you get a blue screen
Jul 22, 2009 | Goldstar GVR-E435 VHS VCR
Sanyo VWM-710 gives video but no sound
You should probably just chuck it, Unless you paid a lot of money for it, which might make a repair worth while, the replacement cost would be a lot less than the repair cost. There is likely a circuit board or capacitor inside the unit that needs to be replaced, and the labor alone is going to run you $75 and up.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 13, 2009 | Sanyo DVW-6100 DVD Player/VCR
Have cable tv and wanting to tape a certain channel
I would suggest that you disconnect the VCR from any signal source. UNPLUG the VCR from the power source [a/c] for at least one hour, more if possible. Before you are ready to plug the machine into a/c attach an antenna to the antenna INPUT, the VCR output goes to input of tv. [ DON'T attach cable box, or any such machine to the input of VCR.] Plug vcr into outlet and turn ON. Place TV-VCR switch on TV. [no remote control??] Change the channel MANUALLY, one channel at a time. If you see tv stations as you change the channel [KEEP changing until you have reached the " end of the line " of broadcast channels.] then you are good.Connecting the vcr to a cable box[ANY KIND!] you can only RECORD through the vcr what you watch on cable.
Dec 09, 2008 | Sanyo VWM-900 VHS VCR
Can't view tapes on vcr
I assume that you are coming in on channel 73 because you don't have a line level input on the display (tv) you are using. If that is the case, your options are limited. If you DO have a line input to the monitor, run the VCR to that input and just switch to that input when you want to use the VCR. If you have RF in only, -that would be the screw on type connector- you would have to have the same kind of output on the VCR. Understand, the VCR will be outputting to channel 3 or 4, so you would need a 2x rf switch, and you would have to change from channel 73 to 3 or 4 whenever you wanted to watch a movie. There may be other options, but I don't really know what you have.
Dec 04, 2008 | Sanyo VWM-950 VHS VCR
Had dish network update - can't view vcr tapes
the output of the vcr...
what is it physically wired to?
3-4 switch
1. Set tv to channel 4
2. insert a pre-recorded tape into vcr.
3.press play once to start playback.
4. after a few seconds press play on the vcr for 3 sec you will see a playback picture.
when a picture doesn't appear on the tv screen repeat step 4.
5. press stop to stop playback.
Mar 16, 2008 | Sanyo VWM-950 VHS VCR
VHS Tape on Sanyo Doesn't play on other VCR's
the heads on the sanyo vcr may slightly be out of alignment from years of use.when playing a recorded tape from this vcr to another, the other vcr's alignment maybe right on track thus causing the poor quality.you can possibly try cleaning the heads with a head cleaner or a high grade blank tape,but i don't think this will solve the problem. but you can try.
good luck
wg
p.s also try higher quality tapes to record on.
Feb 04, 2008 | Sanyo VWM-900 VHS VCR
VWM-950
I suggest you get the Tape path cleaned up. Could be dirty video heads or a dirty Control Head. Use a good 'wet' type cleaning cassette.
Jul 03, 2007 | Sanyo VWM-950 VHS VCR
Sanyo DVW-6100 DVD Player/VCR Logo
290 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
