Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Sony 46WT500 green beam ripple
I have a Sony KP-46WT500; blue and red beams work fine, but green bends inwards on the left side towards the right, something like this: |)......|
Also, ripples occur only in the green beam around the bottom 1/3 of the screen (top 2/3 are fine, no ripples). These two problems occur simultaneously about 5 minutes after the set is turned on, regardless of the input used. It is not a graceful degradation, they occur from one moment to the next.
If the TV is powercycled, it works fine for another 5 minutes, thus I don't think it's caused by heat (I'm thinking an issue with a capacitor, but it's just a guess). I don't think the STKs are at fault either, as convergence is fine for the first 5 minutes. Any ideas on what/where the issue could be, or where/what I should look for on the board?
  • p4pike Mar 20, 2009
    Hey there. I have the same problem but mine seems to do that on all sides and center is fine. If i cover the green projector up then the tv is fine and know problem but different color. lol.. pink. mine is constantly like that though even if i turn it on or off. Just wandering if you found the cause and the part to fix it. I talked to a tv repair shop a while back and he told me that there is a problem in the conversion circuit but i would like to fix it myself because it would be cheaper. I bought tv from friend for 30 dollars. Good deal. Worth fixin i think. If you find something or know something please let me know and i will do the same. My regular email is p4pike@rock.com. Hope to here from you soon. Thanks Pete
    Novelist:
  • 184 Answers
Its the convergence output ICs or the solder connections beneath them.
michtech
Posted on Feb 19, 2009
Dodge charger fuse box , where the fog lights relay goes ?Thanks
Cavity/ Fuse /Circuits
1/ 20 Amp Yellow/ Left High Beam Headlight
2/ 20 Amp Yellow/ Right High Beam Headlight
3/ 15 Amp Dk. Blue/ Adjustable Pedal
4/ 20 Amp Yellow/ Horn
5/ 25 Amp Clear/ Headlamp Washer - If Equipped
6/ 15 Amp Dk. Blue/ Front Control Module (FCM)
7/ 20 Amp Yellow/ Fog Lamp
8/ 15 Amp Dk. Blue/ Park Lamp
9/ 15 Amp Dk. Blue/ Non ABS Brakes
10/ 5 Amp Orange/ Starter
11/ 20 Amp Yellow/ Auto Shutdown/Powertrain Control Module (PCM)
12/ - -
13/ - -
14/ 25 Amp Clear/ Powertrain Control Module
15/ 20 Amp Yellow/ Injectors, Ignition Coils
16/ 15 Amp Dk. Blue/ Powertrain Control Module
17/ 30 Amp Pink/ Antilock Brake System (ABS) Valves
18/ 30 Amp Pink/ Windshield Wiper/Washer
19/ 50 Amp Red/ Radiator Fan
20/ 20 Amp Lt. Blue/ Starter
21/ 50 Amp Red/ ABS Pump Motor
22/ 40 Amp Green/ Radiator Fan High/Low
23/ 50 Amp Red/ High Intensity Lighting
24/ - -
25/ 30 Amp Pink/ Lighting Left High Beam/Right Low Beam
26/ 20 Amp Lt. Blue/ Transmission
27/ 30 Amp Pink/ Lighting Left Low Beam/Right High Beam
if this helps please rate 4 thumbs up.
Jan 21, 2011 | 2007 Dodge Charger SRT8 Sedan
Red & Green outlines but only on left/center portion of screen.
Its a convergence problem. You may want to check the site www.tvrepairkits.com. Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to tvrepairkits.com I fixed a philips 60 inch tv in 45 minutes, The convergecne chips were bad thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Aug 18, 2009 | Sony KP-46WT500 46" Rear Projection...
My sony projection tv model # kp-46wt500 has a green and red tint. how can i fix it?
Increase the current flow to the blue color gun. If it is not adjustable it will need replaced and this is a major repair. You can try to reduce the red and green guns and increase the output transformer for a temporary fix, but save up your pennies for a replacement. Have a tech look at it before running out for a replacement because the SONY is the better model projection televisions.
Jun 28, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony kp-46wt500 with no red projector
all three guns red blue and green should be replaced and the flote.
cost could be from $400 to 680 in parts depending on wer you buy them. I would but the parts my self then pay the repairmen to do the install this way you dont get priced up to high in parts cost.
regards,
daniel.
Jan 13, 2009 | Sony KP-46WT500 46" Rear Projection...
Blue Horizontal arching lines, Blue hue at power on
if you take the front cover off the tv, you will see 6 little nobe, the top 3 are focus, bottom 3 are brightness, should be RED-BLUE-GREEN in order from left to right, find the one that is blue, turn it down a quarter turn, should fix the problem
Dec 31, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony 46WT500 Display Issue (Convergence?)
converge chip failing after warm up fairly common
to see
Dec 26, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony KP-46WT500 Red, green and blue lines appearing on screen
your convergence IC;s are out, they cost about $40, if you know how to solder, you can do it your self, if not , I would try to find somone that can, service centers charge about 4 or 5 hundred, after you get the new ones, there easy to find on the board in the back of the tv
Nov 26, 2008 | Sony KP-46WT500 46" Rear Projection...
Help
You need to have the convergence IC's replaced. A repair like this should run you about 300 bucks or so. In most places.
Apr 27, 2008 | Sony KP-46WT500 46" Rear Projection...
Pincushion Picture on a big TV screen!!!
The set has 3 IC's(one for each color)strictly dedicated for the aligment of each color,if one them does not align is because is going bad or is already bad becuase picture can not be adjusted,the IC's can be identify because they are mounted on a heat sink and have the markings STK--- ---,they are all the same and need to be replaced with an exact replacement.If you are familiar with tv service you can replace them,sometimes the new ones need to be aligned from the service menu,you will need the service manual,soldering and unsoldering will be involved,If you are not too familiar be safe and seek the assistance of a servicer.
Nov 03, 2006 | Sony KP-46WT500 46" Rear Projection...
Sony KP-57WS500 Pictures problem
Your Convergence Correction Amplifier ICs have gone bad (STK329-110) They must be replaced along with the biasing resistors
www.electronix.com has the parts you will need plus I would suggest that you have a qualified TV repair person do the installation for you.
Make sure the traces on the circuitboard are good and that the solder connections are good.
But the ICs and resistors need to be replaced.
Thank you,
Shuttle83
Oct 30, 2006 | Sony KP-46WT500 46" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
95 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
