Question about Yamaha Audio Players & Recorders
How to connect my speakers to my yamaha rxv396ds
How do i get a new maanual for my yamaha rxv396ds
I am trying to connect my Bose Wave Radio to my Yamaha RX S 70 receiver so that I can listen to the radio through my speakers. Right now the speakers are connected to the Yamaha...but radio isn't playing...
There's actually 2 ways of doing this.
Using the variable out connections on the Bose, connect your L&R channels to the desired input, I recommend the auxillary, on your Yamaha and select that input. Turn the volume all the way down on your Yamaha. Turn the volume on your Bose all the way up; then readjust the volume as desired on your Yamaha.
Optional connection; the headphone jack. Connect a 3.5mm mini to stereo plug cable from the Bose to Yamaha in the manner described as above and use the volume control approximately the same way.
Dec 12, 2014 | Yamaha Audio Players & Recorders
Tip
How to connect an iPod to a speaker Yamaha Bar
<p>Yamaha speaker bar is a long, thin speaker system that is typically connected to a television because she can sit on the set. However, many people store their music libraries on iPods, and if you want one of those people you can connect your iPod directly to the Yamaha speaker bar. This is a fairly simple task that can be achieved in just a few moments. <br /> <p><br /> <p>1. Place the iPod in the iPod speaker dock from Yamaha as a bar, or connect your iPod through your door in the background that comes out the opposite. Depending on the model, the speaker dock or a bar directly above the control panel or a cable that runs from the back of the unit. <br /> <p><br /> <p>2. Power bar speaker Yamaha, do the same with your iPod. <br /> <p><br /> <p>3. Choose your music to play through the iPod screen. Press "Play" and you should listen to music through the speaker bar. <br />
on Aug 09, 2011 | Apple iPod touch
Why yamaha rx-v 575 does not turn on?
You have a short in your speaker cables (not connected to speakers or small fiber of wire connecting across the speaker terminals)
-or-
your output transistors have gone bad and need to be replaced. This usually costs the same as a new receiver.
Jul 31, 2014 | Yamaha Audio Players & Recorders
Drivers Yamaha MS55D speakers.
you have to download your drivers from yamaha i succest
Apr 15, 2012 | Yamaha YST-MS55D Computer Speakers
I have a Yamaha HTR6090 receiver and tannoy speakers. I cannot get the sound to come out of the speakers. Tried all speaker connections.
Is this new equipment or a new problem?
Have you followed the instructions in the manual on setting up the speakers, sources, etc?
Is it source-specific? How about some clues.?Something must work.
May 29, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Trying to install my new home theatre
Are you sure the wire is not damaged somewhere? Are you sure that you are connecting the wire to the correct terminal on the receiver? Is the speaker OK?
To test all of this, try different combinations. With Right speaker working, disconnect the wire from speaker and connect it to the left speaker. If it doesn't work, then the left speaker is faulty.
Now disconnect the wire from receiver's right-front terminal and connect to left-front terminal. If it doesn't work, you are either connecting to wrong terminal or the terminal/receiver is faulty.
At last, try using the "left" wire to connect the rigth speaker to right terminal. If it doesn't work, the wire is faulty.
P.S. The +/- doesn't matter for testing, the sound should go either. It is just needed to have all speakers connected in the same polarity, because else the sound waves would eliminate themselves.
Oct 31, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
May 18, 2009 | Yamaha HTR-6130 Receiver
Yamaha YST-MS50 speakers to my i Mac.
You can connect the Yamaha YST MS50 speakers to any audio source that relies on a 3.5mm jack. The YST MS50 should have two audio inputs, so you can use one of them to connect the speakers to your computer. If you don't have a 3.5mm male to male cable, then you can buy that at any electronics store or online.
Oct 11, 2008 | Yamaha YST-MS50 Computer Speakers
Center channel quit woring
The center channel amplifier in the main unit isn't working. Check the warranty. If it's still in force Yamaha will fix it free. If out of warranty, they'll give you an estimate.
May 15, 2017 | Yamaha Audio Players & Recorders
22 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
