Question about D-Link DI 514 Wireless Router (DI-514)
Cant connect to certain users on the game system
People are telling me i need to switch my router to open connectivity i need to find out how to do that
    President:
  • 415 Answers
Follow the link below that contains the manuak and it will explain how to do that.
ftp://ftp.dlink.com/..._manual_07062005.pdf
Posted on Feb 19, 2009
Cant open setup page
Connect a Ethernet cable from your PC directly to the router and try to open the page 192.168.1.1 with "admin" as user and password.
Nov 30, 2013 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
The playstation 3 does not work with certain games saying there is an error on the router (error code: 80710723) How can we open more ports on the router? Thanks for your help
Generally what happens is that progress will stall whilst you are trying to update the firmware or software/games on your PS3, causing it to be corrupted. Your console is then unable to function properly, and you are left trying to "pick up the pieces" as it were. The PS3 error 80710723 is one of these system update errors, and is often experienced by gamers who use wireless connections to update their firmware or games.
So how can you fix PS3 system update error? Here are a few steps you can take to try and fix the 80710723 error code yourself.
  1. In your System Options/Network Settings you need to go and disable a setting called "media server". Doing this has been reported to fix the PS3 system update error in a number of different cases.
  2. If you are using a wireless network connection then switch to a wired connection and attempt to update your console. Wireless connections can have interference, or fail from time to time. Therefore it is better to use a wired Internet connection where possible.
  3. As a last ditch resort you can actually download the update from the Sony website onto your PC, then load that update onto a USB stick and plug it into your PS3 and carry out the update process from there. However, it is best to actually try and fix your connection problems first.
Jan 04, 2011 | Belkin N1 Vision Wireless-N Wireless...
Xbox live connection error
Make sure your NAT is set to open. If it's restricted you may not be able to connect to alot of your friends or games. You can change this by accessing your router through an internet browser.
Apr 10, 2010 | Actiontec GT704WG Wireless Router...
I am tryying to connect the console to WFC to play with friends and gives error code 61070
Please follow the specific guidelines...::
  • The error may be caused by a basic setting on the router that needs to be adjusted (such as the channel).
  • Or you need to disable the firewall of the router.
  • Some games may need certain settings on your router enabled or disabled to allow a successful connection with other players. This can include UDP and firewall settings that will vary from router to router.
In case of any other assistance u can revert back to me...
Regards ,
HARSHIT
Oct 11, 2009 | Nintendo Wii Console
Cant connect to online game servers
Check your online gaming server to see what ports or sites need to be opened up. The RTFM, Read The Flippin' Manual. Here's a link to the manual for your router.
http://www.zhone.com/support/manuals/docs/62/6218-A2-ZB23-10.pdf
Good luck! :)
Sep 23, 2009 | Zhone (6218-I2-200) Router
Having problems connecting on my xbox 360 using this router
if you are positive that you have all the correct ports open, it could be that the other person has their closed.
May 26, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I cant connect internet through hardwire(ethernet) but i can connect to internet by wireless... and it keeps on telling me Unidentified network.
Not really ...
1 thing that should not be in common between your wireless and modem is GATEWAY...
Your default modem gateway will be 192.168.1.1
change your router gateway to 192.168.2.1 or 192.168.3.1
to do this ...
1. click on start menu , type cmd , enter
2. COMMAND PROMPT dialogue box opens .
3. type . IPCONFIG
3. note your Default gateway.
4. open internet explorer
5. type your default gateway in browser address
6. it will prompt you to give user ID and password .
7 Your USER ID and password is ADMIN .
8. your router setup page opens .
9 change your local IP address to 192.168.3.1 .
10. Check mark on BRIDGING MODE .
11. Disable and enable your ethernet .
12 . now try connecting to INTERNET .
It should work . .
May 22, 2009 | D-Link Vonage-enabled Wireless Router...
Belkin 54 g wireless router....cant find on the net. need to port forward to host blizzard.net games HELP!
Make sure your private IP address is statically set.  Your public IP address is obtained from your ISP and is what other users will be connecting to.  You can not manipulate your public IP address so if your ISP is running DHCP, it is very possible that your public address is changing.  Also if you are frequently disconnecting your modem, it is possible your ISP is leasing you a new public IP address each time.  So try to keep things as static as possible.  As far as the battle net stuff.
Diablo, Warcraft II Battle.net Edition, and StarCraft:
Allow port 6112-6119 TCP and UDP out and in
Diablo II:
Allow port 6112 TCP out and allow established sessions in
Allow port 4000 TCP out (realm games)
Allow port 4000 TCP out and in (hosting open games only)
Warcraft III:
Allow port 6112 TCP in (hosting custom games)
Allow port 6113-6119 TCP out and in (hosting custom games if you've changed the default port in the Options/Gameplay screen)
If you are still having problems after you open up the required ports, try opening 116(TCP) and 118(TCP). I don't really know if these ports are required or not.
I have had people tell me that opening up those two ports have helped them connect to battle.net.
Hope that helps.  For manipulating ports in your router I suggest consulting your user manual, or online FAQ.  Save your router config before applying any changes, and always remember, opening up ports subjects you to different types of security threats so be aware that is a risk you are taking.
Mar 12, 2009 | Belkin Computers & Internet
Cannot connect
Sounds like a problem with your network are you both in the same residence? On the same router or switches?
Aug 04, 2007 | Microsoft Xbox 360 Console
Breezenet wbs ds 11
Hi, i cant really give you a exact reason as i aint used that particular model, things i have found that can cause interference to wireless routers are, alarm systems house & car, Microwaves, certain models of cordless phones, and these are only some, and i have found only certain ones conflict on certain channels and disconnect you on & off. sorry cant help anymore. John
Feb 27, 2007 | Alvarion BreezeNET WBS-DS.11 (871100)
D-Link DI 514 Wireless Router (DI-514) Logo
24 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
