Question about Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony kv36hs500 does it have a focus ajustment? i had the high voltage chip replaced t v doing fine just not as clear as it was.
  • Anonymous Mar 08, 2009
    my tv showes green and purple color on the screen
  • 10,594 Answers
Yes, It has focus control at side of fly-back transformer. Rotate focus control in both sides to get maximum sharp focus.
Posted on Feb 19, 2009
Sony projector tv trusurround
There are two possibility for this fault. The first one is, with its CRT base connector sockets. If this socket is bad, an out of focus picture will be displayed at first switch ON, which will gradually gain focus after some time, say, 15 to 30 minutes. If the humidity of atmosphere is high, it might take more than this specified time above, and might take up to an hour or so. Replace the CRT base sockets, and check first. The vertical rolling might be due to insufficient supply voltage from the power regulator board, and should be checked after you have rectified this out of focus problem.
If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. google.com/+GopakumarGopalan
Nov 02, 2013 | Televison & Video
No Picture and Lttle red light next to power buttons blinks for about 30 seconds
First thing to do is reset ( see link below) and see if it resets otherwise if problem continues it will need some work
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits. There are some common breakdowns in the High Voltage circuits in this set. One is the flyback transformer. Another is a small high voltage capacitor in the sweep corrction circuit. There is a cap that goes open in a high voltage circuit (C6532) which needs to be replaced.
Support bulliten by sony
Thread on your model
Nov 20, 2007 | Sony FD Trinitron KD-36XS955 36" TV
Trying to pull out the convergence board so that I can replace the chips. How does the two red wires in the corner of the board come off? I'm trying not to break it.
Hi Kelso73,
These red wires can be remove by opening the front speaker grill. One of the wires is connected to the focus control and the other one is connected to the high voltage module.
Let me know if you need further assistance.
Aug 14, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
I have a sony trinitron kv36hs500 tv which power problems
try making resolders on power supply ckts, try also adjust screen voltage,, check crt socket,,if all of this dont solve it, try to rejuvinate the crt.
Feb 27, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Picture will not remain in focus.magic focus feature fixs temporaily then condition returns
There is usually 3 flyback (hi voltage transformer) that gives the high voltage to the tube over the red wire.
On the flyback you got two adjustment. Focus and ''brightness'' ajustment. Sometimes, you can ajust from the back and they leave opening for the screwdriver entrance, otherwise, you remove the chipboard panel and adjust those screw. It usually write wich ajustment is focus directly on the flyback. As you can see its a bit of a technical ajustment, plus you have to do it when the tv is running and with the voltage on. Needless to say that its pretty easy to do a short in the electronics circuits. I hope you have someone handy with basics electrical skills. Also this might mean your tv have some parts getting in problems actually, but still it would be the first thing that i'd try in this situation... Let us know...
Oct 12, 2009 | Hitachi 50UX26B/27K 50" Rear Projection...
Have model F25190SE, old 1992 tv, Chassis CTC177AC. No signal coming in from rf connector, television all snowy. Can use the rca connections, still has very fine lines in picture. I've replaced the rf...
cristal and IC to be replaced and solderings on all grounds in the tuner unit. maybe costly for a tv of that age, for the fine lines there are 2 ajustements on the back of the tv set, one is focus and the other one is sceen, that ajustement is too high , just turn the ajustement counterclockwise. the tv will become darker
Jun 30, 2009 | RCA Televison & Video
Low resolution
hi, there you need to open the cover of your monitor and check for three ajustments you will see them they are like screw but you have to be carefuly as the monitor is like a TV set it produce high voltage.
one of those screw is for contrast which is the one you need to focus on, if its not there there is a black like plug cable which is attached from the tube and the circuit board that one has got two screws one of those is for contrast try both if not sure (Caution!! that's the one that produces HIGH VOLTAGE) ask some one who know's about electrical appliances if not sure what to do.
Regards,
Colin
May 11, 2009 | Computers & Internet
Rear projection tv
hello. well that's not from your focus board.!!! tv's don't have focus board's .!!! they have focus pod's.!!! it's a small black box with nob's that can be turned to ajust the focus.!!! so the tv look's clear.!!! the problem you have is in your ( blue IC chip') . it's going bad and will need to be replaced.!!! there are 2 (IC chip's) there is one for the red & one for the blue.!!! and they are on the convergence board.!!! they will have letter & number's on them.!!! like (STK 1140 or STK1158) NOW.!!! UNDERSTAND THAT THESE AND NOT YOUR NUMBER ON YOUR SET.!!! YOU WILL HAVE TO LOOK FOR YOUR SELF.!!! ON THE CONVERGENCE BOARD TO FIND OUT WHAT number's are on your (ICchip's) .!!! and replace them .!!! and that should fix your problem.!! hope this help's you.!!! "GOOD LUCK"
Aug 17, 2008 | Mitsubishi WD-52525 52" Rear Projection...
NEC LT220 FOCUS PROBLEM
I replaceed my Benq PB6110 Lamp and the focus is not clear
on the display it was very clear prior to the replacement, now its very hard or not readiadle at all. How can I make the ajustment.
Dec 06, 2007 | Office Equipment & Supplies
Sony FD Trinitron WEGA KV-36HS500 36" TV Logo
119 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
