Question about Sanyo DP32746 32 in. LCD Television
Hdmi tv comes on with sound and black/grey screen comes on after we move it about but this happens everyday
  • 71 Answers
Contact customer care 1800-877-5032
Posted on Mar 05, 2009
I have been using my panasonic tv as a display to watch films on from my laptop via HDMI however now i am just getting a black screen. the TV recognises that the laptop is connected and so does the la
try holding the hdmi wire connecting to the tv port at a slight angle, if it comes on then the hdmi connection is damaged,do you have sound?
give the connection a wiggle and inspect the connection, maybe worth a reset?
Dec 09, 2013 | Panasonic VIERA Televison & Video
Iv got a jmb 19" tv with one hdmi port. when I
ps3 haft to get to video settings and change it, xbox u might haft to change sound output in settings to hdmi
Sep 21, 2013 | Video Game Consoles & Games
No picture, only sound on LG 47LV5500: how do I get picture back?
Definitely odd for sound to come through and not sound, especially via an HDMI connection.
I would contact LG for support, your TV could be defective.
Good luck
May 28, 2012 | LG 47 47LV5500 47 LCD TV
Help with insignia 24 inch flat screen? the av channel will not show the channel where i can play my ps3?at?
It sounds like yoru PS3 has stopped handshaking with your tv. It can happen. It's possible your brother disrupted the connection by unplugging the PS3 before it was shut down. You can try turning on the PS3 first, and then turning on the tv, or vice versa. If that doesn't work, you may need to invest in a cheap HDMI splitter, to plug the PS3 into, and then send the signal from the splitter to the TV. It has happened to me with a computer with the same hardware, once with an LED tv, and once with my surround sound receiver, completely out of the blue. You can try switching HDMI cables, sources, doing putting the tv into maintenance mode and resetting the software. If none of that works, your only option may be to use an HDMI splitter. I did extensive research and read numerous reviews before I settled on this model, due to many recommendations:
ViewHD 2 Port 1x2 Powered HDMI Mini Splitter for 1080P & 3D ' Model: VHD-1X2MN3D
It's available on Amazon here:
Amazon com ViewHD 2 Port 1x2 Powered HDMI Mini Splitter for 1080P 3D Model...
Just in case your HDMI cable was damaged when your brother unplugged it, go ahead and get yourself a decent HDMI cable. The Amazon HDMI cables work just fine.
Jul 07, 2017 | Video Game Consoles & Games
I have a PS3 hooked up via hdmi. The screen goes black for 1 second then comes back during game play. It doesn't do this when hooked up through component connections. I replaced the hdmi cable and...
Ur tv is on 3D mode setup probally,i'm wright?Yes?Set the tv it back to 2D mode,should stop the tv delaying 1 sec. black out intervolt should stop happening.Because ur are not using a 3D PS3 machine ur are using an PS3 2D a normal system.
Aug 08, 2011 | Vizio XVT3D474SV 47 in. 3D LCD TV
I have a Sharp Aquos 32" TV. Almost everyday, the
Maybe the cords have the problem.
You might have to pull and reconnect the cords and do the same basic turning on/off of the Tv.
Or you might also check the positioning of your Tv, example : are there stereos or speakers near or beside the Tv? it causes magnetic reaction and causes the screen to not work properly.
Dec 30, 2010 | Sharp Aquos LC32D41U 32 in. LCD TV
LG 42LG5 hdmi not working
Have you tried another HDMI cable? The cable may be bad. However, if this is not the case and this is happening across mutliple devices(cable box, dvd player, etc) then you might have a bad HDMI input on your TV. Does this happen on all HDMI inputs on your TV? If you can safely rule out your other devices and the cable itself then you've got a main board problem and would need to get it replaced.
Feb 12, 2009 | LG 42LC2D 42 in. LCD HDTV
Xbox 360 showin black and grey specs on screen while playin
Unfortunately that sounds like a case of a 360's video card faltering - My suggestion is to locate your warranty ring microsoft and get a replacement.
Good Luck,
Blazamane.
Jan 07, 2009 | Microsoft Xbox 360 Console
Periodic tv screen blackouts
The problem is your cable box. I know you said you replaced it, but I work on TV's everyday and, sorry to say this but cable box HDMI outputs have serious issues, like no or intermittent sound and video. I have seen customers exchange their cable boxes 5 and 6 times and still have the problem. Your best bet is to use the component outputs of your cable box, visually you will not see a picture difference between component and HDMI when using a cable box. Your other solution is to get satellite; I have NEVER seen an HDMI issue with a satellite box
Nov 25, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sanyo DP32746 32 in. LCD Television Logo
53 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
