Question about Panasonic SA-HE90 Receiver
Panasonic SA-HE9 amp / Sky+ optical
Hi, I'm using the Panasonic SA-HE9 amp and connecting from a Sky+ box optical output to the amp's optical input 1. Today the sound has stopped working in non-DD mode. Anyone have any idea if this is something I can rest or fix?
Thanks, Jeff
I Have a Panasonic SA-HE9 and i cant get the optical cable too work on my Playstation 3 to get sound from there. can any 1 help me with this?????
Posted on Dec 30, 2010
Is there a docking device for connecting iphone with panasonic receiver
There are lots of docks, but they all connect via USB
https://www.google.ca/search?q=iphone+6+plus+dock+connector&rls=com.microsoft:en-CA:IE-ContextMenu&biw=1366&bih=643&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjMh9Hpg97QAhVPVWMKHVosD3kQ_AUIBigB#tbm=isch&q=iphone+6+plus+dock
Your receiver only has s-video.
Total Harmonic Distortion 0.7% (6ohms) (at 20Hz-20kHz)
  • S-Video Inputs/Outputs 5 inputs, 1 output
  • Video Inputs/Outputs 5 inputs, 1 output
  • Video Rec Outputs 1 output (with S-Video)
  • Front Audio Inputs 1 input (S-Video)
  • Digital Inputs/Outputs 4 in (3 optical, 1 coaxial)
  • Audio Inputs/Outputs 6 in, 1 out
  • VIERA Linkā„¢ HDAVI Control 3
  • HDMI Input/Output 3 in, 1 out
  • Dimensions (H x W x D) 6 1/4'' x 16 15/16'' x 13 11/32''
  • Weight 11 lbs
    Panasonic SA BX500 AV Control Receiver with High Quality Amplifier Decoder...
  • Dec 05, 2016 | Panasonic Audio Players & Recorders
    How to connect soundbar to a TV with a skybox
    Connect the soundbar either to the TV's optical output. Or use an Optical to stereo phono/RCA converter box and then a pair of stereo phono cables (red & white) to the soundbar.
    If it's a very basic soundbar with just a headphone jack input then you can go from the TV's headphone output instead.
    As for the Sky box, just leave it connected via either an AV lead or better still a HDMI cable direct to the TV. The TV will send sound out to the soundbar.
    Sep 04, 2014 | Televison & Video
    Panasonic sa xr25
    Is the signal connected to coaxial- a digital spdif? If you are dealing with analogue audio connect them to RCA's. Hope this will help.
    Nov 16, 2013 | Audio Players & Recorders
    I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
    There are two things that I can suggest.
    1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
    2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
    Hope this helps,
    Good Luck.
    Jan 07, 2011 | LG Audio Players & Recorders
    Diagram to set up the Panasonic DMR EZ47V DVD/Video recorder
    Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the LCD . Connect the AV output of the Sky box to the AV input of the Panasonic combo.
    Hope it will cover the matter
    good luck
    Jan 29, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
    No picture on TV through Sky, Home Cinema is on but have sound.
    do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
    Dec 10, 2008 | Panasonic SC-HT75 System
    I have a Panasonic TH-42PZ700A High Def TV and a Panasonic 160gig DVD Recorder. They both have 1 optical audio output each. I have an Onkyo amp which has 1 optical input for audio. How can I have 5.1 dolby...
    Dear ritchiewayne,
    Please connect optical out of the DVD recorder to the input of panasonic TV. Next connect TV's optical out to the input of Onkyo amplifier. connect speakers to the out put of Onkyo amplifier.
    ramesh22
    Jun 15, 2008 | Panasonic Televison & Video
    Connections for DVD Recorder/LCD TV/ SKY PLUS
    Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
    Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
    Pioneer vsa e06
    depends what audio outputs you have on the sky box,analogue (two phono usually red for right channel and white left channel)in which case just use phono leads to the phono inputs,Optical(toslink),connect an optical cable from the output to the optical input on the dvd channel of the pioneer,coaxial (spdif)connect to spdif input on the laser disk input of the pioneer,dont connect to the attenuated spdif.In the unlikeley event of the sky box not having any audio outputs,just use the outputs from the tv to the pioneer.The optical digital input gives the best quality on the vsa eo6
    Jan 24, 2008 | Pioneer VSX-1015 Receiver
    Panasonic SA-HE90 Receiver Logo
    543 people viewed this question
    Top Panasonic Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
