Question about Whynter FX-6SB Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D
Need a handle for the hot water on a YLR-5-87H3 WATER DISPENSER
THE RED HANDLE HAS BROKEN AN NEED A NEW ONE
  • infotek Mar 17, 2009
    need a new cold water handle for the YLR2-5-87H3 water dispenser. Anyone know where to find one?
  • Anonymous Mar 27, 2009
    exact same problem with hot water handle- cant find replacement...
My water cooler was made for Sunbeam by Prestige Home Comfort of Canada. 1-877-383-6399 Mon thru Fri 8:30 am - 5:30 PM ET to order parts or service@limagehomeproducts.com to contact
Posted on May 30, 2009
Hot water dispenser does not dispense well
Most likely is the faucet/tap is broken inside and does not lift properly as the handle is raised. You can get a new tap which is easy to replace from your local Bunn distributor.
May 17, 2014 | Bunn Dual® (20900.0011)
Hot water not dispensing
I ve glacier bay hot/ cold water dispenser - new product. Cold water is coming but no hot water. Water is not coming. What have I to do it is a week old machine.
Nov 20, 2013 | Vitapur Water Dispenser. Hot, Room and...
Sunbeam hot/cold water dispenser is leaking from looks like copper tubing that goes to tank. Model # ylr-5-87h3 what could my problem be
Broken solder connection.
Continual expansion and contraction of metal due to hot and cold extremes will cause metal fatigue. The most vulnerable place is at the join. Other places can fail, but usually the solder join will fail first.
Buy another one and support economy.
Make sure next unit is connected to cold water line, and not hot water line. If hot water dispenser is connected to Hot line, then it will cause water heater to run each time water is drawn through dispenser because cold water immediately enters tank.
http://waterheatertimer.org/Water-heater-dip-tube.html
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html#h-c
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#pot
You might also consider installing small tank under counter. Tanks are less glamorous than hot water dispensers but tanks are more reliable long term than instantaneous water heaters.
May 28, 2013 | Water Heaters
My one month old Calorah Quick&Hot Faucet just started spontaneously spraying hot water and sputtering air without anyone turning on the handle. When I run the water, there are bubbles in the stream...
it sounds like it may be an overheat problem. I am not familiar with that unit itself. but the condition you describe could be caused by the heater boiling the water and then having to blow off the excess pressure. The company's website had a broken link to the spec sheet.If you have the manual look under troubleshooting. Or if they don't have a section like that try lowering the temperature.
Jun 10, 2011 | West Brass NEW Oil Rubbed Bronze Instant...
How do install the hot water handle for model ylr2-5-24h2
i have problems with hot water, the handle is broken
YLR2-%-24H2
Dec 09, 2010 | Whynter FX-6SB Free Standing Hot & Cold...
New Westbrass water dispenser does not have the lines marked "red" or "blue" as described in the directions.
This faucet is the hot only version so it has two copper lines and one Santoprene rubber line. The copper line directly under the handle is the inlet from the wall - the second copper line attaches to the hot water tank by the corner. The Santoprene line attaches to the middle of the hot water tank. This faucet cannot be installed without the hot water tank.
Jun 13, 2009 | West Brass NEW Oil Rubbed Bronze Instant...
New Saeco Odeo Go has solid red exclamation mark, doesn't budge
You have to 'manually' prime the pump: When the red exclamation mark shows, press the water switch on the right side (the picture of the water drip), then open up the steam nozzle and let the machine pump hot water into a cup until the red light goes out.
Jun 11, 2009 | Saeco Odea Go
The plastic handles that dispense the water are broken
Where can I buy the spigets for a Sunbeam water cooler. I need one for hot and one for cold water. These handles are not strong enough plastic to last the lifetime of the unit. They should be made from metal. If the taps on our kitchen sink was made from plastic you can imagine how long they would last.
May 27, 2009 | Sunbeam Refrigerators
Whynter FX-6SB Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D Logo
2,995 people viewed this question
Top Whynter Water Filters & Coolers Experts
Tom Chichester
Are you a Whynter Water Filter and Cooler Expert? Answer questions, earn points and help others
