Question about Delta Drills
I CANNOT PULL DRILL DOWN
THE SHAFT IS FREE THERE HAS TO BE SOMETHING SIMPLE TO RELEASE IT. I ACQUIRED THIS FROM A OLD WIDOW OF A DECEASED FRIEND ABOUT 10 YRS AGO IT WAS OLD THEN. TJHANKS, TOM
I CALLED A FRIEND THAT IS A RETIRED TOOL MAKER AND PURCHASING AGENT FOR A MAJOR MFG COMPANY. THANKS, TOM
Posted on Feb 20, 2009
I need help with I am getting no oil pressure from my motor I just rebuilt first time rebuild it is a Chevy 350 out of a C20 pickup can anyone help
You have hooked up a manual test gauge to the oil pressure sensor/sender port and verified you have no pressure? Did you prime the oil pump before you starter the engine?
Jul 13, 2016 | Cars & Trucks
How do oscillating drill presses work? I have an old Craftsman 8 inch drill press with spindle sanding capability, but the spindle will not oscillate up and down.
Did you already read your manual for that drill press?if your manual is available there is an instruction on how the drill press work..I think the problem their is the shaft that can be found at the right of the drill press..maybe the error is that the wiring of the shaft.
Jun 11, 2011 | Craftsman Drills
How do I use a Vermont American #17192 Drill Press Stand? Anyone have an instruction sheet for this? I acquired one from a sale but am unable to figure out how to mount our drill onto it. Thanks.
Here you will see how the drill is mounted in the device. Position (b) around the handle and tighten it up untill drill seats firmly in place. Take a speed square, or normal square and eyeball or measure the drill to see if its straight. Use the alignment adjustment (A) to fine tune the drill to get the drill bit straight and square. Tighten up all the nuts holding drill in device and recheck the drill bit for straightness.. Put your work under the drill, press the trigger and lock into place to get the drill to constantly run without finger on trigger, pull down the press lever to drill your hole... Hope this helps!
Nov 02, 2010 | Drills
Hi, I let a friend use my Bosch 5600 PSE key less
you can't drill counterclockwise the bits are setup to drill clockwise and the chuck would become loose. try using two wrenches to free up the chuck then spray a little wd40 in it it is just bound up
Nov 05, 2009 | Microwave Ovens
My dc927 chuck is jammed fully open and won't move. How can I lossen it. Regards George
Something I would try:
George, look down the center of the chuck jaws with a bright light. It's going to be difficult to see, but there is an Allen head screw down in there.
Taking the screw out, will afford you the opportunity to remove the chuck from the drill. The drill should have a slightly tapered shaft, and the chuck has a tapered hole to match. It might be stuck on tight. Tap on the back side of the chuck, with a wooden block, and hammer.
(Yes, this may require a helper)
Tap on one side, then the other to try to remove the chuck evenly.
With the chuck off it may release pressure on the jaws. It may not.
In this case the chuck will have to be opened up, (Which will release pressure on the jaws), and the jaws reset.
Aug 22, 2009 | Dewalt 18 Volt Compact Drill Kit
Changing front passenger axle
It is fairly simple, Block your wheels and loosen the lug nuts a little, jack your car up until you have the tire off ground, remove tire, remove the center nut on the tire hub. pull the whole assembly uot and away from the car, let the assembly hang down and push to one side, use something to hold it away from work area, fallow shaft until you come to a support, loosen the support. pull, **** hard shaft towards you. it will take a great effort to loosen the shaft but it should pull loose as one piece. get the new one and put it into the same route as the old shaft. look at entry point into the transmmision make sure that the new shaft has been properly seated, you will feel or hear the spline click into place when properly seated. then follow disassembly instructions. Go to the library if you need pictures and detailed step for step instructions. hope this gets you there.
Chevyrat
May 07, 2009 | 1995 Mercury Villager
Removing rear wiper arm 1992 grand caravan
If this is a factory wiper arm look at the area where it hinges. There should be a small hole in the metal. Find a drill bit or shaft that fits the hole. Lift up on the arm, insert the drill bit. When you release the arm it should be raised of the glass supported by the drill bit. Now without pressure applied to the glass you should be able to wiggle it off the shaft of the motor. Hope that helps.
Apr 01, 2009 | 1993 Dodge Caravan
Chuck came off of drill on a Bosch 11236VS hammer drill
Have you pulled the collar to release the pressure on the steel balls. Just pull the collar usually forward and slide on the shaft and then release and twist till it locks. Let me know if I can help further
Jan 07, 2009 | Bosch 11236VS Rotary Hammer
Drill press
Release the belts and check if you can turn the chuck by habd, if the chuck won;t turn, two things could be wrong, 1) the quill bearings are bad or 2) the shaft that runs down thru the quill could ve rusted causing a restriction, if that's the case, WD 40 should loosen it.
Oct 24, 2008 | Delta 15 331 15" 115/230V Variable Speed...
Open Questions:
How fix Delta/Rockwell 15 drill press from chuck wobbling. I purchased a Delta / Rockwell 15 drill press model 15-091. The chuck wobbles. I ordered some wedges to remove chuck.jacobs #6 wedges After soaking in pb blaster I removed chuck with ease with the wedges. must have Now after looking at what is called the spindle I believe...it is wobbling. I wonder if I am looking at an arbor or the spindle? Above this piece is a threaded section that is about 1/2. I thought of maybe getting a jacobs 34-33c chuck to screw onto this. Seems like if the spindle/arbor is wobbling it still would not run straight or be difficult to properly seat it. I do know that some quills come with a slot to fit a wedge for removing the arbor. Mine does not have this. Without a proper way to remove an arbor it leads me to believe maybe it doesn't have an arbor. Seems that I am looking at the actual spindle. I need this drill press for precision work. If you know about this model.. Please Help !!!!! I am stuck. Do I need to buy a whole spindle? If it is in fact an arbor how are you supposed to remove it? I thought if it is an arbor I could take a grinder and cut 2 slots in the arbor. Then take a really thick washer and cut out a section. to make it a u shape then slide the washer into the grooves I cut out. Then use the wedges on top of that. After tapping the wedges I would think it would come free. Unless it is one solid rod with a taper at the end like an arbor usually has AKA the spindle....HELP!!!! I can't find ANY info on this anywhere. I know someone must have worked on these before.
May 05, 2016 | Delta Drills
Drills Logo
102 people viewed this question
Top Delta Drills Experts
EugenesDIYDen
EugenesDIYDen
Are you a Delta Drill Expert? Answer questions, earn points and help others
