Question about Creative Labs I-Trigue 3600 Computer Speakers
Sub doesn't work
After formatting my PC the subwoofer has never worked. I've tried the audio settings on the PC,the connections, the cable to the PC and I've even tried to see if the problem could be solved by connecting the speakers to an MP3 player (I thought perhaps the computer had problems!). NOTHING!!!! Please help!!
  • grstoppoloni Feb 25, 2009
    I've tried it all already! I think it's a sub problem..... That really sucks! If you have any other idea that'd be great!!! Thanks.....I'm from Italy
  • 85 Answers
Try to check audio cable.. or the speaker wire.. if dosnt get ok.. anyway wer u from?
Posted on Feb 20, 2009
  • ronan cainglet
    ronan cainglet Apr 05, 2009
    i have an idea ... if you know how to dis assemble the sub.. just replace the sub speaker.. maybe your sub spkr burned out....
I have a Sharp Aquos LC-60LE640X TV and I am trying to connect a Samsung HW-H751 Soundbar to it. I have hooked up the optical cable, adaptor and sub woofer, I have tested the Bluetooth function throug
If you are connecting the soundbar to your TV with the digital audio cable, make sure to select "D IN" using the source button on the soundbar. Bluetooth (BT) is a separate source from another device. (phone, etc.) The TV will need to be set to use the digital audio output and probably PCM format. (?) The subwoofer is preconfigured at the factory to mate up with your soundbar. (See below instructions - your soundbar includes the amplifier:)
Digital audio output setting:
After connecting an amplifier with digital audio input and
external speakers as shown, you should set an audio
output format compatible with the programme you are
watching or the device connected.
Go to "HOME" > "TV Menu" > "Setup" > "Option" >
"Terminal setting" > "Digital audio output" > select
"PCM" or "Bitstream".
NOTE
• When set to "Bitstream", Dolby Digital is output when the Dolby
Digital or Dolby Digital Plus audio formats are received. When
set to "PCM", PCM is output no matter what audio formats are
received.
• When set to "Bitstream", HE-AAC audio formats can be output
as Dolby Digital.
Jan 24, 2015 | Sharp Aquos Televison & Video
Sony CMT-GP5 subwoofer output very quiet
From the description the subwoofer is the problem, since the item is new return it to the place of purchase, this is a manufacture issue.
Aug 13, 2012 | Sony CMT-GP5 CD Shelf System
How do i connect a subwoofer to my receiever it doesn,t have a out put for the subwoofer can i hook it to the speaker s
HI,
To gi ve you a better solution need to know the barnd and model number of both the receiver and the sub woofer.
OK
Aug 26, 2011 | Audio Players & Recorders
Hi, I have a denon AVR 889 about 4 years old and the subwoofer suddenly stopped working,how can i check if its the amp or the sub thats the problem?
A Denon AVR 889 is not a sub so we don't know anything about the sub in question.
Maybe the existence of the sub is no longer set in the AVR. Look at the speaker definitions first before going to wild.
Try another cable to the sub.
OR, run the sub's signal supply cable to one of the Tape Outs on the receiver and tune in something on FM. If that works a) it will be loud, and b) go back to the SUB settings on the AVR.
Crack the sub open and access the terminals on the speaker itself. Disconnect them from internal components and run one of your amp channels directly to it. If it works, the amp or signal path are dead. If it doesn't work, it's a dead driver.
May 19, 2011 | Denon AVR-889 Receiver
I have atomic A-8 subwoofer and philips FR740 receiver. when i turn the amplifier and the subwoofer "on", the subwoofer starts to hum loudly and it is wery annoying. i made all the connections...
The symptom sounds like an open signal shield somewhere and the cable is acting like an antenna for airborne electrical noise.
Disconnect the RCA cable at the sub. Is it still humming? NO? Problem is external to it. YES? Internal. Broken ground somewhere.
Recheck all connections making sure to twist the RCA head as you install it so oxides will be worn off.
Consider what may have changed in the environment regarding electrical devices, motors, magnetic sources. Ensure signal and speaker wires as ar not running are as non-parallel to any power cords as practicable.
Apr 23, 2011 | Eltax Atomic A-8.2 Subwoofer
My JVC Subwoofer does'nt work !!! Connected
If your connected via the sub pre out on your reciever check your setting to make sure that it is turned on also if this is done you may try using speaker cables to by wire the subwoofer
May 24, 2010 | Harman Kardon AVR 2550 Receiver
Cannot get the sub woofer to work.
Now tell the NAD you have a subwoofer. Page 15, Figure 13, etc. and Page 18 - 19.
Mar 05, 2010 | NAD T770 Receiver
I just bought a KEF PSW2500 subwoofer and am trying to connect it to a Yamaha v663 receiver. However, I went from a subwoofer pre-out 1 to the right line in on the sub. I don't hear any sounds from the...
HI,go into the yam setup menu and make sure you have the sub turned on and cross over set to about 80hrtz if this suits your speakers,set sub level to about -5 on amp and say half way on the sub,this should work if not pull out sub cable at amp and touch the end,you should get a hum,if not you may have no power,faulty cable or sub.
PS>make sure you are pluged into the sub PRE OUT and NOT the six channel in.
Hope this helps.
CABLE GUY.
Apr 19, 2009 | KEF Audio PSW 2500 Subwoofer
How to connect unpowered subwoofer to receiver with RCA sub out?
In order for this to work, you will need an external amplifier. Your receiver is set up to use a "powered" sub. With only speaker connections on the sub, it is a "passive" sub requiring a separate amp.
Dan
Dec 16, 2008 | Yamaha YST-MSW10 Computer Speakers
Cerwin vega ht-10d subwoofer won't work in yamaha reciever
Well, as I know, your Cerwin Vega subwoofer is designed for use with stereo systems. Therefore, it has only 2 channels for input, and 2 channels for output as well. However, you can try this out; the first thing I suggest is that you hook up your main front channels through the subwoofer. All you have to do is to connect the subwoofer input to the front channel output on the amp, then hook up your front speakers to the satellite output on the subwoofer. As long as you make sure that system is working on 8 ohms, I believe this can activate the subwoofer.
Sep 15, 2007 | Athena AS-F1 Main / Stereo Speaker
Creative Labs I-Trigue 3600 Computer Speakers Logo
114 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
