Question about GE 27928GE5 Cordless Phone
Manual telefone em portugues
Quero ver quem tem o manual em portugues do telefone GE sem fio 2.4 27928. para que ler e usar corretamente.
3 Suggested Answers
bbl242003
  • 1637 Answers
SOURCE: HOLA, NECESITO VER SI ME
You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones MORE USEFUL INFORMATION FOR ALL YOUR ELECTRONICS When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
Posted on Jan 19, 2011
  • 102366 Answers
SOURCE: manual model 27995GE 1A em
http://www.home-electronics.net/USER-GUIDES/27995_DOM_ES_CL_IB.pdf
Posted on Aug 19, 2011
Fwlink linkid 106440
Primeiro em Ingles e depois em Portugues:
Dear Eustaquio, in order to try to solve your problem, we need you to provide us with a little bit more information, like:
1) What is the version of your Windows OS?
2) What is the version of your Internet Explorer?
3) Did the problem started after you proceed with any kind of updates? Even automatic Windows Updates?
4) Please, provide us any other information you may find important to let us understand how the problem first appeared.
Agora em Portugues:
Caro Eustaquio, para que possamos tentar ajudar a resolver este problema, necessitaremos que voce nos forneca algumas informacoes, tais como:
1) Qual e a versao do seu Windows?
2) Qual e a versao do seu Internet Explorer?
3) O problema surgiu depois que voce fez algum update no Windows ou no Internet Explorer? Ou depois de alguma atualizacao automatica do Windows?
4) Por favor, de-nos quaisquer outros detalhes que voce ache relevante para que entendamos como o problema apareceu originalmente.
Esperamos sua resposta para poder tentar ajuda-lo!
Atenciosamente,
Regards,
Miguel. L. Martins
(OBS.: estou escrevendo sem cedilha e sem acentuacao porque este sistema do Fixya nao permite caracteres Unicode que nao sejam os do Ingles - qualquer acento impede a mensagem de ser enviada)
Oct 30, 2013 | Computers & Internet
Do you speak portuguese? i need to konw how i can install a 300Mbps Advanced Wireless N Router in my computer... please, help me.
Ok, conecte o cabo de rede (com conectores RJ45) que vem de seu modem ADSL (ou da NET, ou de seu atual serviço de internet), aquele que encontava-se (ou ainda encontra-se) diretamente conectado a seu computador, à entrada 'WAN' do roteador. Conecte outro cabo de rede da entrada '1' do roteador à porta ethernet de seu computador. Então, inicie um browser de internet (Internet Explorer, Opera, Chrome, etc.) e digite 'http://192.168.1.1'. Ao receber o prompt de autenticação, entre 'admin' (minúsculas) em ambos 'Username' e 'Password'. Uma vez na página de configuração, clique em 'Quick Setup' e siga os prompts. Na medida do possível, deixe tudo em automático. Quando chegar na página 'Wireless', em 'SSID', defina um nome para sua rede, marque o item 'WPA-PSK/WPA2/PSK' e defina uma senha alfanumérica (entre 8 e 63 caracters) para criptografar sua rede. (Esta senha deverá ser definida em todos os dispositivos sem fio - computadores, laptops, celulares -que deverão acessar sua nova rede sem fios). Depois de alguns 'Next', clique em 'Finish' e "Reboot'. Depois que o roteador reiniciar, sua rede criptografada estará pronta.
Estas configurações são básicas. Seu roteador é capaz de executar muitas outras tarefas, tais como ter outro endreço IP para toda a rede (ao invés de 192.168.1.x), filtros por endereço MAC (físico), endereço IP fixo definido para cada dispositivo que você der acesso, etc..
De qualquer forma, se tiver outras dúvidas específicas, por favor, volte a contactar-me.
Atenciosamente, Carlos
May 30, 2011 | AGPtek TPLink TLWR941ND IEEE 80211bg IEEE...
Preciso desbloquear um NOKIA 1616-2 RH-125 IMEI: 352017/04/569098/7 Obrigado.
Pode haver muitas maneiras de desbloquear o telefone. Tanto quanto eu sei, pelos c?digos de desbloqueio ? a maneira simples e segura. Vou sugerir o site de desbloqueio-Zone.com, que est? fazendo um bom servi?o e que eram altamente recomendado nos f?runs de telefone celular.
Eu usei-os para desbloquear meu celular. em contato com eles e dentro de 30 minutos eu tinha o meu c?digo de desbloqueio eo meu telefone foi desbloqueado.
Espero que isso ajude.
Feb 11, 2011 | Nokia 1616 Cell Phone
Quero baixar filme no iPad
Pedimos desculpas por qualquer mal Português, não posso falar o idioma.
Para baixar um filme em seu iPad, você precisa abri-lo no iTunes no computadordo iPad é sincronizado. Com o iPad conectado, optar por sincronizar todos os filmes / filmes, ou tentar arrastar o filme para o logotipo do iPad.
Espero que ajudado, boa sorte!
Jan 15, 2011 | Apple iPad 64 GB WiFi
Eu quero manual em português
Aa primeira coisa que você deve fazer é enviar-nos a marca eo modelo da sua câmera, para fazer uma pesquisa e orientação.
Boa suerte.
Jan 09, 2011 | Cameras
2005 Honda NX4 Falcon sistema de tarifa??o
Oi, Barracuda_ga antes de testar qualquer componente el?trico no Sistema de carregamento ? "IMPERATIVO" que voc? tenha uma bateria totalmente carregada de 12,5 volts ou mais e que possa passar um test "LOAD" adequado, se necess?rio, voc? pode ter uma leitura preliminar de 12,5 volts ou mais mas pouco ou zero de amperagem, a bateria est? com defeito e deve ser substitu?da. As baterias tipo AGM caem nesse cen?rio mais do que as baterias de chumbo-?cido.
1. Verifique os terminais da bateria para danos ou corros?o, verifique se os cabos da bateria est?o "BOTH" para conectores soltos, corro?dos ou quebrados, "INSIDE" e fora do chicote de fios, execute o test do wiggle do conector e verifique os cabos com um ohm?metro, se necess?rio.
2. Para verificar o regulador, desconecte-o do estator. Fa?a uma luz de test e prenda-a no terminal negativo da bateria e, em seguida, toque primeiro um pino e depois o outro no plugue que vai para o regulador. Se voc? conseguir a menor quantidade de luz da luz de test, o regulador ? torrado. Para fazer isso com um medidor: chumbo preto na terra da bateria, chumbo vermelho para cada pino no plugue, comece com a escala de voltagem maior do que 12vdc e mova a escala de tens?o para baixo em etapas para cada pino. Qualquer tens?o ? um regulador ruim.
3. Na outra parte do plugue do regulador desconectado. Defina o mult?metro para a escala Ohms x1 e mida a resist?ncia entre os pinos do estator. Voc? deve ler algo em torno de 0,1 a 0,2 ohms para um sistema de 32 amp.
4. Em seguida, verifique a continuidade entre cada pino no plugue e moldura / ch?o do motor. A agulha do medidor n?o deve se mover (resist?ncia infinita) (os digitais mostrar?o resist?ncia infinita) se a agulha do medidor se mover (indicando continuidade) (os digitais mostrar?o alguma resist?ncia), verifique com muito cuidado. Se o medidor ainda mostrar continuidade ao solo, o estator est? em curto (mau).
5. Ajuste o medidor para ler volts A / C superiores a 30 volts (a configura??o da escala para a tens?o deve sempre ser maior do que a maior tens?o que voc? espera ou voc? pode fritar o medidor). Inicie a bicicleta e mude de um pino para o outro no plugue (N?O atravesse as sondas do mult?metro! - toque-os um para o outro). Voc? deve ler aproximadamente 16-20 vac por 1.000 rpm.
6. Se a bateria estiver boa no test de carga, se o estator N?O estiver em curto-circuito na terra e o estator estiver apagando a tens?o do A / C, ent?o o regulador est? ruim (provavelmente mesmo se for passado o passo 2)
Para obter mais informa??es sobre sua pergunta e downloads valiosos "GR?TIS" que voc? precisar? para visualizar ou imprimir, clique nos links azuis abaixo. Boa sorte e tenha um dia maravilhoso. http://racetechelectric.com/files/pdf/rte_troubleshooting_flow_chart.pdf
HOW TO CHECK YOUR CHARGING SYSTEM and CHANGING the STATOR and REGULATOR...
DOWNLOAD NX 4 NX4 Falcon Service Repair Workshop Manual Download Manuals... $15
https://www.partsfish.com/page/oem-parts-for-honda
http://www.casasandin.com/manuales/honda/NX4%20FALCON%2000%20A%2002.pdf
Aug 29, 2010 | 2005 Honda NX4 Falcon
Meu not ta com windows xp e nao conseguindo achar o drive de som e nao escuto minhas musicas quem gostaria de me ajudar por favor me ajude to precisando o drive e conexant 20561 intel obrigado!
I como a programa DriverMax para encontrar difícil de encontrar drivers . Você pode receber dois (2) drivers a dia para ... sem mais que e que tem a pagar. A nunca me falhou. Você pode receber ele aqui: http://www.drivermax.com/Clickthe "download" botão , e download, , em seguida, instalá-lo . A vai ajudar você encontrar qualquer faltando drivers você precisa.
Jun 13, 2010 | Microsoft Windows XP Professional
Preciso do manuel do Celular MP7 Dual Chip Mini
Há um manual em português aqui. Espero que lhe seja útil. Note que a página do 2shared é algo confusa. Não clique nas palavras grandes 'DOWNLOAD' em azul que você verá lá. Logo abaixo da 1a. em que ela aparece (junto com 'PLAY NOW' em laranja), você encontrará 'Save file to your PC: click here'. é onde você deverá clicar para fazer download do manual.
Um abraço, Carlos
May 07, 2010 | Cell Phones
Quero ascessar a internet sem usar o gprs apenas pela wii-fi tem jeito?
I want use my gmail and I can't do it, if you can help me please
Jan 08, 2010 | HTC Touch P3452 Smartphone
Fone de ouvido
Não tenho certeza se eu entendi como eu não falam Português, mas, se eu sou, então você está perguntando qual a cor auscultadores em ir? caso em que, headphones e alto-falantes sempre ir para a luz verde jack. My reply in English; Not sure if I understand correctly as I don't speak Portuguese, but if I am, then you're asking which colour the headphones go into? in which case, headphones and speakers always go into the light green jack.
May 25, 2008 | Foxconn WinFast K7S741MG Motherboard for...
GE 27928GE5 Cordless Phone Logo
794 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
