Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Potent smell from fridge when turned off...
I borrowed a friends fridge and bought another one recently, I switched it off after cleaning it out but there is a strong smell now coming from inside if I open the door it catches your breath.
Can gases leak and be harmful? If so what signs should I look out for?
  • bnev Feb 24, 2009
    There is a foul odor coming from my refrigerator. I can smell it when the door is closed and really bad when it is open. There is no old food in it.
  • 51 Answers
Refrigerant is heavier then the air we breath. By knowing this, I believe if you did have a leak it would settle to the bottom of your unit. One thing you may smell that could be caused from your unit is burnt plastic. If you smell a burnt plastic smell then some wires may be burnt. To answer your question as to the danger of breathing the gas. It is harmful to inhal refrigerant. Since it is heavier then the air we breath, it displaces oxygen. Please let me know if I can help with anything else.
Posted on Feb 19, 2009
  • 410 Answers
Refrigerant gas can be harmful in high concentration but a regular home refrig does not have enough refrigerant to be dangerous unless directly inhaled at the leak ( it would disipate faster than it ould build up) plus refrigerant is odorless and colorless so you probably wouldnt even know if it was leaking.
Your odor is most likely from a missed food item still in the frig or something that altho cleaned up left an odor behind. the most common culprit is citrus fruits. when they go bad they will leave a gaseous smell behind.
thanks for using FixYa hope that answers your question. Peyton
SOURCE:
Hotpoint mistral fridge freezer flashing EE. I don't know what it means. Both fridge and freezer still seem to be working.Do you know what needs to be done?
It's probably timed out on defrost, take everything out (borrow a neighbours or friends freezer and transfer food) switch off, do a thorough manual defrost and check all pipes etc are clean and clear, (and if you are able clean and vacuum around the back while it's off to get rid of all the dust on cooling coils)
it'll prob be ok after that.
May 08, 2014 | Refrigerators
Whirlpool SXS.....1. compressor cooling fan quit so fridge and freezer stopped working. 2. replaced cooling fan and fridge and freezer working again. 3. Now the fridge and freezer works but runs nonst
Check to see if the sensor in the freezer compartment is encased in ice. If so, do a complete defrost and restart the unit. Another possibility is a bad thermostat and/or sensor.
Jul 25, 2012 | Whirlpool Refrigerators
How to get rid of fish odor
There's a filter at the back of the fridge honestly u wud not believe the stuff that it stores once u clean that the smell goes in a few days completely.
Feb 17, 2012 | GE Refrigerators
I have magicmix compact 3100 which I don't use very often. Recently, I let my friend borrow it, and I think she might have burnt the motor. It does not do anything when I turn it on. There is evidence...
I hate to say this but it probably is not worth fixing. The burned smell could be from several different components depending on just what it smells like. It sounds like you may have a burned out transformer if you have no life at all or something went hard enough to take out the fuse.
I would look around to see what a replacement microwave will cost. Generally the compact ones are fairly inexpensive to purchase new. $40-$75 and you will pay for more than that for parts plus labour.
Sep 12, 2011 | Microwave Ovens
The fridge and freezer smell like a dead animal. cleaned the inside with bleach but still smells for weeks. model w10212088
There are two reasons for bad smells. 1. Long time not being used. 2. Lack of cleaning inside compartment.
Solution: Unplug fridge. Keep open fridge door. Dip a dry cloth in soap water and start cleaning each and every compartment. Keep freezer door also open. And then clean with another dry cloth. Keep both doors open for nearly 5 hrs. It will be enable fresh air to **** the smell inside fridge.
After 5 hrs close the fridge and run on empty for one hour. Keep food items after one hour. Please keep all food items closed vessel. Not only it's avoid odor but also be hygienic.
If you use to keep fish items in freezer, clean fridge once in a week.(Spray roo spray in the room when you keep fridge door opened. Don't spray into fridge.)Helpful.
Jan 30, 2011 | Whirlpool Refrigerators
Freezer got unplugged, meat spoiled, freezer cleaned, smell remains. What can we do to get rid of smell?
I have found that the best cleaners for removing left over odors are citrus based cleaners. They help to neutralize odors and prevent re-occurrence. You could also use a diluted bleach as well to sanitize the inside. Make sure it is not too potent or the bleach odor will overcome the bad odor in annoyance.
Good luck!!
Jun 15, 2010 | Kenmore 8.8 cu. ft. / 249 liter Chest...
BAD SMELL COMING FROM UNDER MY WHIRLPOOL SIDE BY SIDE FRIDGE. I SMELL IT WHEN THE FAN BLOWS. IT SMELLS LIKE URINE.
check its not the drained ice water which collects on a pan over the compressor. the compressor heat is supposed to evaporate it .that foul smell might be due to that.
if that is the case ,switch off fridge , clean , dry , the pan & see .
May 31, 2008 | Whirlpool Refrigerators
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
589 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
Jimmy
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
