Question about Sony Playstation 3 (PS3) Console
PS3 Turns on but will not load home screen with system options.
I have contacted Best Buy's help line and was informed that the latest update we all had to download is faulty. If you have turned on your PS3 and it loads the black screen with the wavey smoke behind it but will not load the icons for games...system settings... ps3 network...etc... this is the problem caused by the update download. Also, your controllers when you try to connect them without the wireless will not be able to connect to to the system. If you have this problem call this number... Sony will fix for free if your system is within its 1 yr warranty will fix it for free. 1-800-345-7669...its a pain to navigate... I just hit 0 to get to a person to talk to.... please let me know how this goes.
  • Anonymous Apr 03, 2009
    i have the same problem but my warranty ran out and my m8 tried to whack the hard drive into his laptop and it wouldnt format for sum reason..... any help is much appreciated
  • Anonymous Apr 04, 2009
    im gunna buy a new hard drive and ill let ya know how it goes
    President:
  • 2,653 Answers
More than likely your hard drive was corrupted. The easiest way to fix it is to format the hard drive. There are LOTs of different ways to do this but the easiest way is to just hook the hard drive to a computer via a usb cable and then formating it through disc manager.
Here's a quick guide:
http://support.microsoft.com/kb/309000
It doesn't matter what file system your choose, just format it, and then pop it back into the PS3. It will recognise the hard drive as a new drive and then will reformat it again so that the PS3 can read it.
That's it! Problem solved.
The drives are SATA so if you don't have a usb cable you could always throw the drive into a laptop as long as it takes a SATA drive and use an XP or Vista CD and follow the same generall game plan: format the drive
OR you could swap the drive into someone else's PS3, it will do the same exact thing. It will recognize it as a new drive and will format it, then just pop it back into your old PS3 and boom. SUCCESS!!!
That's probably the easiest way now that I think about it.
Posted on Feb 19, 2009
Have red screen
1) Follow this link and download the latest FW update (3.15):
http://uk.playstation.com/ps3/support/system-software/detail/item249463/Update-features-%28ver-3-15%29/
2)Transfer the update on to a USB flash drive/pen to connect to the PS3. Stick it in.
3) Access the PS3 Recovery/Safe Mode. This will help to do so:
http://us.playstation.com/support/answer/index.htm?a_id=1488
4) Choose Option 6 - System Update. Should locate the FW file on the USB pen.
Aug 23, 2011 | Sony Playstation 3 (PS3) Console
Hi all, I can't "sign in" in PSN, it says you you
You seem to have some corrupted data on the hard drive regarding downloads and firmware. No fear this is an easy fix. First off...shut off ps3 so that its in standby. (Red Light On).
2. Hold the power button down; the system will turn on and turn off once again.
3. Press and hold the power button again and keep holding, it will beep as it turns on and then it will double beep. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
4. You will be prompted to plug in your controller via USB and then hit the PS button
You will now have a screen with these options (I have attached a picture of this screen below)
1. Restart System: Restarts the PLAYSTATION®3 System.
2. Restore Default Settings: Reset all system settings back to default.
CHOOSE THIS ONE 3.Restore File System: Checks for corrupt/missing system files.
4. Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
6. System Update: Update the PLAYSTATION®3 System
IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that fixed my blu-ray drive is option 3: RESTORE FILE SYSTEM
I REPEAT CHOOSE RESTORE FILE SYSTEM
After this, it is going to restart and bring up a screen reading something like "you have Corrupted System Data. Your PS will now replace this data" Then you choose continue and that should be it.
This option reinstalls the system files and drivers inside the PS3 with the original ones that are stored on your hard drive. In this case, it replaced a corrupted driver for the blu ray drive thus fixing my issue and hopefully yours!! This option will only replace all system files thus saving you from loosing any data that's stored on your hard drive. Again this option does nothing to your hard drive it reads a file from the drive and rewrites it to the PS3 system. Hope this helps...it did for me.
Dec 15, 2010 | Sony Playstation 3 (PS3) Console
MY PS3 WON'T LOAD ANY DISC! This just happened today, and all of my games are in good condition. I recently got the newest update of the PS3 firmware. All I get is a never ending loading circle of doom. D:...
no worries bud...gotchya covered...first off..if u cant access the ps3 main menu at all then u cant delete the update singularily..if u could access the main menu, just go to the item u updated...(i.e playstation home) and delete it and download and reinstall again...if not...then heres the fix...dont worry it wont erase anything, just corrupted data...which it sounds like u have...k....1. Start with having the system in standby (redlight is on)
I REPEAT CHOOSE RESTORE FILE SYSTEM hope it helps ya!
Unable to down load latest update ,to be able to get on line .....version3.41.... runs really slowly an gets to 8% an then comes up fault has occured ...tried conection test and both ip address an...
If I were you I would download the update on your PC or laptop and place the file on a USB memory stick. Create a directory on the memory stick call PS3 and then inside that directory create a new directory called UPDATE. Place the PS3UPDAT.PUP file in that new directory called UPDATE. Now go back to your PS3 and go to settings, scroll all the way up the top and select system update. The next screen asks you to either update via internet or removal storage. Select removable storage and the PS3 will then update off of your memory stick.
Hope this helps and thank you for using FixYa
Aug 31, 2010 | Sony Playstation 3 (PS3) Console
Every time my friend trys to start home it gos to the loading screen then freezes his system and restarts its self with the 3 beeps. It used to work fine but it only started recently
Hopefully this will help solve your problem:
1. Press and hold down the power button located at the front of the PS3 console, until you hear a first beep, then eventually a second – before the console shuts down, then let go of the button;
2. Now press and hold the button again until you hear a first beep, then a second beep then eventually a quick double-beep, then let go of the button;
3. The TV screen should now display a six option menu, where you can select what’s required, i.e. `Restart System`, `Restore System` etc. `Reset System` should only be used after other attempts with the other options, as your game saved data may be lost. If you play Modern Warfare 2 online, then this won’t be affected as your data is saved on the Sony Server.
4. During any of the above actions, your best having your handset controller connected to the PS3 via the USB cord, which includes pressing the `P` button when required (located between `Start` and `Select`).
These actions should help solve `freeze` problems and others such as update errors etc – which restrict you starting up or playing your console.
Don’t hesitate to contact Sony UK if required, who are very helpful. Their UK number is: 0844 7360595
Good Luck!
Jun 30, 2010 | Sony Playstation Home
My ps3 comes up with an error when i am trying to do the new update for FIFA 10. Comes up with error 8002ae22... can someone help in normal people terms on how to fix this
If you receive an 800 series error code on the PLAYSTATION 3 system, we recommend performing the following steps which may correct the problem.
Install the Latest System Software Update
To check what version of the System Software is currently installed on your PLAYSTATION 3, from the PS3 Home Menu go to Settings > [System Settings] > [System Information]. The system will display the System Software version number. You can check online to make sure you have the latest version installed.
From the PS3 Home Menu, go to Settings > [System Settings] > [Restore Default Settings]. Once you select Restore Default Settings, you will see a list of settings that will be restored. Scroll through them and press the X button to restore the settings. After the operation is complete, you will see the initial set-up screen that appeared the first time you turned on the PLAYSTATION 3 system. You will need to go through the initial set-up process before you can use the PLAYSTATION 3 system.
Jun 28, 2010 | Sony Playstation 3 (PS3) Console
No discs are recognized by the console.
Your BD Blue ray lens is damaged. Try doing a system restore and reupdating the lastest software update. If nothing helps you need to contact Sony via Phone or email. Its most likely your Playstation console needs replacing. If youve had your playstation for over one year then you will have no warranty and will need to buy a new playstation console. You can find cheap options on eBay. :)
Jul 28, 2009 | Sony Playstation 3 (PS3) Console
Not playing any game
Are you connected to the internet with your PS3? If you are make sure you have the latest update. If not you can download the latest update onto a memory stick via your PC and just plug it in to the PS3
Jun 29, 2009 | Sony Playstation 3 (PS3) Console
PS3 Call Of Duty World At War - Latest System Update Error
From the home menu, select icn_settings.gif (Settings) > icn_ntwkupdate.gif (System Update), and then press the x_button.gif (X)button.
Select [Update via Internet], and then press the x_button.gif (X)button.
The system automatically searches for and finds the latest version of the update data.
Download the update data.
If a new version of the system software is found, an update is necessary. Press the x_button.gif (X)button to start downloading the update data.Follow the on-screen instructions to perform the update.
Confirm that the update was successful.After the update has been completed, go to icn_settings.gif (Settings) > icn_ps3_systemsettings.gif(System Settings) > [System Information]. If the [System Software]field displays the version number of the update, the update wassuccessful.
WARNING:
  • Do not turn off the PS3™ system during an update. If anupdate is cancelled before completion, the system software may becomedamaged, and the system may require servicing or exchange.
  • During an update, the power button on the system front and PS button of the controller are inactive.
Jun 22, 2009 | Dmm Call of Duty: World at War
Updating PS3 .PUP file
Update data download procedure
  1. Create a folder on the storage media in which to save the update data.
    Using a PC, create a folder named “PS3” on the storage media or USB device. Within the PS3 folder, create a folder named “UPDATE”.
  2. Download the update data and save it in the UPDATE folder created in step 1.
Notice Be sure to save the update data as noted below. If the data is not saved in the correct way, the PS3™ system will not recognize the update data. The folder name must be in all uppercase letters.
  • File name: Save as file name “PS3UPDAT.PUP”.
Update procedure Notices
  • Do not turn off the PS3™ system or remove the storage media or USB device during an update. If an update is cancelled before completion, the system software may become damaged, and the system may require servicing or exchange.
  • The power button on the PS3™ system front is not active during an update.
  1. Insert the storage media or USB device that contains the update data in the PS3™ system.
  2. From the home menu, select icn_settings.gif (Settings) > icn_ntwkupdate.gif (System Update), and then press the x_button.gif button.
  3. Select [Update via Storage Media], and then press the x_button.gif button.
    The system automatically searches for and finds the update data saved on the storage media or USB device.
  4. Start the update data.
    Press the x_button.gif button to start the update data. Follow the on-screen instructions to complete the update.
  5. Confirm that the update was successful.
    After the update has been completed, go to icn_settings.gif (Settings) > icn_ps3_systemsettings.gif (System Settings) > [System Information]. If the System Software field displays the version number of the update, the update was successful.
Hint
Mar 30, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
2,971 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
