Question about Sony DVP-CX875P DVD Player
I have the sony dvp-cx875p. The player attempts to read a disc and fails, trys to flip and says cannot flip goes on to the next disc and then the next until it display on the lcd and the screen c:32:00. Any idea what this is?
  • 1 more comment
  • jasonbowen2 Feb 20, 2009
    I will be checking on it later today.
  • jasonbowen2 Feb 24, 2009
    I had to replace the lens unit because the disk would not spin. However the dvd will play disc but at times has problems loading the disk into the lens chamber.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    It is failure of optical lens.
    First attempt ti clean it with CD Cleaner, still no joy, then unplug unit from AC outlet, take off its cover and clean lens with good quality cotton bud.
    Last option is replace optical lens.
Directv code for sony dvd
20533,21533,20864,21033,21070,21431,21536 the setup codes for dvd/dvd-r players try 1 or all of these
Oct 17, 2011 | Sony DVP-CX875P DVD Player
All of the sudden our Sony DVP-sr200p dvd player is not loading our dvd's, it is stating "cannot read disk". Any solutions?
use soft cloth to clean the disc.
Examine the disc for any cracks or scratches that might be interfering with playback
Attempt to play another disc.
If another disc plays in the DVD player, then the previous disc is faulty.
If still the same. try to unplug for 3 hours. if the same. check sony.com/repair for service option
Oct 17, 2010 | Sony DVP-SR200P DVD Player
Sony DVP-CX995V "cannot play"
you can clean the motor by the back side
Oct 05, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Sony DVP-CX995V 400 disc DVD Player wont read DVD-
After variety of different tests and findings I have resolved this issue. It appears that the DVD burner was not in good working order and the DVD player was not at fault. Thanks you to all who answered and responded to my problem. Many thanks.
Aug 18, 2009 | Sony DVP-CX850D DVD Player
Cant play All DVD - Band of Brother Has 2 Part on A Single DVD Part 1 Part 2
There is a button labeled FLIP on your remote control. It is on the far right column, and it is the fifth button from the top. It is also the first black button on the remote.
There is also a FLIP button on the front of the unit in the top right corner. It is white. When you push it, it lights up orange.
If the unit attempts to read on side of the disc and fails, it will rotate the carousel 180 degrees and automatically attempt the read the other side of the disk.
May 20, 2009 | Sony DVP-CX860 Multi-disc DVD Player
Sony player dvp-cx850d won't read cd or dvds. need to reset
This is not a problem that a reset will resolve. If you can gain access to the lens, try cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, the spindle motor may be defective. This is the motor that turns the disc. Once a disc is recognized as being loaded, the disc is spun up. If it does not get to speed fast enough, it will fail to read.
The bottom line is that without seeing the unit, I can not state exactly which scenerio you have here.
If the cleaning does not resolve the problem, I would suggest you request a detailed estimate from an authorized Sony service center.
Dan
Mar 10, 2009 | Sony DVP-CX850D DVD Player
Sony CX995v "Cannot Play" message on DVDs but plays CDs O.K.
Hi...
The laser goes thru a different lens arraignment for DVDs.
Take it to a TV shop and have them "blow out" the laser assembly with some CO2 and clean the lens.
Jan 22, 2009 | Sony DVP-CX985V Multi-disc DVD Player
Won't read disc
The laser lens in your CD might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more.
Dec 04, 2005 | Aiwa NSX-A115 Shelf System
Sony DVP-CX875P  DVD Player Logo
108 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
