Question about Panasonic DP-C322 Copier
We received a Panasonic DP-C322 but can't get it to do anything.
It seems to be stuck. The status light on the front middle is yellow and it won't leave the Print function no matter what buttons are pressed. It wants some kind of user code, but we were not given any. Is there any way to manually reset the machine/codes and start over from scratch?
  • 40 Answers
You can deactivate the department counter in F5-47
Posted on Apr 19, 2011
    Champion:
  • 224 Answers
The codes will need to be de-activated in service mode, a technician will need to be summoned
Posted on Mar 30, 2010
Panasonic workio DP-C322 will not print yellow
replace the yellow ink cartrdge. go into menu and clean up
May 07, 2012 | Panasonic WORKiO DP-C322 Printer
Have just installed Windows 7 Ultimate and downloaded/installed the driver for Panasonic DP-C322. After successfully installing, I printed a test page that consisted of 100's of pages, some blank and...
The "test" output should have been one page.
If the printer properly interpreted the data-stream that it received, it _would_ have generated just that one page. However, if the printer is not "interpreting" the data-stream, but instead is printing it, character-for-character, then you could have gotten the mountain of output that you got.
Turn the printer off. Turn the printer on. Try again to print your own, small, "test" page.
May 05, 2011 | Panasonic WORKiO DP-C322 Printer
Panasonic dp-c322, "replace black toner"
This model estimates toner usage based on dot count.
You can reset the counter by pressing "function" key, then counter view. Scroll down near the end and you will find toner counter reset. Select "k".
Feb 15, 2011 | Panasonic DP-C322 Copier
How can I get a Panasonic DP-C322 copier/printer to print with full functionality from a MacBook Air running OS 10.6.6? I was able to get it to print by entering the IP address but only using a generic...
I'm assuming you have the PS option and firmware in the copier.
Just checked Panasonic's site.
http://panasonic.net/pcc/support/mfp/dp-c322/ps/download.html#02-4
It appears 10.5 is the highest Panasonic currently supports.
You can try the 10.2-5 drivers.
Feb 09, 2011 | Panasonic DP-C322 Copier
How can I set up email addresses and save them for later use model DP-C322 Panasonic
yep!
first you must have smtp server (for sending email)
and pop server (for receiving email) running on your
network.
second, turn-off you dns settings and set all network
parameters as IP Address (host, smtp server, and
pop server ip address)
that's it!
May 20, 2010 | Panasonic DP-C322 Copier
I need to learn how to scan documents on my dp-c322 copier
I assume that your copier is set up on the network. First you need to install a program called Panasonic Communications Utility on your PC which can be downloaded from www.panasonic.net. After the program has been installed and configured a blue tray will appear on your taskbar close to the time. Double click on the tray and set a name. On the copier press the scan button and scroll down until you see your name. Press start and the scan will begin.
Mar 23, 2010 | Panasonic DP-C322 Copier
Scanning to EMAIL on Panasonic DP-C322
Incorrect SMTP Server IP Address is
set.
No email application is activated on the
Mail Server
Apr 08, 2009 | Panasonic DP-C322 Copier
Panasonic DP-C322- prints envelope addresses upside down
Set it for one setting and turn the envelope to suite --OR-- make the printiing preferences changes in the word processor program that you're using.
Jan 13, 2009 | Panasonic Workio DP-4530 Copier
Panasonic DP-C322 Copier Logo
187 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
