Question about RCA D56W20 56" Rear Projection Television
Rca 56" has three blinks
Rca d56w20b has three blinks with a squealing sound and i have already replaced the flyback
  • 1 more comment
  • Four20beats1 Feb 19, 2009
    I have one ordered. looked at a few other posts and it sent me in that direction. I also called a local repair shop and thes said it would make the squealing noise i am hearing. I will let you know how it turns out.
  • Four20beats1 Feb 20, 2009
    no it is a c5588 or a 2sc5588
    I have got it ordered from mcm newark. we deal with them all the time at work.
  • RCA Master
  • 5,138 Answers
Have you checked the hori output transistor bet it is shorted .
Posted on Feb 19, 2009
  • ladywinn
    ladywinn Feb 19, 2009
    Part# NTE2324.
  • ladywinn
    ladywinn Feb 20, 2009
    Go to ACME you can order it there or call 1-800-575-9833
I believe that I have a HV problem but need some direction? Initial problem was smell and a pop noise resulting in three LED power on blinks with a squeal.
My sony did the same thing and worked fine after replacing the bulb. A pop sounds followed by a squeal is what I heard during and after the bulb blowing out. I hope this helps. And the red light flashed similarly.
Dec 12, 2014 | RCA D52W20 52" Rear Projection HDTV-Ready...
When power button pressed get three blinks accompanied by a squeal with each blink. I replaced capacitors CP 130, CP 120 and CP 114. I removed CP 150 and verified it good with meter. I replaced fly
Your Set Is In HV Shutdown,Probrably Caused By A Shorted Flyback Transformer & Horiz Output Transistor,With That Model Rca, These Items Are All On One Separate Module Or Board,Which Can Be Purchased Seperately..
Sep 24, 2014 | RCA D52W20 52" Rear Projection HDTV-Ready...
Where is the horizontal output transistor exactly?
So Far You've Done Very Good, The Horiz Output Is Located Very Near Or On The Flyblack Panel, It 's Usually A Rectangular Transistor Mounted To A Very Large Silver Like Heat Sink ..It Does Sound Like It's Shorted, But If Not,Check The Focus Divider Or Hv Tripler..
My RCA D52W20 --> turns on sometimes, when it does, it blinks once, slow, and then after the 1 slow blink, blinks 9 times fast. now, i dont know whats wrong but sometimes the tv wont even blink to show...
Sounds like the Flyback needs resoldering then replace the Three caps CP150, CP120, and CP114. You can get the repair kit by that same name from the kit also contains the CD with instructions.
Mar 28, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 56 inch rca that blinks three timeswith a humming noise but wont turn on
The 3 blinks (an error code) and the hum (most likely from the flyback) indicate that the flyback transformer is bad and needs to be replaced as the simple way of putting it (fairly common problem with projection tvs). If you plan on doing it yourself, then you should have some electrical expertise since working in a projection tv like this can be very dangerous otherwise I would go through the local shop. Let me know how this turns out for you.
Jul 18, 2009 | RCA D56W20 56" Rear Projection Television
RCA HD52W59 Power button lights three times when pushed and unit makes squealing noise each of the three times the light comes on then nothing. No power, no light, etc...
replace the flyback which is the 270125 flyback. You can get the 270125 Flyback repair kit at the following link which contains the flyback plus detailed instructions on CD
Jul 17, 2009 | RCA HD52W59 HDTV Projection Television
Comes on and blinks three times, hold in on 3rd time
It sounds like youre describing a RCA or GE tv with the ITC222 chassis. If so replace the flyback and CP150. If I had your model number and chassis number I could assist with the flybacks part number for you
Jun 09, 2009 | Televison & Video
RCA F32450 ATC113 chassis Dead & Squealing
IHVT # 257805 or ASTI 2078 = 20.00.......................T.
Dec 02, 2007 | RCA F32450 32" TV
RCA D56W20 56" Rear Projection Television Logo
220 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
