Question about Price Pfister Plumbing
Price Pfister kitchen faucet two handle with gooseneck and pull down spray. The pull down sprayer will not stay up in the goosneck.
  • 3 Answers
It may also be a missing weight on the sprayer hose, or that the sprayer hose is obstructed. Open up the cabinet under the sink and look a half-loop of the sprayer hose that should be hanging down from the underside of the faucet. It must be able to descend without obstruction as you return the sprayer to the body of the faucet. If it is resting on a box of dishwashing soap or otherwise obstructed, then it doesn't have it's full weight to counterbalance the weight of the sprayer head. Capice? It needs the weight of the hose to 'weight it down'. Also, there should be a donut-shaped weight around the hose that should be able to freely slide to tha lowest position of the half-loop as the sprayer is extended and returned. Make sure that's working too.
Posted on Apr 04, 2009
    Problem Solver:
  • 9 Answers
If you look closely to the sprayer, it has a groove that fits tightly into the goosneck. Make sure you have tightly into the groove and let me know. There should be no other reason why it wouldn't fir back in the goosneck.
Posted on Feb 21, 2009
How to replace a price pfister kitchen faucet sprayer
The sprayer should have a threaded fitting on the end of the hose. Unscrew old one from valve, pull hose out the top, feed new hose back down into cabinet and screw in to where old hose was attached.
Sep 23, 2012 | Price Pfister Pfister T26-4ypu Rustic...
I need a replacement handle, including all the parts and hoses, on my Price Pfister Marielle kitchen faucet model # T26-4NEE
Most new kitchen faucets feature single-handle control levers and washerless designs that rarely require maintenance. Additional features include brushed metallic finishes, detachable spray nozzles, or even push-button controls.Connect the faucet to hot and cold water lines with easy-to-install flexible supply tubes made-from vinyl or braided steel. If your faucet has a separate sprayer, install the sprayer first. Pull the sprayer hose through the sink opening and attach to the faucet body before installing the faucet.
Where local codes allow, use plastic tubes for drain hookups. A wide selection of extensions and angle fittings lets you easily plumb any sink configuration. Manufacturers offer kits that contain all the fittings needed for attaching a food disposer or dishwasher to the sink drain system.
Jul 26, 2012 | Price Pfister Marielle Kitchen Rustic...
The sprayer attachment to my kitchen faucet must have lost a spring or something. There is no give to the handle that i used to be able to push on, it simply stays down and the water will only flow threw...
ya you are correct, unfortunately there is no repair for this. Here is the link to see the parts which make up your faucet and to buy them. if you need anything else just ask:)
Jul 26, 2011 | Price Pfister 532-7PCC Marielle Pull-Out...
Replacement Price Pfister sprayer/hose
I called Price-Pfister and they sent out the parts free under their warranty, plus a few dollars for postage.
Apr 10, 2010 | Price Pfister Marielle Kitchen Faucet with...
Faucet leaks at base of spray handle when water is turned on. How can I fix this leak?
most of the the pullout sprayers need a rubber washer were it meets the hose chek for cracks and replace.
Oct 31, 2009 | Price Pfister 532-7PCC Marielle Pull-Out...
Sprayer leaking from inside handle mechanism
although it is possible that the spray head has gone bad, it is more likely that the diverter mechanism inside the kitchen faucet needs replaced. When this part is defective, it allows full pressure from the faucet to go to sprayer head even though the sprayer is not triggered. The sprayer is not designed to handle full pressure when it is not spraying.
Jun 05, 2009 | Price Pfister Marielle Kitchen Faucet with...
No water flow in gooseneck faucet
Sounds like the diverter part (insode the faucet) is clogged or broken.
May 27, 2009 | Price Pfister J103-BC 100 Series Kitchen...
Kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
May 04, 2009 | Price Pfister J103-BC 100 Series Kitchen...
Plumbing Logo
447 people viewed this question
Top Price Pfister Plumbing Experts
Level 1 Expert
john h
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
