Posted on Mar 01, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to reset canon ix 6560
Canon ix 6560
Anonymous
Level 3:
  • Canon Master 32,281 Answers
  • Posted on Mar 01, 2013
Anonymous
Canon Master
Level 3:
Answers
32281
Questions
Helped
7912481
Points
102259
RESET CANON PRINTER
1, Power off the printer
2, Unplug the printer's power cord, wait 5 seconds then plug the power cord back in.
3, Hold the Power button for 6 Beeps
4, Release the Power Button
This will reset the printer and should resolve incorrect cartridge detection problems
2answers
My canon ix 6560 printer cannot recognize the ink cartridge even though i already replace the original cartridge a new one it still prompt on my computer the "cartridge cannot be recognize"..thanks
First, I'm not a Canon Tech.
* Had same problem with my Canon MG3022
* These newer (+2010) printers have higher memory and more control programing built in. Some brands more than others.
* The printer monitoring is very strict and needs to be followed EXACTLY as stated by the monitoring program.
* Another issue is how slow these programs are as they will check everything to see if your following along. Times will depend on your WiFi speed, CPU speed, and if your running other programs in the background (which you are as your trying to print something from Word, Paint, Photoshop, etc.)
* skipping over any point of the ink exchange will lock up the system as it's looking for the old cartridge (which is bad) and trying to establish a new cartridge in it's place. If you don't wait for it to establish this base line then it may see the new cartridge as 'used' and reject it. Yeah I know, frustrating. It's designed to prevent someone from "re-filling" the old cartridge and re-inserting it as "New"
* I've found that if I shut down everything (computer and printer) and restarting the printer with old cartridge. Then as it powers up and goes into "no Ink" error. Replace the cartridge. Hopefully it will accept the newer cartridge. You must give it time to process through the change out procedure (up to 15 mins.) Wait for the ready light then turn the computer on.
* Still problems? Check warranty. Call or go online to Canon.com for support.
Aloha.ukeboy57
2helpful
2answers
How to solve the error of canon iR2016 photocopy system error E003?
How to reset E000, E001, E003, and E007
Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" then Press "Stop" or "Additional Function key" to end service mode or restart the machine.
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
Canon IC-MF6530/6550/6560/6580
No reset procedure is required, replacing the fuser is the only repair.
Canon D860 series
Press Additional Function key and the "#" key in that order. Go to Printer (number 7), select "Set", Select "Printer reset" and press "set".
Canon Printer Support Phone Number
9helpful
2answers
Cara perbaiki ix 6560 error 5100
printer saya canon ix6560, mengalami eror 5100, mhn bantuannya,,trmksh,,
17helpful
3answers
I have a canon mx300 pixma how do i setup the fax
If you have question about reset canon pixma mp450 leave a comment ... (based on default setting using Canon Colour Fax Test Sheet)¹ ... Supported Operating System Windows 7, Windows Vista, Vista SP1 / Windows .... If you have problems to reset canon ix 7000 printer please email me ..... To resolve do the following: ..
E532 in canon np 6560
Hello sir; That's not the staple problem, that's staple shift motor problem, replace it.
2helpful
Ink absorber
A special service software program is needed to reset the internal counter for the ink absorber.
Check here:
http://www.pdfoo.com/result-service-tool-software-resetter-for-canon-pixma-ix-5000.html
9helpful
2answers
old marine
old marine
ZJ Limited
ZJ Limited
