Question about Rangemaster Proffessional 110 Gas Kitchen Range
Rangemaster 5331 double oven, oven's dont turn up
Both oven's ignite but the flames stay low, is this the thermostats or something else
  • adrianf Feb 20, 2009
    seem to have same problem - on one oven only - flame stays low despite setting
SOURCE: Rangemaster 110
i have had the same problem with rangemaster 110, r/h solinoid,i purchased a replacement from an authorized dealer, same fault within 6 months, i had to purchase a replacement so they could check the first replacement was faulty before they refund my money. now the second one has failed. so we have decided to use it until the l/h oven gives up (hopefully sooner than later) then we will be buying another double oven, but it will not be rangemaster.
delboyp
Posted on Oct 28, 2008
  • 833 Answers
SOURCE: Oven will not respond
The knob won't have any effect on the flame size.  The knob controls temperature.  If you're referring to the pilot light staying on and then the main flame not going on...that's another problem.  If the main flame will not go on, the assembly that controls the main flame is likely defective.  If the unit has a thermocouple, you might change it out first.  Sometimes, that's all that is needed and they're cheap.
Posted on Nov 26, 2008
  • 160 Answers
SOURCE: Gas oven
Its the flame failure device faulty (FFD)
Posted on Feb 22, 2009
57 varieties
  • 1653 Answers
SOURCE: my rangemaster cooker lights on ignition but only
It will most likely be the thermostat that is faulty and will neeed replacing. If it wwas the safety device then you would not get any gas at all.
Posted on Oct 02, 2009
  • 160 Answers
SOURCE: i have a leisure rangemaster 110 double gas oven
the flame safety device need replacing (FFD)... this lets the full gas through when flame is sensed... safety 1st as a gas engineer will be required..
Posted on Dec 18, 2009
Oven flame on right hand oven doesent increase when dials turned up
The OVEN flame size is consistently one size.
The thermostat simply stays closed longer when asking for higher temperature in the oven.
Sep 22, 2010 | Rangemaster Classic 110 (Dual Fuel) Dual...
I have a leisure rangemaster 110 double gas oven the left oven stays low i have tried cleaning jets but this has no effect can you suggest a cause
Dec 18, 2009 | Rangemaster 110 (Gas) Kitchen Range
Oven is igniting but not getting hot
got the same problem on a rangemaster 110 - just had the comet engineer look at it - changed the thermostat and the spark generator - no effect. poss the flame failure device or the timer.
Nov 15, 2009 | Rangemaster 110 (Gas) Kitchen Range
My rangemaster cooker lights on ignition but only stays on low flame is it the thermostat or safety device
Oct 02, 2009 | Rangemaster 110 (Gas) Kitchen Range
My g70m oven ignites and stays lit but it won't heat up it stays the same all the time
Hi
You have one of these faults:
Faulty FSD (Flame Safeguard Device). When you turn your oven on the FSD lets a small amount of gas through, after about 30-90 seconds the FSD is satisfied and allows more gas to come through......this then moves over to the.......
Oven Thermostat, this will sense the heat from the oven and adjust the temperature accordingly.
If the flame doesn't go high after 60 seconds it's the FSD, if it does but then it goes low and fails to increase then it's the Thermostat.
Either way you need to get a qualified gas engineer to look at it.
I hope this helps
Steve :)
Apr 05, 2009 | New World G70m Gas Double Oven
Gas oven
Nov 30, 2008 | Rangemaster 110 (Gas) Kitchen Range
Nov 23, 2008 | Rangemaster 110 (Gas) Kitchen Range
Pressure of flames in Cannon gas oven
HI thanks for your question. the part that's at fault, is the igniter. it glows but not hot enough to ignite all the gas. replace the igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 09, 2008 | Ovens
Rangemaster 110
Reading the user manual, it states that the flame initially comes on low, until it is "sensed" by the flame sensing device. This to me sounds suspiciously like the flame isn't being sensed and so never gets increased to the normal level.
I've not had time for a proper look at it.... but from a quick glance this morning this looked like a "flame rectifier" probe next to my burner (as we commonly use in boilers to sense if the gas burner is lit). This is just a metal probe. They send a high-ish AC voltage signal (Sine wave) from it, through the flame, to the earthed metal case. The flame acts like a diode (yes it really does work !) and simple electronics detects the change in the applied signal (rectified) due to the flame. I know from personal experience they (the probes) get coated with crud (carbon, etc) and need a good clean. I suggest you try cleaning both it and the metal area opposite it. If necessary the probes metal tip could be GENTLY rubbed with very fine Emmery cloth, etc, if badly coated.
Other than that, if it is sensing the flame, then it must be the gas control device (solenoid valve ?) that is jammed, blocked or just defective.
Simples......
Dec 18, 2007 | Rangemaster 110 (Gas) Kitchen Range
Leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
Nov 13, 2007 | Ovens
Rangemaster Proffessional 110 Gas Kitchen Range Logo
61 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
