Question about Mach Speed PM2MP Motherboard
Memory upgrade I currently have 512 mb of memory and looking to upgrade the pm2mp board state can be upgraded to 2 gb. I started looking for memory on ebay, I looked for pc2100 or ddr266 is this correct? I also came across a lot of memory that states it is server memory can this be used? Basicaly Im looking for some suggestions on what would be a suitable memory upgrade as far as ecc/nonecc, buffered/unbuffered, registered/non registered, high density/low density what am I to look for to be as compatible with this motherboard? Thank you in advance for your time and assistance, Jeffrey
    President:
  • 1,073 Answers
Hi Jeffrey!
Yepp, you can upgrade it to 2GB memory, those DDR266 PC2100 you fund on ebay is perfect for your board.
Your boad also supports DDR200 as long as they are 184pin sticks. Thogh the DDR200 memory is a slower stick then the DDR266.
So if you fins 2 sticks each 1GB go for it. Your pc will be fast as a jetplane (at least af fast as it possible to get it).
Here is all the info i found about you Mobo:
http://www.motherboard.cz/mb/jetway/PM2MP.htm
Good luck to you
Please take a moment and rate my heko for you
Nic
Posted on Feb 19, 2009
  • 741 Answers
According to the pm2mp manual you have two memory slots. Each slot can hold a max of 1GB DDR266 or DDR200 184-pin DIMMS. So when you are shopping for memory just ask for or Google DDR266 DIMMS. This is what matches your CPU 478 Socket so it is important to get that exact type of memory or you will have all kinds of wierd problems that will be hard to troubleshoot. Good Luck.
Don't forget to rate this solution.
  • Mach Speed Master
  • 4,806 Answers
Hi there.
The best memory for that motherboard is DDR SDRAM, the supported ram speed is 266 MHz • 200 MHz(maximum 2BG, 1BG in each slot)
Kingston or corsair memory running at 266MHz is my recommendation to you. Try not to buy used memory as it may not work!!
Good luck and thanks for using Fixya!!
Cannot find specification for packard bell i start 1379. I want to look into the possibility of upgrading this pc. Can anyone point me in the direction of the specs being available online for this...
Here is the homepage:
http://www.packardbell.co.uk/pb/en/GB/content/download
This specs provided was complete with a Intel Intel Serial ATA-300 ATA-133 PCI 160 GB Microsoft Windows Vista Home Basic , ATI Radeon Xpress 1100 128 MB 4 MB . The Desktops memory add up to 2048 MB , with standard memory 512 MB , memory installed 533 Mhz DDR2 SDRAM DIMM 240-pin Very low profile PC4300 Compact Flash Type I with 2 Expansion Sockets/Slots.
You can update the graphic, by adding a better graphic card, on the mainboard.
The ram can be upgraded to 2 gb ddr2 ram.
A bigger harddrive, can be added, for more space.
The cpu will be hard to find, it probably have socket 775, but this cpu is not available anymore.
And not all cpu`s will fit the mainboard.
Good luck
Feb 10, 2013 | Packard Bell (181368) Motherboard
I have intel pendium d d102ggc2 motherboard. am using 512 mb ram ddr2 667mhz. Now i want to upgrade it and use 2 gb ram. please suggest.
Mother board d102ggc2
• Support for DDR2 533 MHz and DDR2 400 MHz DIMMs
• Support for up to 2 GB of system memory
Dec 27, 2012 | Intel D102GGC2 Motherboard
Gt5082 what is the best sticks for gateway gt5082
Memory Upgrade for Gateway GT5082 Computer, the Gateway GT5082
Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory
Type, and comes installed with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) of Memory. You can upgrade your
Gateway GT5082 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) standard Memory installed.
For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Gateway GT5082 Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope it helps
Apr 14, 2012 | A-Data Technology 1GB kit (512MBX2)...
I have a 512 mb 667mhz sdram on D102Ggc2 board.now i decided to up grade memory. Can i upgrade system memory without lose this 512 mb.
Yes you can. but make sure that you buy the exact same type of RAM stick that you have and put it in the other RAM slot so the Dual Channel feature will be active (dual channel makes data transmission/processing faster) and making your systems memory 1GB. However, your motherboard can utilize or handle up to 2GB or RAM so you can put also a 1GB RAM stick which will make your systems memory a total of 1.5GB (that will be the case if you really dont want to lose the 512MB that you currently have,
Hope this helps.
Jul 09, 2010 | Intel D102GGC2 Motherboard
I have compaq presario 5000 series...and iwant upgrade my ram ...i have 128+128 sd ram so how much i upgrade my ram...can i upgrade 512+512 sd ram OR 256+256 sd ram...thank you
the RAM upgrade will depend on ur motherboard capacity and specification.
u need to check ur MB manual
if ur MB can have only SD RAM then only SD RAM upgrade is possible...DDR will not work....
so be careful while buying ur RAM
intelD845GLLy MB...the following details are from the intel website
http://www.intel.com/support/motherboards/desktop/d845glly/sb/CS-012825.htm
System Memory Features
The D845GLLY board provide the following memory features:
  • Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
Caution Do not use ECC DIMMs with the Desktop Board. Using ECC DIMMs could damage the Desktop Board.
Integrator's Notes:
  • Registered DIMMs are not supported on the Desktop Board.
  • This Desktop Board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated on this board.
Note To be fully compliant with all applicable PCI33 SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance.
hope this helps
Reg....bye
Feb 24, 2010 | Intel D845GLLY Motherboard
Compatible with windows 7
yes its compatible with windows 7.
Nov 21, 2009 | Computers & Internet
How to install memory upgrades on GATEWAY GT 5042B PC
CLICK HERE. to get all the information you need about your computer.
Memory:-
  • Installed: 512 MB DDR2 533 MHz (PC4200) SDRAM
  • Expandable to: 4 GB (4 DDR2 slots)
  • If you want to know how do i install it? CLICK HERE.
    please rate my solution very high, if this infornmation is helpful.
    Sep 23, 2009 | Generic Memory Computers & Internet
    I want to upgrade my HP BA 600 Mother Board`s RAM Capacity
    Most likely your MB is too old for this upgrade although there is a chance you could flash your bios (reprogram your computer's brain to accept the new memory providing hp has a flash for it).
    here is a link for the latest bios flash for your computer, use at your own risk.
    http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=32895&swItem=vc3903en&prodNameId=20305&swEnvOID=54&swLang=13&taskId=135&mode=4&idx=0
    good luck.
    Thank you,
    agadycom
    Nov 27, 2008 | HP Computers & Internet
    Memory upgrade problems
    sex just change the mother board old mother board get slower by time. so' buy new core 2 duo or core 2 quad wich I am using.
    Apr 08, 2008 | Lite On NA115 Motherboard
    Mach Speed PM2MP Motherboard Logo
    139 people viewed this question
    Top Mach Speed Computers & Internet Experts
    Brian Sullivan
    Brian Sullivan
    Justin
    Justin
    David
    David
    Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
