Question about Panasonic KX-T7730 Corded Phone
My phone wont jump to the next line
Hi, i have the panasonic kx-t7730 phone I have two lines on it one is also a fax line. my problem is in the pass when you called line one and someone was on line one it would jump to line two, but now if line one is busy it is not jumping to line two it just rings and rings. please help me asap thank you
  • 30 Answers
That is up to your telephone service provider. call them and info them off the problem. tell them that you want a busy forward only to line 2. that way after 4 rings it will jump to line 2.
Posted on Feb 21, 2009
Can I connect Panasonic KX-T7730 to the normal line as other phone are connected?
What? A 7730 is a Panasonic system phone that connects to one of about 18 different Panasonic phone systems. You can connect a single line set in parallel with the PT if you tell it so in software.
Carl
Sep 05, 2011 | Panasonic KX-T7730 Corded Phone
How to turn on caller id on Panasonic KX-T7730. How to set outside line on Panasonic KX-T7730 so that a Panasonic cordless phone can call out
CID is part of the phone system and requires a -93 card and system programming. Panasonic makes different systems that the 7730 phone works on, but it was first delivered with the TA-824 or equivalent system. It also needs to be programmed to tell it how may lines are equipped. Then, when you dial "9" to get an outside line, it will grab the highest WORKING line, instead of just the highest line.
FInd the model number on the system cabinet and do an internet search for the installation manual of the system.
Carl
Sep 01, 2011 | Panasonic KX-T7730 Corded Phone
Hi, i have a Panasonic KX-T7730 phone. And i have two telephone lines (Line 1 and Line 2) to receive and make calls. I've inaccidentally pressed something and now Line 1 is not working - I am unable to...
From the idle phone press PROGRAM line 1's button and dial 0 1 STORE. That puts line 1 back under the button.
Press PROGRAM or pick up the handset and set it back down to exit programming.
Carl
Apr 19, 2011 | Panasonic KX-T7730 Corded Phone
Hi I have a panasonic KX-T7730 and I need to connect it to my linksys PAP2T Device. but I haven't Voice Over It. can I use this device with KX-T7730?
The 7730 is a Panasonic Analog System phone. It plugs into a Key Service Unit and the line port plugs into the PAP2T device. Model numbers like KXT-A624/824 are examples.
Carl
Feb 18, 2011 | Panasonic KX-T7730 Corded Phone
Hi, I have a Panasonic kx-t7730 phone and the caller id does not work... cannot see any numbers for incoming calls on any line and we have three lines ... How do i turn on caller id ??
Since you have 3 lines, that tends to be a TA series phone system. Do you have CID hardware? It's a card that fits into a card slot or rests in the cover of the Key Service Unit and ends in 93. (62493, 82493)
Start with CID service, a card, and some programming.
Carl
Dec 21, 2010 | Panasonic KX-T7730 Corded Phone
Hi I have panasonic kx-t7730 and I have a problem. We have two lines but only rings on switchboard. We also Use cordless panasonic phone but it does not ring unles i transfer to it. I have already done...
In a TA series, the ringing is programmed in system programs 408-410. You go to the main phone, enter system programming, and select those options and turn on ringing per line and per extension.
Carl
Sep 03, 2010 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 CORDED PHONE
my telephone is lock forget pasword
Oct 14, 2008 | Panasonic KX-T7730 Corded Phone
Need to program pf buttons on kx-t7730
Press Program Button
Press Button to be Programmed
Dial 1 - Plus extention number to be stored on button
Press button directly under 'ENTER'
Feb 12, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
124 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
